08 650 outlander PROBLEMS!!! - Can-Am ATV Forum
This is a discussion on 08 650 outlander PROBLEMS!!! within the Can-Am Outlander forums, part of the Can-Am ATV Discussion category; :th_smilie pullhair: My 2 month old atv runs great for a hour or so and then get hot and will start hesitating and sputtering so ...
Old 07-20-2010, 09:35 PM
Member #11084
View toolmn's Photo Gallery(0)
Exclamation 08 650 outlander PROBLEMS!!!
:th_smilie pullhair:My 2 month old atv runs great for a hour or so and then get hot and will start hesitating and sputtering so bad that you can hardly go anywhere. No warnings come on the speedo... I have drained the tank checked the check valve, looks like pump and filters are fine. It only happens after the bike gets warm and it seems like the fan stays on for a good while b/f cutting off. Radiator seems good, no mud in it and full of fluid. I can let the atv sit for 30 min and it will run fine until it gets hot again. Any help would be greatly appreciated. The local dealer won't honor the 3 yr warranty b/c i have 30s on it and its snorkeled...
Old 07-20-2010, 10:36 PM
OSOKILL's Avatar
prolly has a clocgged filter sock on the pump its self will have to pull the tank to tell for sure.... you tested the reg fuel filter correct
www.commanderforums.org
www.atvblog.net
Old 07-21-2010, 10:06 AM
Member #11084
The reg filter looks good, going to pull the tank today and check the fuel pump filter...thanks
Old 08-10-2010, 07:47 PM
Can-mam's Avatar
Member #9051
View Can-mam's Photo Gallery(0)
Same thing happened to my 2010...'cept the engine light came on and it went into limp mode. Same symptoms though...Wound up being a faulty map sensor. Good luck!
Sandy
"Bear" with me, folks...I'm new at this!
2010 Outlander Max 650 XT-P
Old 08-10-2010, 10:48 PM
Col.'s Avatar
Member #3575
View Col.'s Photo Gallery(0)
Fuel pump not holding pressure? I've heard people talking about the same symptoms and it was their fuel pump.
08 650xt Ricochets,stealth snorkel, Black ITP C series, 27" Outlaws, HMF Utility, RDC 2" lift.
Old 08-10-2010, 10:51 PM
Col.'s Avatar
Member #3575
Sorry didn't see that this was an older post. Did you get it fixed? What was the problem?
Old 10-15-2010, 04:13 PM
Wy Can Am's Avatar
First Name: '08 Outlander Max XT, '07 Outlander Max XT, '06 Rally
Member #12556
View Wy Can Am's Photo Gallery(0)
I have an 800 outlander max xt and have had the same problem. We would ride about an hour and the machine would go into limp mode. After two trips to the shop the radiator was replaced (old one collapsed) and a new radiator cap was installed. This problem started with less than 200 miles on the machine. Be advised that nothing showed up on the computer when the machine was diagnosed at the shop. I think the new radiator is a 2010 model, the mechanic said that it has better flow compared to the old radiator. So far, the machine is running a lot cooler and has not gone into limp mode. Going elk hunting this weekend, should be a good test. Hope this helped.
Old 10-16-2010, 05:34 AM
Can-mam's Avatar
Member #9051
Mine is STILL having issues! There is a lengthy post on another forum on what they are saying is wrong with mine now.ATTN 2010/2011 can-am owners - can-am ATV Forums - can-amtalk.com And it seems to be an issue with many as more and more people read this post and check their own machines.
Sandy
07 canam outlander max 650 trouble shooting
08 can am outlander max
2008 can am outlander 650 xt problems
2008 can am.outlander 650 engine issues
can am 650 atv problems
can am 650 outlander max issues
can am 650 outlander problems
can am 650 problems
can am 650 xt problems
can-am 650 problems
common problems with the can am 650
outlander 650 problems
problems with 650 can am outlander
starting procedure for 2007 can-am outlander 650 xt
Problems w Outlander 800 bschauf Can-Am Outlander 9 08-22-2010 07:25 PM
07 800 outlander fan problems jeffriverrat Can-Am Outlander 0 12-03-2009 06:46 PM
'06 Outlander Problems northernguy Can-Am Outlander 3 03-11-2006 06:23 PM
Outlander Problems darrell5 Can-Am Outlander 26 12-22-2005 12:00 AM
Problems w Outlander 800 bschauf Please Introduce Yourself 0 12-31-1969 07:00 PM
