LED headlight light bulbs
This is a discussion on LED headlight light bulbs within the Can-Am Outlander forums, part of the Can-Am ATV Discussion category; Has anyone tried LED headlight bulds ? I saw various listings for SMD LED 9003 and H4 light bulbs. I wonder how bright these are? ...
Old 07-19-2009, 06:27 PM
Lunytech's Avatar
Member #7298
View Lunytech's Photo Gallery(0)
Default LED headlight light bulbs
Has anyone tried LED headlight bulds ? I saw various listings for SMD LED 9003 and H4 light bulbs. I wonder how bright these are? I'm tempted to use these in the stock location of my '06 800 MAX XT because they should use less current leaving extra power to run a couple of handle bar mounted halogen 55 watt lights. I attached a sample ebay listing.
Your input would be greatly appreciated. Thanks...
2x Car 68 LED SMD Xenon-White Bulbs H4 Fog Light 12V:eBay Motors (item 220441918089 end time Jul-25-09 03:00:26 PDT)
Old 07-20-2009, 07:41 PM
Member #6611
View ericdrob67's Photo Gallery(0)
I tried a very similar set of bulbs, and they were not very bright at all, noticably dimmer than the stock 35 watt bulbs. And they also made the high beam indicator light up on the dash. Not to mention there was no difference between low and high beam setting.
I have been running normal automotive xenon H4 bulbs in my 400 for several months with no problems.... although i rarely use the high beams since "low" beam is more then bright enough for most riding.
_______________________________________________
09 Outlander 800r
DIY stealth snorkels, BH 2.0's, Hayden fan controller, HMF utility, PC3, Tusk hand guards, Protaper Fat pad
Old 07-20-2009, 07:45 PM
Voodoo's Avatar
Torn and Twisted!!
Member #2820
View Voodoo's Photo Gallery(8)
PIAA H4's work great...
Voodoo
Old 10-20-2011, 09:25 PM
Member #19020
View Bunny's Photo Gallery(0)
One of the better night LED's I have found is the C. Crane BNB Bright Night LED Nightlight Bulb. This bulb consisting of 4 diodes making the distribution of light very even. Priced at under $5, the manufacturers rate that you will gain about 60,000 hours of usage out of one. Best Led Headlamp However, from my experience you will find that the light will start to fade over an extended time. How long that will take seems to depend on the bulb.
Old 01-13-2012, 02:46 AM
Member #20301
View carriedolt's Photo Gallery(0)
I have tried these led bulbs.Now i am using 50 watts bulb
They were better than the halogen bulbs. Consuming low power and also bright.
My suggestion is to go with led bulbs.
Good Luck
no spam in sigs please. read the rules.
9003 led bulb
9003 led headlight bulb
9003 led headlight bulbs
9003 led review
atv led headlight
atv led headlight bulbs
atv led headlights
brightest 9003 led bulb
h4 led headlight bulbs review
led 9003 headlight
led atv headlights
led bulb 9003
led headlight 9003
smd led headlight review
smd led headlights
Results: 35W Headlight Bulbs Upgrade to 55W on 800 Half Stuck Can-Am / BRP 45 07-23-2009 06:12 PM
H4SB Xenon light bulbs Northern Bomb Man Can-Am / BRP 30 09-20-2006 11:00 PM
new bulbs push4racing Can-Am / BRP 9 08-15-2006 06:00 PM
800 tail light bulbs? turboman Can-Am / BRP 5 12-06-2005 06:27 PM
Head light bulbs for 2006's?? turboman ATV Tires and Wheels 2 08-13-2005 08:12 AM
