Question on CVT cleaning with hose in snork
This is a discussion on Question on CVT cleaning with hose in snork within the Can-Am Outlander forums, part of the Can-Am ATV Discussion category; Can I put a hose in my snorkle, loose a couple of CVT bolts and simply flush the CVT to clean it and then let ...
Old 07-12-2010, 08:55 AM
First Name: '07 Outlander 650, Snorkle Your ATV, 26" ITP Rims and Mud Lites, HMF Swamp Series, Hayden controller
Member #8173
View knukey's Photo Gallery(0)
Default Question on CVT cleaning with hose in snork
Can I put a hose in my snorkle, loose a couple of CVT bolts and simply flush the CVT to clean it and then let it dry or will I booger something up?
Old 07-12-2010, 11:50 AM
pikeman's Avatar
Member #6603
View pikeman's Photo Gallery(8)
I guess you could if you don't want your clutch to last long. Just take the cvt cover off and clean it, and lube your one way bearing is the best bet, that way you can inspect things at the same time. Only takes about 2 minutes to get your cover off.
07 Outlander Max 500
27" Zillas on ITP SS212
Dir 2 Overfenders
Frame mod/ xt front bumper/strut spacers
Viper max 3500/syn rope
HMF Swamp series/with ceramic coated headers
Uni air filter
xmr cvt exhaust and pod
Old 07-12-2010, 12:07 PM
that is how you check for leaks, not for cleaning the clutches. take the cover off and clean it properly to get the grit and grime off it, then lube the one-way and friction washer. just don't use cleaners that cause oxidation on aluminum like purple power, greased lighting, or any other really harsh cleaners. LA's totally awesome from the dollar store is what i use for cleaning everything and won't oxidize the aluminum unless it is left on for a really long time.
can-am cvt clutch clean lube
clean cvt clutch
cleaning cvt clutches
cleaning cvt xlutches
cvt cleaning can am
how to clean can am cvt
how to clean can am renegade cvt clutch
how to clean cvt
how to clean cvt can-am
how to clean cvt for atv
how to clean outlander cvt clutch
outlander cvt cleaning
what do you clean a cvt with
what is the best lub for cvt clutch
what to do if you get water in cvt outlander
Couple new snork pix. TorkMonster Can-Am / BRP 11 02-27-2010 02:12 AM
Some Stealth Snork Observations. Better Than stock BUT! rkc05 Can-Am / BRP 7 05-27-2009 07:00 AM
radiator hose/oil hose raven Can-Am / BRP 4 10-22-2008 09:32 PM
Pics of snork, temp gauge and a question about some wires. 800BOMBCAMO Can-Am / BRP 22 05-31-2006 11:07 AM
Rad Hose ID Traxterman Can-Am / BRP 1 04-17-2006 04:34 PM
