02-08-2010, 03:36 PM
Member #7783
Popping/backfire
I've got an '09 outty 500, HMF pipe(sounds great), Dalton clutch springs and custom snorkeled. fantastic atv. Problem is that there is a nasty backfire/popping sound comming from the air box and it is lacking power, what could be the cause? is it a possible exhaust leak?
02-08-2010, 04:21 PM
Member #8966
Chances are you're running lean. You have to richen up your A/F ratio. I have an HMF on the way, and HMF told me that I may or may not need an EFI controller, so I am going to run mine without it first, and see how it runs. But if it backfires like yours, I am going to get a Power Commander 3 as most people on these forums swear by them. I also have just installed a snorkel kit, and it runs fine with just the snorkel kit on it.
A couple of people on these forums told me that these bikes run rich from the factory (well, the 800's atleast) so I shouldn't have a problem. I hope not.
2008 Can Am Outlander 800 Max XT Ltd.
SnorkelyourATV Extreme Snorkel Kit
Renegade Pegs
Kolpin Rear Box
HMF Swamp Series XL
02-08-2010, 04:33 PM
Member #7783
Thanks for the reply. The pipe sounds great!!!!. the quad was starting to pop before the pipe, quess I should have mentioned that. I put new fuel in and new plugs. is it a warranty thing to have them check the air/fuel mixure, or is it something else?
02-08-2010, 04:57 PM
Member #3575
The shop manual says exaust leak or engine is running hot because of a lean condition.
08 650xt Ricochets,stealth snorkel, Black ITP C series, 27" Outlaws, HMF Utility, RDC 2" lift.
02-08-2010, 05:30 PM
Member #4130
popping in the intake side is lean. If this started before the exhaust install, I would check your fuel pump pressure.
08 gade 800
-800vtwin.com ECM
-Koso Display
-LTE Dual Exhaust (ceramic), modded QC's
-50mm tb
-09 tb boot, airfilter, cams
-Race Intake
-Modified Airbox
-Dalton Clutch Components
02-08-2010, 06:33 PM
Member #8421
My 210 650max xtp back fires when I come on to it and then let off quickly. The only thing I did to it was add a twin air filter.
02-08-2010, 06:46 PM
Member #1382
You may want to check your valve adjustment. Tight intake valves will cause just the symptoms you describe.
02-08-2010, 07:28 PM
Member #8421
they adjusted the valves when they did the first maintenance but i will call them in the morning. thanks!
i know they did something to the computer for cold starts. might have something to do with that.
02-08-2010, 07:54 PM
Member #4130
tight intake valves would also cause a rough idle and hard starting.
08 gade 800
-800vtwin.com ECM
-Koso Display
-50mm tb
-Race Intake
-Modified Airbox
02-08-2010, 09:56 PM
Member #8421
So you think the twin air filter is ok to have in there?
