Can-Am Outlander 800 frame strengthening - Can-Am ATV Forum
This is a discussion on Can-Am Outlander 800 frame strengthening within the Can-Am Outlander forums, part of the Can-Am ATV Discussion category; I have read and read and read some more about weak Can-Am frames, blah, blah. Some guys put pressure treated wood in there, some guys ...
Old 12-28-2008, 12:53 PM
lapoolboy's Avatar
Member #5924
View lapoolboy's Photo Gallery(0)
Some guys put pressure treated wood in there, some guys use square steel tubing, etc., etc.
I'm picking up my new Outtie on Tuesday and I want to address this frame issue before I even ride it. I have Ricochet skids on the way, but I want to beef up the frame too.
Soooo, I was thinking about filling the hollow frame spar with some type of epoxy material. It would go in as a liquid and fill the inside perfectly. Once hard, it would make the frame SOLID! We use a two-part epoxy at work that is VERY strong but it only comes in handheld gun size quantities.
We used to build fiberglass boats and we'd use A-B foam in 55 gal. drums. Shoot that stuff all up under the deck to add flotation. It would expand like crazy and dry pretty fast. It's easily cut, ground, etc. once hard but I'm thinking if it's in a hollow tube enclosed on all sides, it would give the frame more crush and dent resistance.
Am I thinking clearly here or way offline?
2008 Can-Am Outlander 800 (Viper Red)
CATVOS 4" Gen. 2 lift
28" Radial Outlaw tires
MSA Diesel 14" wheels
Ricochet full skidplate
Muzzy exhaust
PC5
VisionX LED light
PIAA headlight bulbs
TwinAir with Outerwears
Old 12-28-2008, 01:01 PM
Voodoo's Avatar
Member #2820
View Voodoo's Photo Gallery(6)
I think you will be OK with the Skids, IMO.....
The Ricochets cover the bottom very nicely...
Voodoo
Old 12-28-2008, 01:04 PM
mod88's Avatar
Member #4992
View mod88's Photo Gallery(0)
Update your profile so we know what unit you are getting.
I haven't heard about our frames being weak. I have heard our trailing arms bending if you are jumping a outlander. Which is kid of insane anyway. They weigh almost 800lbs.
I just totalled my '08 outlander 800 max xt. The unit barrel rolled down a hill about 75 feet. It rolled about 5-6 times and was jumping off the ground about 10 feet and slamming back down. The frame was fine. It didn't bend or break. It bent the upper supports that hold the body on. it also broke handle bars and gauge pod and flattened both right side tires and bent the rims. This was an extreme crash and the frame was just fine.
2009 800R Max XT
27 inch Bighorns/ Chrome Climax wheels,Crutchfield Extreme Shocks, Ceramic coated Exhaust, Tigers Tail,GPS Mount, rear soft bag, Mirrors, Customized shifter/ Gas Cap, Steering Stabilizer, BRP Plow, Heated shield port
Tom Brown
tom.brownatv@gmail.com
Looking for riding buddies
Old 12-28-2008, 01:17 PM
lapoolboy's Avatar
Member #5924
Man, just do a search for Can-Am frame mod...you'll find tons of information.
Maybe they beefed up the frames for 2008?
I have seen pictures of the hollow frame spar and the metal is very thin. Smallest bump into a rock or stump and that thing is dented in. That opens up the possiblility of bending at that point.
Muzzy exhaust
PC5
VisionX LED light
Old 12-28-2008, 01:27 PM
Renegade4me's Avatar
First Name: Riding the Oregon dunes since 1984
Member #5916
View Renegade4me's Photo Gallery(0)
Frames do get bent and tweaked from major wrecks. Had several of them come in the shop, but most of them fell of a trailer or some major rolling. I purchased a trade-in that fell off a trailer (500 max xt) and am having it rebuilt now, frame and a lot more. But they are actually pretty tough. The only week part is the fact that they are a skid and everything hits the skid. The Ricochet skid plates (help)this problem. We sold a lot of them and never seen the (extensive) damage again (front bottom impact dents). Yet the idea of filling the frame with some sort of epoxy is quite intriguing (and would recommend) Good luck. Attached a pic of the bike I am rebuilding. You can kinda see the frame damage from this angle. (update edit)
MINE:
UP FOR SALE: 2012 Can-Am Renegade 1000 X XC
Skat-Trak 26x12.5x12 Extreme Haulers 12-paddle
Tune Monster ECM w/wideband autotune
LTE Dual "Custom" Exhaust-ceramic coated - Polished Alum. Cans
QuadShopCustoms Primary & STI Secondary Clutch Kit
MRRPM Stage 1 drop-in Cams
WIFE'S:
2013 Can-Am Maverick X rs 1000r
Added: Aluminum Roof, Windshield, Doors.
