02-16-2010, 11:00 PM
Member #6316
Ballistic - I tried to install my HID kit today. I think I got the same kit as you because I have identical ballasts. My problem is for some reason I thought I wouldnt need a relay. So now I have ordered a relay, but am confused about hooking it up. Do we have to run a wire all the way back to the battery posts or are there auxillary hookups under the front pod area? I have a renegade and the battery in under the rear rack. Are your high beam lights still useable?
02-16-2010, 11:10 PM
Member #7675
I didn't think I would need one either, but the computer didn't like being connected straight to these ballasts. I ran a fused power wire from the battery to the relay. The HID burners are now the only bulb, with one speed.
2008 Outlander Max 800, 2" full snorkels, frame mod, UNI filter, Plano hard box, HID lights.
02-17-2010, 10:02 AM
Member #6316
I didn't think I would need one either, but the computer didn't like being connected straight to these ballasts. I ran a fused power wire from the battery to the relay. The HID burners are now the only bulb, with one speed.[/QUOTE]
Hmmm, I didnt really want to give up my high beams, I was hoping to keep them and have HID in the lows. While still using the stock light switches. Do you remember what gauge of wire you ran from the battery to up front. Did you buy a relay kit and splice some longer wires to get back to the battery?
02-17-2010, 06:57 PM
Member #7675
Ah yes, you have a Renny, you can just put the HID bulb in the low bulb place and fire it off of the low signal wire (through a relay if necessary). I ran a 10 gauge wire from the bat to the front compartment and did all connections in that vicinity. I pieced together my own harness.
02-17-2010, 10:40 PM
Member #4298
WOW!!! I was hoping it would be plug & play too.... If possible please post the color coding of the wiring for the low beam and the relay connections... (Please)!!!
2008 Outlander 800XT Camo Owner. AR-15 Nut!! DPMS .223 & Rock River 300-Whisper !!
Douglas Black 12″ C-Series Type-7 Wheels & ITP XTR 26",
Ricochet FULL Guards & Skids,
BRP Rear Box with quick disconnect,
BRP Bark Buster Hand Guards behind the OEM XT Plastic Hand guards,
Polaris Override toggle switch,
Soft Hand Grips (Stops a lot of the vibrations),
EBS Extreme Duty Front Brakes ( Still Grind's Like Stock Pads!!! WTF ???)
BRP Fender flares.
Moose Racing Dual Gasser
Xentec HID Head Lights.
switch,
02-17-2010, 10:43 PM
Member #4298
Ballistic_Tip , Where did you order that relay from???
BRP Fender flares.
switch,
02-18-2010, 12:38 AM
Member #8320
I just got around to installing mine a couple of days ago, and ran in to the same problem....because I have dealt with lots of these kits in automotive applications and never had a problem, I was surprised when they were not working correctly. My Outtie gave me a "lost communication" message and the machine ran like crap!! I have left the battery on the charger and will attack this later this week. Fortunately, I have spare setups with an automove relay and the larger style ballasts, and direct wiring to the battery, so I will try that setup. These older kits use the factory connection as a SIGNAL only, and the power comes straight from the battery, and not thru the factory connector. I was really bummed cause I was expecting a better outcome, but hey...we will get this done! Just so you know, these slim ballast kits work awesome in the vehicles I have installed them in (about 12 so far)
When the Millenium was approaching, all the world was concerned about Y2K....in Canada it was "why wear a touque EH?" ...........GO TEAM CANADA!!!!
08 800XT Camo
26" Maxxis Bighorns
Heated grips
Horn install
Garmin Oregon mounted on handguard (hard wired to battery}
Bear banger mounted on handguard
Synthentic winch line
BRP shifter lock
LED "antitheft" light on instrument panel
2" reciever on rear home fabbed - cost $10
Plastic skid plate
Prewired plug in charging line at battery
Plastic gear box rear mounted
Rotopax 1 gallon water mounted to side of rear box
ATR spine
HID headlights
Rotopax 2 gallon fuel mounted to front fuse panel cover
Additional gel battery mounted under rear cover
Working on new one piece 3/8" skidplate
Daily ride 99 GMC 4x4 ext cab S/B
Summer ride 69 Camaro SS convertible
Wife's daily ride 07 Nissan Frontier
Wife's summer toy 06 Honda CRF 230
21 foot Okanagan travel trailer
02-18-2010, 08:14 AM
Member #7470
well like i had said in a earlyer post, i have a plug and play kit made for the outlander. it came last thursday takes maybe a 1/2 hour to install. theres no relay,cutting,slicing,siliconing nothing just plugs right into factory wires then turn the key and ride.
so far its been working perfectly no issues
2010 canam 800r max xt (camo), 26" bighorns,elka reservoir's, heated riding gear on t-stat, heated grips & thumb, eagle eye HID lights & (miller lite)
2005 yfz450/ gytr graphics, gncc tires
2010 ski-doo rev xp 600, piaa headlight bulbs
02-18-2010, 08:26 AM
Member #6316
I cant justify spending $250 on a HID kit though ST222. I will have probably $70 in it once I get every last piece (kit, harness, extra wire, connectors) That leaves me $180 extra to play with. Yes I have a little more time invested, but there is like 8 feet of snow everywhere so I am not missing out on riding, just spending more quality time with my Renegade, and also learning a little something along the way.
02-18-2010, 10:34 AM
Member #7470
thats very true murph, i understand. I was just trying to let people no who cant do this kind of wiring themselfs that there is a plug and play kit out there with no kinda skills needed.
yes its alittle pricey but all the leg work is done for you. plus it ends up looking factory being theres no extra wires and relays runing around. but all in all as long as it works thats all that matters.
by the way isnt spending time with the machine so nice  cheers scott,
