Flooded Engine - Page 2 - Can-Am ATV Forum
Flooded Engine
This is a discussion on Flooded Engine within the Can-Am Outlander forums, part of the Can-Am ATV Discussion category; You need to pick the front of the bike up in the air and drain the exhaust system. When the bike quits the exhaust fills ...
Old 02-09-2010, 11:15 AM
cam2010's Avatar
Member #7413
View cam2010's Photo Gallery(2)
You need to pick the front of the bike up in the air and drain the exhaust system. When the bike quits the exhaust fills up and as you crank it over the water runs back in thru the exhaust valve every time it opens.
I have had this happen a few times but if you drain the exhaust right away you can get away with about 2 oil changes to flush it.
The best way is to flip it straight up onto the back rack.
2012 commander 1000 XT
2010 canam outlander 800R XT
26" Zillas
Old 02-09-2010, 05:04 PM
Member #5779
View leon's Photo Gallery(0)
Hey when you flush out your engine you should fill it with Marvel mystery oil first and crank over. It blends with the water, then drain right away. Repeat steps, only use 3/4-2/3 of mystery oil and the balance of oil with cheap oil, no use in spending top dollar on oils when your not actually riding the machine. Keep repeating the steps and lessen the amount of mystery oil. Also change out the oil filter 2 or 3 times. On your last change replace filter and then use a good quality synthetic oil. I myself use Amsoil, i've changed all my vic's oil and gone with Amsoil. Also change the plugs, air filter, and tilt the machine back to drain the water out of the exhaust. Hope this helps lindsaylisa.
07 outty800 XT Ricochet skids 02 Rancher 350 25" 589\'s warn 424
  #13
Old 02-09-2010, 06:53 PM
Member #6384
View SGTCap's Photo Gallery(0)
I ended up having to rebuild my engine when I drowned it. These machines run an automotive style crank and rod bearing that are pretty easy to tear up with water and mud. I hope you dont have to tdo the same. I was fortunate to catch it before I destroyed the crank. Cranks are $1300.
If the water you got in there was at all muddy or sandy I would start tearing it down. Its cheaper in the long run than replacing the crank.
  #14
Old 02-09-2010, 09:43 PM
texdot5's Avatar
First Name: 2008 Can Am 800 Outlander XT 2 UP
Member #8677
View texdot5's Photo Gallery(0)
flooded engine
I want to thank everyone for all of their feed backs and trust me, my life would of been hell if it was not for listening to you guys! Luckly the mud hole we normally play in was full of clear water due to the recent rains instead of merky , muddy water. I did though use a product called "Seafoam" instead of Mystery oil and it worked awsome, not to say the mystery oil would not have worked just as great. I also took oil samples inbetween changes to verify the residual water in the oil.23 quarts of oil later, 800 Outie XT is running just as good as before !!! if you combine what everyone told me and perform them while workin on the bike, you should come out gerat in teh end.. I posted a picture under my profile of my yellow submarine.
  #15
Old 02-10-2010, 11:11 AM
cubby's Avatar
Member #8082
View cubby's Photo Gallery(5)
Yellow Sub, that should be your new name LOL. Glad to hear every thing worked out for you in the end just hope you don't do it again
Put your helmet on and try something stupid
2008 outty 800xt, with bighorns on ITP ss212's, renny foot pegs, and skids, HMF pipe and K&N filter
2001 summit 700 144"
2012 skidoo summit 800 etec
2013 Polaris 850xp with some goodies
  #16
Old 02-17-2010, 07:25 AM
texdot5's Avatar
Member #8677
I am sure this is related to the flooding of the engine but just not sure what is causing it. After friving approx 10 miles last Dunday, Al of a sudden, the 800 outie just died. No sputtering, no jerking just came to a slow crawl and stopped! I would keep hitting the throttle and yet no engine. I let it sit for 10 seconds and it would start right up and run approx 50 yards. I would let it sit 2 minutes and it would run for approx 100 yards. and then shut off and come to a crawling stop again. Not sure if its was getting no gas through the fuel filter or electronic problem. All of the dash lights stayed on just no engine. Any ideas?
  #17
Old 02-17-2010, 05:45 PM
brutewing's Avatar
Member #8867
View brutewing's Photo Gallery(3) Send a message via ICQ to brutewing
Quote: Originally Posted by Smiffracing View Post
Should have given her hell! I was cruising down a side channel of the river by my house a week ago. Maybe 2 feet deep in the deepest spot, or so I thought! I was in 4X4 and cruising along just like 10-15 MPH. Next thing I know my front end dips and I can't see the bottom at all! I was in it too far to brake and back out so I did what seemed normal to me, Pinned it! I didn't know what would happen but I didn't have alot of options. It had about 3 feet of traction on the back tires before I was totally afloat! That thing was staying on top of the water and was actually propelling forward! It then stood straight up in a wheelie and was going over! I bailed off the back thinking that I could touch bottom and give it a little push. Wrong! Water up to my neck and I still can't touch bottom so I figured what the hell, Punch it again! by this time it was sunk about to the seat with the front end sitting higher than the back by about a foot. I had one hand on the throttle and one hand on the rear rack and was kicking my feet as hard as possible with what was now about 200 pound carhart bibs and snow packs! It just kept going! I made it overall about 30 feet across water till my belt finally slipped about 4 feet from the bank. A couple of buddies grabbed the front bumper and I stood up in only about 3 feet of water. We made it! They lifted the rear end and I gave her some gas and dried the belt and off I went, heading a few miles back home into the 15 degree snowing night! It was the most amazing thing I and a few of my friends ever witnessed! My Outty does have some work to it and great tires. It was so sweet that I have thoughts of trying it again but on Film.
THAT SOUNDS AWESOME I WANT THE YOUTUBE LINK LOL
2012 800 MAX straightline performance intake, straightline pipe, straightline air box mod, straightline power commander tune, QSC CLUTCH and YELLOW BECAUSE IT IS FASTER, 2" rox riser, 26" bighorns on 14" climax motosport rims, BRP storage box ,,right and left mirrors
2006 18 foot mr pike lund my baby
1985 350X TRIKE
1997 Honda valkyrie
PAST QUADS
2005 750 BRUTE FORCE
2005 650 HONDA RINCON
2005 KFX 700
1993 220 KAWASAKI
1985 90cc kawasaki dirt bike
atv engine has flooded crankcase
can am flooded engine
flooded 800 can am how to fix
flooded four wheeler engine
flooded motor on wildcat 1000
flooded quad engine oil
how do i fix my four wheeler if i flooded it
how to fix a flooded quad
how to fix flooded 4 wheeler
how to fix quasd with flooded engine
how to flush a flooded four wheeler motor
how to restart my atv after i flooded the carburetor?
how to unflood a four wheeler
my 4 wheeler is flooded
put diesel in motor for flooded atv
Flooded CjWaggs Can-Am / BRP 5 06-09-2008 07:33 PM
990 cc engine sierradmax Can-Am / BRP 16 07-10-2007 03:15 AM
Can someone tell me where the engine # is?? spudbutter Can-Am / BRP 6 01-13-2007 06:20 PM
Hot Engine wildbill Can-Am / BRP 6 07-25-2006 07:12 PM
Engine Ice au2183 ATV Tires and Wheels 1 05-06-2006 12:33 AM
