02-08-2010, 05:18 PM
Member #7675
What the hell, I'll give em a try. Mine shipped today.
2008 Outlander Max 800, 2" full snorkels, frame mod, UNI filter, Plano hard box, HID lights.
02-08-2010, 08:19 PM
Member #4298
Me too...$44 Shipped to my door,,,
2008 Outlander 800XT Camo Owner. DPMS & Rock River AR-15 Nut!!
Douglas Black 12″ C-Series Type-7 Wheels & ITP XTR 25",
Ricochet FULL Guards & Skids,
BRP Rear Box with quick disconnect,
BRP Bark Buster Hand Guards behind the OEM XT Plastic Hand guards,
Polaris Override toggle switch,
Soft Hand Grips (Stops a lot of the vibrations),
EBS Extreme Duty Front Brakes,
BRP Fender flares.
switch,
02-08-2010, 08:34 PM
Member #4298
OK.....Where is the best to mount the ballast??
BRP Fender flares.
switch,
02-08-2010, 09:21 PM
Member #8320
Not exactly sure yet....the length of the harness will probably determine where they will go....up as high as possible. You will see they are fairly small and thin. They are supposed to be waterproof and all the connections except the headlight connection are sealed. It's the factory headlight connection that will have to be protected....as I said in an earlier post, I have "sealed" other large connections by using large heat shrink, lots of dielectric grease, and tie wraps at both ends of the heat shrink....also using "liquid tape" in the ends of the heat shrink before putting the tie wraps on helps.
When the Millenium was approaching, all the world was concerned about Y2K....in Canada it was "why wear a touque EH?" ...........GO TEAM CANADA!!!!
08 800XT Camo
26" Maxxis Bighorns
Heated grips
Horn install
Garmin Oregon mounted on handguard (hard wired to battery}
Bear banger mounted on handguard
Synthentic winch line
BRP shifter lock
LED "antitheft" light on instrument panel
2" reciever on rear home fabbed - cost $10
Plastic skid plate
Prewired plug in charging line at battery
Plastic gear box rear mounted
Rotapax 2 gallon fuel on frt rack
Rotopax 1 gallon water inside rear box
ATR spine
Working on HID install and new one piece 3/8" skidplate
Daily ride 99 GMC 4x4 ext cab S/B
Summer ride 69 Camaro SS convertible
Wife's daily ride 07 Nissan Frontier
Wife's summer toy 06 Honda CRF 230
21 foot Okanagan travel trailer
02-08-2010, 10:59 PM
Member #7470
if your going to buy hids why not buy ones that are made for the outy. HO was the one that mentioned eagle eye lighting. they are 250.00 but you get what you pay for  . now these are plug and play no wire cutting and work great since HO was the guini pig he's had no problems.. mine will be here wed
2010 canam 800r max xt (camo), 26" bighorns,elka reservoir's, heated riding gear on t-stat, heated grips & thumb, eagle eye HID lights & (miller lite)
2005 yfz450/ gytr graphics, gncc tires
2010 ski-doo rev xp 600, piaa headlight bulbs
02-09-2010, 11:28 AM
Member #8320
ifferent vehicles
I've looked at a few sites where they claim to have "custom " kits for lots of different types of vehicles, but basically I think they are just basic kits with the correct bulb and headlight connector?? The biggest difference with the Outty is the headlight is sealed from the back, unlike automotive setups. The only modification required is to get the headlight connector outside the sealed headlight. Let us know how the kits look. Also is it worth $250 for a small mod like this?
08 800XT Camo
26" Maxxis Bighorns
Heated grips
Horn install
BRP shifter lock
Plastic skid plate
ATR spine
02-09-2010, 03:02 PM
Member #6316
I copied the following information off of an HID kit description on ebay. The product is slim Digital ballasts with the HID kit. What brought my attention to it is that it mentions prevent failed ignition. I know some people have had problems with there atv not starting if the HIDs are turned on before the machine is started?
I just wanted to post it up for discussion. Here is the Item number:400102334764
WHY DIGITAL? AN INTELLIGENT LIGHTING MANAGEMENT SYSTEM THAT PROVIDES INCREASED ENERGY SAVING, PREVENT FAIL IGNITION, EASIER MAINTENANCE, PROLONG THE LIFE OF THE BULB BY 30%. THIS IS A BREAK THROUGH TECHNOLOGY OVER THE PREVIOUS ANALOG DESIGN AND THIS DESIGN IS DRAMATICALLY IMPORVED OVER CONVENTIONAL BALLASTS.
02-09-2010, 06:01 PM
Member #7470
ifferent vehicles
yea i no what you mean with getting the connector out of the boot,but with the eagle eye kit it comes with the new connector and the boot.so theres no slicing & siliconeing things to keep dry. the stock headlight wire unplugs maybe 10 to 12" up from the headlight. just unplug that & plug the new eagle eye one in & put your headlight back together. also theres no need for a relay like the other kits need, were you here about it shutting your quad down. just somthing to think about....
02-09-2010, 08:15 PM
Member #8320
The older ballasts were larger (about 1" thick) and came with a standard automotive relay in the wiring harness to turn on voltage to the lights. You also had to wire a battery positive and negative, and run the harness from one side to the other side. The slim ballast setups use a "digital" relay setup, and I sure they are talking about failed ignition of the lights, not the vehicle. I do on occasion get one light which does not "fire". Simply turning the lights off and back on usually corrects problem. The slim ballast kits are definitely the way to go for simplicity of install.
08 800XT Camo
26" Maxxis Bighorns
Heated grips
Horn install
BRP shifter lock
Plastic skid plate
ATR spine
The Following User Says Thank You to davegee For This Useful Post:
