battery removel - Can-Am ATV Forum
battery removel
This is a discussion on battery removel within the Can-Am Outlander forums, part of the Can-Am ATV Discussion category; How do you remove the battery on a outlander 500 max. thanks for any help G...
Old 06-29-2010, 06:56 PM
Member #8144
View Little g's Photo Gallery(0)
battery removel
thanks for any help
G
Old 06-29-2010, 07:52 PM
SEXYREX's Avatar
Member #5051
View SEXYREX's Photo Gallery(0)
Unhook the rubber strap, take off the negative lead with a 10mm spanner, lift up battery a bit and pull out towards you enough to undo the positive bolt and remove lead. The battery should now be in your hands. Make sure your connections are tight when you put it back in, as many problems have been known with loose connections.
2010 OUTLANDER 800R MAX LIMITED EDITION
Old 06-29-2010, 08:51 PM
altar1's Avatar
Member #9585
View altar1's Photo Gallery(0)
Since I had the same unwritten question.....
How the heck does one even get a wrench to the negative lead? There just simply isn't enough room. Not to mention the very real possibility of catching your wrench on the positive terminal while trying. Putting a loose negative wire back on would be even worse.
I was able to tighten the positive pole with a small socket wrench (which was loose from the factory), but only after I taped it all up to prevent accidentaly hitting a ground somewhere.
Tom
Mount and Ride
1 Can-am 500 Max XT
3 Yamaha Grizzly's
1 Arctic Cat
1 Yamaha Xt motocross bike
Old 06-29-2010, 09:11 PM
8lander's Avatar
Member #4644
View 8lander's Photo Gallery(0)
I pissed around with the battery strap on my 800 today for about a half hour. Had to run a couple zip ties to hold it on at the back.
The designer of the battery compartment should be fired.
Also the f**knuts that designed the windshield, stator, suspension etc. should help that first guy carry out his sh*t along with there own.
All the rest, carry on.
The battery took more time than installing a PR dampner today but was worth it.
-800XT Outlander
Precision PRO damper
27" XTR's
ITP black 108 SS rims
HM Rad relocate
Dalton clutch kit
Ricochet skids
BRP windshield(winter)
BRP HD front springs
HM threaded preload adjusters
Wes cargo box
- 400XT for the wife and kids
Precision PRO dampner
26" mud lite's.
ITP 4 spoke rims.
Ricochet skids
Wes seat/box
-2005 DS 50
Old 06-30-2010, 09:50 AM
LMAO. Once you get on the throttle makes it all worth it though, eh?
Old 06-30-2010, 10:12 AM
really? problems getting the battery out? it takes all of a minute or two to get it out safely. unless the other motor sizes are different, the negative terminal is supposed to be towards the rear of the bike for easy access. dealers have been known to put batteries in backwards, and i've seen a few people put them in backwards to make it easier to hook jumpers to the positive post. but for jump starting, use the starter relay/solenoid in the back and keep the negative terminal to the rear of the bike.
Old 06-30-2010, 03:56 PM
altar1's Avatar
Member #9585
Mine came with the negative terminal toward the front of the bike, positive toward the rear. I worked for half an hour and couldn't get it out. Maybe I'm just inept. So the starter relay would also be ok for jumping and charging?
Tom
Mount and Ride
1 Can-am 500 Max XT
3 Yamaha Grizzly's
1 Arctic Cat
Old 06-30-2010, 06:47 PM
yup. just make sure to use the side of the starter relay that does not go to the starter. check the battery cable length and see if the negative will reach to the back. i've got my battery sitting on a rolling stool behind my bike and there is plenty of cable to reach it.
Old 06-30-2010, 07:50 PM
altar1's Avatar
Member #9585
Thanks!
Tom
Mount and Ride
1 Can-am 500 Max XT
3 Yamaha Grizzly's
1 Arctic Cat
Old 06-30-2010, 07:59 PM
Member #8144
thanks for all of the help. I am trying to install jumper for battery tender, jumper cables, what ever it could be handy for.
It is a pain to get out. thanks again
G
2007 canam battery removable
2010 can am battery removal
can am outlander battery removal
change 2011 can am battery
change battery in 2008 can am outlander
changing battery on can am 800
how do you change battery in can am outlander 800
how to change the battery in a canam outlander max
how to change the battery on a cam am spyder
how to remove battery from can-am xt500
how to replace battery on 2008 can am spyder gs
how to replace battery on cam am spyder 2012
out lander battery pack remove
outlander 400 atv battery removal
video for battery replacement on 2008 650 outlander
second battery khauger Can-Am / BRP 5 12-24-2008 10:44 AM
Battery ????? cc1999 Can-Am / BRP 36 01-30-2008 03:05 PM
Battery help cgr Can-Am / BRP 39 09-09-2007 06:25 PM
Battery FALCAN Can-Am / BRP 3 06-26-2007 01:41 PM
Need new battery? turboman Can-Am / BRP 5 03-13-2007 12:40 AM
