Broken shift lever - Can-Am ATV Forum
Broken shift lever
This is a discussion on Broken shift lever within the Can-Am Outlander forums, part of the Can-Am ATV Discussion category; My 400 XT Max has been shifting hard all winter while snow plowing even while doing the hump. The shifter lever finally broke today and ...
Old 01-08-2010, 04:10 PM
K31Scout's Avatar
First Name: Hunt,fish,archery
Member #8335
View K31Scout's Photo Gallery(0)
Unhappy Broken shift lever
My 400 XT Max has been shifting hard all winter while snow plowing even while doing the hump. The shifter lever finally broke today and I got it back inside the garage in reverse. How hard is it to replace the shift lever? Is there an after market lever that is a little harder? Thanks,
Bill
Old 01-09-2010, 12:35 AM
Member #8669
View oldred400max's Photo Gallery(0)
Shift Lever 400 max
I broke mine a couple of weeks ago.. got a replacement at Can Am dealer. Not hard to replace but watch out for the 2 o-rings.. they fall out easily and
can be hard to find.
Old 01-09-2010, 02:13 AM
Member #6611
View ericdrob67's Photo Gallery(0)
Bill
After you get the lever replaced, Id highly recommend the one way bearing mod.
I found the bearings for as low as 20 bucks shipped and you should be able to get it tore down and put back together in under an hour with basic tools.
_______________________________________________
09 Outlander 800r
DIY stealth snorkels, BH 2.0's, Hayden fan controller, HMF utility, PC3, Tusk hand guards, Protaper Fat pad
Old 01-09-2010, 08:17 AM
K31Scout's Avatar
Member #8335
Thank you. It's -0F here this week so I'll wait on the bearing till spring. Thanks for the tip on the o-rings.
Old 05-13-2011, 06:59 PM
191185's Avatar
Member #10777
View 191185's Photo Gallery(0)
I know this thread is about 5 months old, but does the one way bearing mod have any benefit in easier shifting ?
Or are you just recommending the one way bearing mod because it will coast easier ?
I also broke my shifter, and have not fixed it yet,.. . going to give it a go this weekend .. any help would be appreciated. .
do you take off the seat, then the plastic, to get in there ?
2007 Can-Am Outlander Max XT 400 -
spline from all terrain research, skid plates. ..
Old 05-13-2011, 07:05 PM
gbroad23's Avatar
Member #4746
View gbroad23's Photo Gallery(0)
The bearing mod makes it shift way easyer, Little to no humping required. A clean and greasing of the one way helps but does not compare to the aftermarket bearings. i got mine at battery worl for $13 each IIRC
Old 05-13-2011, 08:13 PM
Yup everything comes off real easy just watch the long side panels they can be tricky but just take your time. No tools required to take off the plastics you will need to take off.
Old 05-13-2011, 08:35 PM
191185's Avatar
Member #10777
OK I got the shifter out...
How much does the replacement cost at a dealership ?
I'm going to do a search and look and see how to do the bearing mod, ... unless anyone has a link with instructions and pictures ?
I also read that 75W 90 chain oil by Amsoil makes a difference in shifting ... anyone agree ?
Old 05-13-2011, 11:11 PM
Member #14295
View 05cummins's Photo Gallery(0)
I use 75 140. 75 90 is not the correct oil for the gear case.
1200hp cummins drag truck..2008 pitviper compound turbo six speed viper 2012 procross 1100 turbo 2011 XMR turbo soon.
Old 05-13-2011, 11:30 PM
Member #13825
View sargent-tom's Photo Gallery(0)
Talking
On the 400 the trans is integral with the crankcase thus using your engine oil. The V-twins use a divorced trans and their own oil. The shift lever is easy to replace ,and if you have the capability I recommend rebuilding your broken lever using 3/8" cold rolled ( stronger& more rigid then the 1/4" stock). When replacing the lever check the alignment carefully. Place trans in neutral, shift lever in neutral notch and adjust carefully so each sits exactly in it's proper location. Next go to your one way , clean& grease it , as you do this turn the 2 bearings in the one-way by hand testing them to see how easy they turn. Most likely they will be hard to turn ( because of the seals) . That is what the other posts are talking about ( freewheeling at idle when the belt is riding on it ), the after market bearings spin easier. To illustrate: on a manual trans car it is much easier to put it in gear when the clutch is fully depressed then when it is partially depressed. I have done all this except the after market bearings and my 400 now shifts very well, that is why I recommend doing this step by step.
The Following User Says Thank You to sargent-tom For This Useful Post:
191185 (05-14-2011)
2004 bombardier outlander 330 gear arm
2005 can-am outlander broken shift
2005 can-am outlander shift lever pulled in
2007 can am outlander 400 shift lever
2007 can am outlander xt 400 gear shift
2012 renegade shifter broke
4wheeler automatic shifter fell off
broken bombardier outlander 400 shifter
cam am 400 shifter replacement
can-am 400 outlander 2010 how to fix shifter
canam outlander 2007 gear shifter
canam outlander gir shift
fixing shifter knob on 2007 can am 400
gear shifter remove cam am 4 wheeler
shift lever broke on outlander 400 can am atv
Hard to move shift lever Sp700 GOTTOYS Polaris 9 01-02-2016 08:11 PM
broken brake lever camlaw Can-Am / BRP 4 09-14-2008 09:14 AM
Brake lever redrancher4x4 Can-Am / BRP 3 01-14-2008 08:30 AM
Gas Lever sjwilson Can-Am / BRP 13 08-25-2007 04:17 PM
Torsion bar lever broken on the 800 KYRenegade Can-Am / BRP 17 03-26-2006 08:15 PM