Old 12-28-2008, 01:43 PM
Member #3580
View redrancher4x4's Photo Gallery(0)
I assure you that Riccohets do not solve the problem. Do the "frame mod" its too easy and cheap not to. Trust me if you really ride hard you will need it. learned the hard way.
2007 outlander 800 standard
Custom Front bumper and skidplate(Heavy)
Warn 3000 W/ synthetic rope
Twin Air Filter
Stealth snorkle
HMF slip-on
PC III
25" Duro Power Grips
Water Temp Guage
Old 12-28-2008, 01:51 PM
blevinsbulldog's Avatar
Member #4426
View blevinsbulldog's Photo Gallery(0) Send a message via AIM to blevinsbulldog Send a message via MSN to blevinsbulldog
i have ric. skids & the frame mod(steel tubes) its probably the best $20 invested in the bike!
07' 800 Outlander Max
R-LAWS 28's Skinny Wide
ITP SS108's
Crutchfield Springs
XMR Relocate Kit
/// CVtech
/// Secondary
Full Snorkz
Warn RT30
Hmf pipe
Old 12-28-2008, 01:52 PM
Big Ern's Avatar
First Name: I like cold beer and loose women
Member #3518
View Big Ern's Photo Gallery(0)
I like the expanding foam idea, if it was not too messy. I knew a guy who put some kind of that stuff in between his Ricochet skids, and the floorboards/frame to keep mud/snow/debrit out. It was black foam, and it felt like hard plastic after. he had it shaved down to look factory.
Man of Liesure
07 Red Outty800XT
Ceramic Dynoport Exhaust, Gen 3, Uni, Engine Ice
14" ITP SS112\'s, 26 Terracross Radials, Rene Pegs
PR Steering Stabalizer, HPG Shocks/HD Springs
Skids/A-arms, 1" Billet Spacers, Rene Side Panels
Warn 3000 W/Synthetic Rope, 110w Bulbs
650 Helix-3 Renny Fingers, 08\' Tailight
Custom Handguards, hot grips, decals
07 Yellow Outty650XT
Skids/A-arms, Uni, Rear Shocks Up-Front
Custom Handguards, hot grips, decals,
Q-Release Trunk, 110w Bulbs
Old 12-28-2008, 01:53 PM
Member #194
View pri_i_oh's Photo Gallery(0) Send a message via Yahoo to pri_i_oh
yep, Can ams have had problems with the frames for a while. In fact last I heard (I havent had a chance to really confirm it yet) these guys racing the 450 are going through a frame per race. Mines cracked in 3 spots and BRP says "sorry you abused it" and I had a plow frame. I thought that would protect it pretty well, guess I was wrong....do the mod. I wish I had known about it.
Old 12-28-2008, 01:54 PM
lapoolboy's Avatar
Member #5924
Yea, it would no doubt be messy, but you could shave it off anywhere it oozed out after it dried.
I just don't know if it would do much for strengthening.
Muzzy exhaust
PC5
VisionX LED light
2007 can am outlander 800 frame
2009 can-am outlaw frame
2009 can-am outlaw frame for sale
cam am outlander frame gusset
can am 800 frame buckle
can am 800 frame problems
can am forums outlander 800 frame
can am ouander 800 gusset kit
can am outlander 800 frame problems
can am outlander frame chassis stiffener
can-am renegade 800 chassis brackets
frame for sale for 2011 can am 800 xt
how to strengthen outlander frame
how to strenthen can am frames
strengthening can am outlander frame
