Outlander won't start - Can-Am ATV Forum
This is a discussion on Outlander won't start within the Can-Am Outlander forums, part of the Can-Am ATV Discussion category; Went to start my 06 outlander and it would just click. This was after just riding it for ten minutes. Cleaned the battery connections, tried ...
Old 04-21-2010, 07:40 AM
Member #9936
View bweyer's Photo Gallery(0)
Went to start my 06 outlander and it would just click. This was after just riding it for ten minutes. Cleaned the battery connections, tried jumping it on the battery and directly, and still just clicking. Probably missing something small, could use some advice. Checked all the fuses also.
Old 04-21-2010, 10:04 AM
gtj's Avatar
gtj gtj is offline
Member #5841
View gtj's Photo Gallery(0)
Here are a few simple things:
Do you have a DSS key/ignition? Have heard they can be a little cantankerous at times. Ever bent? Remove, clean, dielectric grease dab and replace.
Inadvertently knocked the kill switch to off position?
Check shifter in park or neutral. Sometimes shows park or neutral on pod, but not synched at sensor.
Another thread here: No start? 08 800
2009 Outlander XT in Yellow, Snorkeled, Rad Re-Locate, Frame Mod, Ricochet Skids, One-Way Bearing Mod, QSC Clutch Kit, Reverse Mod, PRP Steering Stabilizer, Crutchfield Stage I rear / Stage II frt, Maxxis 28 Zillas on ITP Beadlocks, 30" Gorilla Silverbacks, Renegade Foot Pegs, heated thumb & grips, 2 X 1gal. gasoline / 1 X 1gal. water RotoPax
Old 04-21-2010, 10:35 AM
Member #9070
View Flatlander's Photo Gallery(0)
That click typically is the starter solenoid if the battery is good then it could be the starter going bad. Staters will sometimes act up when they are hot but work when they are cold. This is due to the copper winding starting to develop cracks in them or the solder which expands and breaks the current flow when they are hot; ie 10 minutes after riding. Since you tried jumpers and still just a click it is likley the starter. Wait till it is cool (morning) and try it;if it works. Solenoid could be bad also just tap it with something while turning the switch.
2004 400 MAX
2005 Yamaha Bruin 250
Old 04-21-2010, 11:58 AM
Member #9936
I cleaned the key, moved it around. That seems to be okay. I also thought it was the starter, just hoped it was something else. Thanks for the help.
Old 04-21-2010, 12:55 PM
Member #9661
View snowgoforever's Photo Gallery(0)
Tap on starter with wrench while you crank. I've gone on dozens of wrecker calls where I didn't tow the car due to a few whacks on the starter or gas tank (stuck brushes on starter or fuel pump, respectivily). Short term fix, but at least you know where you stand.
2004 Outlander 400 HO
Old 04-21-2010, 08:04 PM
Member #9936
I tapped on the starter and still nothing. Gonna make sure it's getting power, but I'm sure it is as the solenoid is clicking on and off with the start switch. Looks like I'll be getting a starter.
Old 04-21-2010, 08:50 PM
Member #9661
If you've determined it's the starter, I'd pull it out and hook it directly to your car/truck battery with jumper cables. If she doesn't spin, you know for sure that's the prob before you drop money on a starter. (I believe they're grounded through the bolt tab, so you just clamp the negative jumper cable to the starter housing, positive to the one cable coming off the starter).
Oh, and this should be obvious but I'll say it anyways, be prepared for a few sparks when you make the connection and don't leave it connected for more than a few seconds, especially if it doesn't spin!!!!!)
Old 04-22-2010, 01:02 AM
Member #9936
I'll give it a try. Thanks.
Old 04-22-2010, 11:32 AM
Member #9070
BTW- Tap the back end of the starter were the wires go into the housing, this is where the brushes are. Avoid tapping TOO hard on the side, this is where the premenant magnets are and they will break and lock up the rotor. Done it, payed for it, probably do it again!
2004 400 MAX
Old 04-26-2010, 03:57 PM
Member #9915
View CMICK's Photo Gallery(0)
I'm needing this help as well..............but where the heck is the starter located??
04 mitsubishi outlander will not start
2004 mitsubishi outlander starter location
can am 2016 outlander wont start
location of my mitsubishi outlander 2005 starter
misubishi 2012 outlander won t start
mitsubishi outlander 2004 no start
mitsubishi outlander click click then starts
mitsubishi outlander sport 2014 won't st
mitsubishi outlander starter problem
mitsubishi outlander starting problems
mitsubishi outlander won't start
mitsubishi outlander wont start
my mitsubishi outlander wont start
what will make a 2006 mitsubishi outlander will not start
why wont my 2015 outlander start immobilizer error
07 Outlander 800 No Start Electrical? moorepowersports Can-Am Outlander 6 07-19-2014 01:28 PM
03 Outlander 400 wont start jetsnow Can-Am / BRP 1 12-28-2009 11:08 AM
Outlander 500 HO WON'T Start!! Please Help!! Fenton Quagmire Can-Am Outlander 3 11-13-2009 08:18 PM
Outlander 800 won't start MikeRJ13 Can-Am Outlander 7 06-08-2008 10:20 AM
Outlander wont start aerial Can-Am Outlander 2 05-21-2008 02:47 PM
