RAtcheting sound coming from front end
This is a discussion on RAtcheting sound coming from front end within the Can-Am Outlander forums, part of the Can-Am ATV Discussion category; As you can see, the red line that connects the two ears on the driveshaft is parallel to the entire shaft all the way down ...
Old 09-23-2010, 07:25 PM
Member #4004
View OuttyUpfront's Photo Gallery(0)
Default Photos are worth a thousand words...
As you can see, the red line that connects the two ears on the driveshaft is parallel to the entire shaft all the way down (well, pretty close, I just threw it in). This is a properly "phased" driveshaft.
And the red line here is somewhat diagonal to the shaft length. This driveshaft is "Out of Phase" and will result in chatter in the driveline.
Edit: I have no idea what this driveshaft is for, but the images showed exactly what I wanted to display.
The Following 4 Users Say Thank You to OuttyUpfront For This Useful Post:
klub222 (09-23-2010), rkc05  (09-23-2010), WilliamBos (09-23-2010), WiNdGaDe800 (03-25-2012)
Old 09-23-2010, 07:34 PM
View rkc05's Photo Gallery(430)
Cool pics. Tks.
2013 Outy 1000 Max XT, 29.5 Gen2 Laws, STI-HD 14" Beadlocks,1-1/4" pipe lift, Dalton 1000 Mud Kit, BRP Chassis skids and a mirror.
  #13
Old 09-23-2010, 07:42 PM
WilliamBos's Avatar
Member #10836
View WilliamBos's Photo Gallery(0)
Quote: Originally Posted by OuttyUpfront View Post
make sure that if you had the driveshaft out, you got it put back together and alligned properly - if the shaft was out, you should be able to lay it so that the joint yokes are perfectly aligned, IE, if one ear against the floor and the other straight up, the other end of the shaft should be exactly the same... if even one or two splines off, the sounds you told us about will be there.
What he said!!
Thanks,
Will
  #14
Old 09-23-2010, 07:44 PM
WilliamBos's Avatar
Member #10836
Thank you!!
Thanks,
Will
  #15
Old 09-23-2010, 07:45 PM
Member #4004
Quote: Originally Posted by oscaregc View Post
hi, am new and have the same problem, can you explain again and slooooow how to align the shaft (front and back) . thanks
The photos above should give you a great idea on the alignment of the rear.
As for the front, there is only one u-joint so to speak... the reason they can get away with this is that the driving shaft and the driven shaft are practically straight in line and parallel - When this happens, there is very very very little change in the ear placement in their rotation so effectively keeping the "growing and shrinking" of the shaft mentioned earlier from happening.
So there is no alignment required on the front.
On a side note......As the angle bettween the driving shaft and the intermediate shaft increases, the speeds (due to ear placement along their rotation) begin to change and the alignment of the u-joint yokes (two as with the rear driveshaft) becomes ultra important.
  #16
Old 08-16-2011, 08:24 PM
cammedouthamlander's Avatar
First Name: old school beerdrinker
Member #14267
View cammedouthamlander's Photo Gallery(0)
Just ran across this old post and too late. I'm sure thats what I did {wrong clocking alignement} when I put shaft back together when it separated after a major crash. I ran bike on jack and noticed shaking,looked like bent drive shaft so I bought a new one for $350.00.Put new on and solved the shake,but couldn,t figure out why old one visually looked straight. Just dug up old shaft and it was clocked wrong,at least I didn't throw it away. Costly mistake so maybe this will help others remember when changing U-joints,ALIGNE SHAFT!!!! Or you'll wind up with a $350.00 spare shaft like me!
  #17
Old 09-01-2011, 08:47 PM
Member #4004
Awesome that you now have a spare shaft... bummer that the spare shaft cost you $350.
I'm glad to hear that others still benefit from this post.
  #18
Old 11-08-2012, 09:09 AM
First Name: married father of five
Member #21254
View jolytre's Photo Gallery(0)
thanks you just saved me some $$$$$$$$$$$$ it's nice to see people will to spread their knowledge :th_smilieth umbsup:
atv ratcheting sound
outtyupfront phase
ratcheting sound in front
pipe sound Gibson Can-Am / BRP 26 03-02-2010 09:16 AM
ratcheting when breaking grass boy Can-Am Renegade 14 08-25-2009 06:20 PM
Metal on metal ping sound coming from rear suspension area, help please!! mrclark Can-Am Renegade 19 06-27-2009 01:56 PM
chirping noise coming from front right tire? 08canam ATV Tires and Wheels 31 12-08-2008 08:53 PM
"Ratcheting" noise from rear end when braking? echoffmann Can-Am / BRP 3 08-21-2006 04:14 AM
