I have had a leaking rear diff and I could see the seal where the drive shaft goes into the diff coming out...after pulling it apart it seems the big nut inside there had loosened and pushed the seal out causing it to leak. That big nut in there takes some kind of tool to tighten it..It's going to need a tool that will turn the nut from the middle. Does anybody know how to go about tightening this nut and how tight should it be? I think from the manual one of the nuts is supposed to be 145ft/lbs but bot sure which one. Thanks
