12-01-2009, 04:10 PM
Member #7977
Can Am Heated Grips
Putting new heated grips on, any hints on getting the grips on easy? I had a rough time with the first ones on my other outlander.
2004 Outlander 400 XT - gone
2007 Outlander 500 Max XT - gone
2008 Outlander 650 Max XT
(I think that will be it for a while)
12-01-2009, 04:22 PM
Benefactor Gold
Member #3629
I just put BRP heated grips on my Renegade. I just scaped as much of the old glue off, wiped the bar with alcohol and slid the grips on. I did have to use a board and hammer to tap it all the way on but it was quite easy.
08 Renegade 800, ricochet skids, 29" swamplites, SS108 rims, 2" lift, Ron Woods exhaust, snorkeled, hand grip and throttle warmers, Clutch kit and programmer. All decals removed. (SOLD)
12-01-2009, 05:37 PM
Member #328
Hair spray works very good for installing grips.
2007 chev C/C Dually D/A, 8.5X20 enclosed trailer, 05 raptor 80, 08 can am 800 max ltd, 06 raptor 700, 09 850 xp.
12-01-2009, 07:40 PM
First Name: Born and Raised in Alaska
Member #7956
Easy Install
One of the ways i have done it, is to get some heat resistant spray paint and spray the bars. They usually slide right on. I have used the hair spray trick and it works pretty good but once they get wet they tend to roll. Good Luck...
2010 800 Camo Outty.. 28" Zillas on SS108 Black, Synthetic Rope, 2" Lift, Ricochet Skids, Dalton Clutching, Hand and Thumb warmers, RAM Rhino Holder
12-01-2009, 08:23 PM
Member #5841
I second the paint method with a little pursuasion from a rubber mallet. Just tap them on hitting the grip nice and straight and don't get them on too far as to "pinch" the wire.
2009 Outlander XT in Yellow, Snorkeled, Rad Re-Locate, Frame Mod, Ricochet Skids, One-Way Bearing Mod, QSC Clutch Kit, Reverse Mod, PRP Steering Stabilizer, Crutchfield Stage I rear / Stage II frt, Maxxis 28 Zillas on ITP Beadlocks, 30" Gorilla Silverbacks, Renegade Foot Pegs, heated thumb & grips, 2 X 1gal. gasoline / 1 X 1gal. water RotoPax
12-01-2009, 08:33 PM
Member #4453
The moose grips I bought suggested right in the directions to boil them in water for 3 min, that recomendation was if I was trying to put them on an Outty. After you had to wd40 them and that creates the chemical reaction for em to stick. I thought the last part was kinda weird, but it worked.
08 650 Max XT
HMF penland, Richochet Skids, Uni Filter, jacket water temp gauge, Stealth snorks, relocated air intake. (Rolled and wrecked)
09 Outlander max 800r
HMF Penland, Richochet Skids, Jacket water temp gauge, Full snorkels BRP windshield, fan override switch, CVT and air box drain, Tamarack soft box, synthetic winch cable, 1" wheel Spacers, 26" Big Horns, PIAA lights
12-02-2009, 05:43 PM
Member #6732
wd40!! and get symtec grips they are awesome
2009 800R outlander XT
ricochet skids
PCIII
diesel wheels, 26 moto mtc,HMF slip-on
snorkeled, race tuned by john cannon
12-02-2009, 11:36 PM
Member #1260
Rubber mallet and wd40 worked fine with me .... go easy with the hammering ...
12-03-2009, 07:45 AM
Member #7977
Thanks, going to try to get them on tonight..
12-03-2009, 10:37 AM
Member #8260
Grip HOW TO?
I'd like to install heated grips and thumb warmer but have no experience with quads to speak of(Just installed full set of Rico's). Are the heaters plug'n play? Hook up under the pod somewhere?
cheers and thanks.
can am atv heated grips, can am heated grips, can am heated grips can am 650, can am heated grips instalation, can am heated grips wiring, can am hot grips, can am hotgrips, can am outlander heated grips install, can-am heat hand grips & throttle combo wire diagram, can-am heated grips, heated grips for can am atv, heated grips for outlander 400, how big is a can am rengenade grip, problems with ca am heated grips, replace handle grips on can am outlander 400
