Comet Clutch Removal? - Can-Am ATV Forum
This is a discussion on Comet Clutch Removal? within the Can-Am Outlander forums, part of the Can-Am ATV Discussion category; How are you guys with the comet clutch setup removing it? I have never had mine off since installing it and need to take it ...
Old 04-10-2010, 08:52 AM
Member #6403
View Seat Deep's Photo Gallery(0)
How are you guys with the comet clutch setup removing it? I have never had mine off since installing it and need to take it off to do some back clutch cover repair. Thanks in advance.
If you don't stand behind our troops feel free to stand in front of them!!
2007 Can Am Outlander 650 XT Camo
Full Ricochet Skids
Renegade Foot Pegs
Gorilla Axle Stage 1 lift
Gorilla Axle Radiator Relocation Kit
Engine Ice
Fully Snorkeld 2"
09 Intake and Filter
B&M Oil Cooler
MrRpm Oil Cooler Adapter
MrRpm 51mm Throttle body
MrRpm Comet Clutch Setup
STM Clutch Weights
HPD and Dalton Clutch Springs
Hmf Swamp series XL
Dynojet Power Commander III
30" Silverbacks on Itp SS112 14" rims
2008 Can Am Ds 450X
K&N Airfilter, Outerwear Prefilter
2007 Honda CRF 50F (6 year old Sons Ride)
Old 04-10-2010, 09:09 AM
i've always just used a big ass bolt that fits the threads and a steel rod. next time i'm going to try packing it with grease or soap or whatever and popping it off through they hydraulic pressure.
Old 04-11-2010, 01:58 PM
Member #6403
Thanks Brian i thought maybe a differant puller would work but the bolt and steel rod will do the the trick and is lots cheaper so thanks again.
Full Ricochet Skids
Renegade Foot Pegs
Engine Ice
Fully Snorkeld 2"
B&M Oil Cooler
STM Clutch Weights
Hmf Swamp series XL
2008 Can Am Ds 450X
Old 04-12-2010, 10:51 PM
Perf Tuners
Member #2653
View john cannon's Photo Gallery(0)
Brian
I tried pulling mine this weekend with no success. Dang thing is freaking stuck. I know for a fact that stupid thing was not turning on the shaft. I am going to have to back up and punt on this one. I need a monster impact.
John Cannon
www.MUDandDIRT.com
www.YouTube.com/mudanddirt
MaD MotorSports
ATV EFI Custom Tuner
Powered by www.MrRPMcycle.com
Outlander X, MrRPM 1004cc, BRP Race TB/ECM, STM, Fasst, Precision, AC, Muzzy
Perf Tuners
Member #2653
Have you ever put heat on it??
John Cannon
www.MUDandDIRT.com
MaD MotorSports
Old 10-01-2010, 11:54 AM
Member #4626
View karistep's Photo Gallery(0)
Could someone explain me how to remove the comet STEP by STEP ?
Commander 2012 LTD
Old 10-01-2010, 03:42 PM
the most fool proof way to remove it is to get a bolt that is threaded for the threads in the clutch shaft. wrap the threads with teflon thread tape. if you have someone who can help you, tip the quad on it's right side, about 45 degrees, then fill the hole in the clutch with water. then thread in the big bolt and let the bike back down on all 4 wheels. then hit the bolt with an impact till the clutch pops off. every single clutch i've come across that has been hard to remove has popped off that way. if you don't have someone to give you a hand, don't tip the bike and just pack the hole with grease instead of water. the grease is just harder to clean up.
john, sorry i missed your reply four months ago. i'm guessing you got it off by now, lol.
Old 10-02-2010, 03:06 AM
Member #4626
I currently just remove main bolt. (1)
Do I need to remove spring and face plate (6) & (7) ?
I have this tool
How to use it ?
Commander 2012 LTD
Old 10-02-2010, 07:58 AM
to use that tool, simply remove the main bolt, apply anti-seize or grease the end of that tool, apply some to the threads (that helps to reduce resistance from them binding up), then thread it into the clutch by hand, once tight, hit it with an impact. if that doesn't get it to pop off, wrap the threads with thread tape, fill the hole in the primary with water or grease (same as above method i posted), then thread the tool and hit with an impact.
Old 10-03-2010, 06:05 AM
Member #4626
Thanks so much Got Wake for your help.
I try everything (I have no impact wrench). I use grease as you mentioned.
Nothing to do. Even the thinnest end of the clutch puller start to twist.
It makes me crazy.
Commander 2012 LTD
comet 20 p3 driven cam removal how to
comet 780 puller
comet 780 removal
comet 94c cover removal
comet clutch disassemble
comet clutch spins trying to remove
how do you get a comet clutch apart
how to disassemble a comet 44 magnum clutch
how to disassemble salsbury clutch
how to remove a comet 102c
how to remove a comet clutch
how to remove a salsbury clutch
how to remove comet clutch
how to remove series 40 clutch
removal of a comet driven clutch
Clutch tech for high hp big motors, Stock, Comet, STM billet mrrpm Can-Am / BRP 109 05-19-2010 01:57 PM
Comet Clutch Down2Ride Can-Am Renegade 41 03-13-2010 06:22 PM
clutch weights for the comet users got wake? Can-Am / BRP 3 08-09-2009 09:01 PM
Pls school me on the Comet Clutch ! X-Devil Can-Am / BRP 24 07-18-2009 10:27 PM
Comet clutch on 800 Rotax mrrpm Can-Am / BRP 26 08-28-2008 03:54 PM
