400 coil - Can-Am ATV Forum
post #1 of 13 Old 07-21-2010, 11:45 PM Thread Starter
400 coil
any one know wat the resistance valus for the ignition coil on the 2007 400 xt? think mine is causing all my troubles
roborider is offline
post #2 of 13 Old 07-21-2010, 11:46 PM
OSOKILL's Avatar
whats yer bike doing?
www.commanderforums.org
www.atvblog.net
OSOKILL is offline
post #3 of 13 Old 07-22-2010, 07:40 AM Thread Starter
well .. its runnjin fine when its cold or warm , when it gets hot .. like goin up a hill under hard throttle .. it dies like it runs out o gas, let sit for a while till it cools a bit then your off again for a bit then dies.. back firs out the exhaust. some times need full choke jus tto start it.
post #4 of 13 Old 07-22-2010, 09:46 AM
OSOKILL's Avatar
has a fuel pump in the tank???? pull the tank and check the filter sock on the pump sounds like its clogging up =]]
www.atvblog.net
OSOKILL is offline
post #5 of 13 Old 07-22-2010, 02:38 PM
A 2007 will be carburated, check the fuel lines for dry-rot above the valve cover. Check the fuel on/off/res switch for proper flow (mine only works on reserve).. Check and/or clean the carb. Check and /or replace the tank fuel filters (behind the tank grommets)
backfiring and having to use the choke tells me you have a lean fuel condition.
GYPSY 400
Possibly the O-400 Guru??!
Outlander 400 Information Center
GYPSY400 is offline
post #6 of 13 Old 07-22-2010, 04:08 PM
OSOKILL's Avatar
isnt the gas tank in the same place ... under the seat???
www.atvblog.net
OSOKILL is offline
post #7 of 13 Old 07-22-2010, 04:17 PM
token's Avatar
If it's carbed and starts acting up when it gets real hot, it might be getting vapor lockkked
*Ricky Bobby drives a Can-Am*
2009 Outty 800R XT Camo
Gorilla Edition ITP SS108 Wheels
30" SILVERBACKS
QSC clutch --------- HIDZ
Full Muzzy
Wild Boar Relocate
PCIII Tuned by JOHN CANNON
Flexx Bars
TOO MANY OTHER MODS TO LIST OMG.
token is offline
post #8 of 13 Old 07-22-2010, 04:33 PM
OSOKILL's Avatar
it still has the fuel tank strainers in the tank ... says you have to pull the tank and remove gromet 14 and I am betting its clogging up
www.atvblog.net
OSOKILL is offline
post #9 of 13 Old 07-22-2010, 06:35 PM Thread Starter
far as i know i dont have those strainers .. so i have put inline filters on
post #10 of 13 Old 07-22-2010, 11:54 PM
Perhaps this is your problem.. As you will have those strainers in the tank.
GYPSY 400
GYPSY400 is offline
What size heli-coil for drain plug? BRPFan Can-Am Outlander 4 09-05-2009 05:11 AM
No current going to coil. elliemaio Can-Am / BRP 0 09-04-2009 08:02 AM
shock coil spring rate for renegade x??? raven Can-Am Renegade 1 11-10-2008 06:34 AM
Re-coil for 49cc mini chopper BAJA X Other Toys 4 06-14-2006 11:25 PM
