One way bearings for easy shifting
This is a discussion on One way bearings for easy shifting within the Can-Am Outlander forums, part of the Can-Am ATV Discussion category; Thanks...
  #271
Old 02-05-2010, 07:57 AM
View QUADAHOLIC's Photo Gallery(63)
07-650-MAX
Ricochete ~ Crutchfield 2+1
  #272
Old 02-06-2010, 08:02 AM
Member #7536
View deerhunter's Photo Gallery(0)
Default solution
Thanks to all for the input. The vbx bearings worked great!! I now installed them on my second outlander.
I do use isoflex as a lubricant for the one way bearing.
My Outty's both are 2005 400's and have had this problem since new. We use them for everything from plowing, hauling deer, planting food plots to trail riding. So they are not only a tool but for alot of fun in the mud.
After breaking off a shift lever, cleaning and lubing multiple times the new bearings were the ticket!!
  #273
Old 02-08-2010, 03:38 PM
roundy's Avatar
Member #9034
View roundy's Photo Gallery(0)
Was working on my clutches as I came across this. It shifts hard and you kind of had to pop it in gear, sometimes would creep. So I pulled it apart, one of the bearings doesn't even turn! got it broke free, I also noticed almost no grease, really sticky leftover crud. Also the friction spacer seal thing is stuck pretty good had to pry it off. I ordered some stuff today!
  #274
Old 02-11-2010, 11:31 PM
Member #9006
View BIGGUN's Photo Gallery(0)
Quote: Originally Posted by rene1 View Post
well let me eat some words....i had my clutch all apart on the bench for a week now.....but i was out of town, just got back and went and had a looksy. your right, the friction washer removed, and the pieces don't touch. i was thinking that the spring seat would rub on the lip on the inner sheave shaft. but there is actually a small clearnce there.
so, just to humor you out for the sake of sticking my foot down my throat, i will assemble it without and see how it works. and it is likely going to be fine from a damage perspecctive. BUT, it may not have enough friction with the low friction bearings and no washer...it would be like shifting it with the engine off haha....gone full circle now....ohwell. when my parts show up to re assemble it we will see.
all apologies for being an ass..
Well, what did you end up finding out? Any difference?
Kevin
  #275
Old 05-05-2010, 10:11 AM
Member #6511
View dongatta's Photo Gallery(0)
Default Better Shifting
I installed my VXB bearings last night and all I can say is WOW!!!!! My machine is shifting like a piece of cake. It was shifting so easy I could go from H to P without knowing. One other thing I noticed was with my original bearings is when it was in park or neutral the belt would not be turning. Now in park or neutral it spins. When I go into h r or l the belt stops spinning.
  #276
Old 06-30-2010, 01:25 PM
Member #5999
View Ola800X's Photo Gallery(0)
Isnt that the other way? That it should not spin in N or P, if youre bearing are working great? Giving less tension to the gearbox?
I just did this mod myself today, and i`m not to happy yet.. Used the VXB bearings, and greased up the oneway like i should..
My secondary never spins in N or P, and i still have to hump alittle to go from R to H or L, or from P and into any gears..
Perhaps it will get better after some driving? Just been testing in my drive way tonight.. alittle gearing, and some idling in gear, in N etc..
08` Renegade 800 X
6808 bearing ontario
can am outlander how one way bearing works
shifting problems renegade 1382 Can-Am / BRP 5 05-03-2010 10:13 PM
rear bearings cmepoo Can-Am / BRP 0 08-15-2008 01:39 PM
Over Easy UNDRPSI Can-Am / BRP 7 02-05-2008 10:26 PM
rod bearings ? mudmanmatt Can-Am / BRP 0 05-08-2007 01:03 AM
ATV wheel bearings 2007 CAN-AM OUTTY 800 ATV Tech Tips 1 02-16-2007 04:34 PM
