Outy 400 - Runs good, gets hot dies, cools off runs good again - Can-Am ATV Forum
This is a discussion on Outy 400 - Runs good, gets hot dies, cools off runs good again within the Can-Am Outlander forums, part of the Can-Am ATV Discussion category; '06 Outlander 400, starts fine and runs fine. After running through sand at low RPM for about 15 -20 minutes it dies, sounds like it ...
Old 10-09-2010, 09:38 PM
Member #10136
View msumrall's Photo Gallery(0)
'06 Outlander 400, starts fine and runs fine. After running through sand at low RPM for about 15 -20 minutes it dies, sounds like it is running out of gas. Will not restart unless I full choke it but it won't keep it running for more than a few seconds if I give it any throttle or turn off choke. Let it sit for about an hour and it started and ran for about 30 seconds then the same thing happened. Once I tow it back to the trailer and get home (about an hour and a half more) it will start and run just fine again. The valves are fine, fuel is clean, and I ran a large dose of seafoam through it last weekend when this occurred the first time. I have no ideas since it will start and run fine when cold and not run at all once it gets hot. Any ideas would be appreciated.
Old 10-09-2010, 09:46 PM
WilliamBos's Avatar
Member #10836
View WilliamBos's Photo Gallery(0)
Quote: Originally Posted by msumrall View Post
'06 Outlander 400, starts fine and runs fine. After running through sand at low RPM for about 15 -20 minutes it dies, sounds like it is running out of gas. Will not restart unless I full choke it but it won't keep it running for more than a few seconds if I give it any throttle or turn off choke. Let it sit for about an hour and it started and ran for about 30 seconds then the same thing happened. Once I tow it back to the trailer and get home (about an hour and a half more) it will start and run just fine again. The valves are fine, fuel is clean, and I ran a large dose of seafoam through it last weekend when this occurred the first time. I have no ideas since it will start and run fine when cold and not run at all once it gets hot. This is my wife's machine and she insists I talk to somebody "who knows something" and "fix it" before she will go out again. Any ideas would be appreciated.
Just a guess here, carb issue?? How many miles??
Thanks,
Will
2012 Sportsman 400HO - 5,800 KM and counting.
25" Traxion Grippers Warn RT 25, Warn Hawse Fairlead, Synthetic Rope, Glacier III plow.
Polaris HD Front coils
Kolpin Rear Trail box with L&R Mounts.
Old 10-09-2010, 10:22 PM
Member #10136
It has about 1400 miles on it. It had about 1050 when we got it in the spring.
Old 10-09-2010, 10:24 PM
Camcrazy's Avatar
Member #6784
View Camcrazy's Photo Gallery(12)
The fuel system could be vapor locking or the fuel pump could be bad. It sounds more like a fuel pump issue since it runs fine when it is cool than when it heats up it sounds like the engine is starving for fuel. I always start looking for the cheaper fix than work up to the more expensive things. Or just take it to a dealer and hope for the best! Good Luck!
07 Outlander 800 Max Red
27" Bighorns
2" Lift kit
Garmin 76GS
3000lb. Gorilla Winch
UNI Air Filter
Old 10-09-2010, 10:42 PM
Member #10136
How do you fix the vapor locking thing?
Old 10-09-2010, 11:03 PM
akguppy's Avatar
Member #11603
View akguppy's Photo Gallery(0)
You can try insulating your fuel line from the tank to teh carb. Check the routing too, previous owner could have re-routed it too close to teh exhaust. But, I really don'w think this is what is wrong. If the fuel is "vaporizing" in the line, the rubber fuel line would probably fail. You might check your rectifier and voltage when hot.
Old 10-09-2010, 11:12 PM
Hampster rancher's Avatar
Member #8316
View Hampster rancher's Photo Gallery(0)
Check your gas cap. If the vent in it is not working properly it won't get fuel fast enough to fill the carb. As you run it it will drain the bowl and take a while to re-fill.
Just try running it with the cap off, see what it does.
We ran into this on 2 different machines on our last ride.
TEAM RDC #72
'09 RENEGADE "X", GenII RDC lift, Rhino axles in the back, 30" Silverbacks on 14" RDC Aluminum SwampLoX, CooksMills Custom front bumper, RDC Rad Re-locate bracket, RDC Blade gas cap, QSC
Old 10-10-2010, 03:51 AM
Hot Fuzz's Avatar
Member #11659
View Hot Fuzz's Photo Gallery(0)
I do not know if this will work or not, but run it until it starts running rough then open your gas cap. If it works then you know the vent is bad on your cap. It is hard to believe that your fuel is vaporizing before it makes it to the carbs as it would have to be really hot for this too happen... as in your engine overheating. Let us know what you find!!
Hot Fuzz
2010 500 Maxx XTP
2011 800R XTP
"Semper Fidelis" - Alway's Faithful
Old 10-24-2010, 10:55 PM
Member #10136
Seems like the problem was confined to the fuel pump. I replaced it and no more problems. THanks for all the support.
1998 artic cat 454 atv runs fine for 5 mintues than fouls the spark plug
2002 polaris 325 magnum died
2005 suzuki eiger 400 when gets hot shuts off
2007 yamaha exploring edition wont run after getting hot
600 sportsman sputters then dies
97 bearcat 454 quits running
arctic cat atv won't start when hot
atv gets hot and dies, does not want to start till cool
dvx 400 starts then dies
honda four wheeler running and shuts off
honda trx350 won't run when warm
kfx 450 runs good for a cupple minutes then cuts off
my 4wheeler turns off when hot
what will cause my artic cat 400 to start and run for five minutes then die and not fire for a few minutes
why does my 4 wheeler stop running when it gets warmed up?
Runs only with Choke open Avalanche Can-Am Outlander 4 10-29-2009 07:35 PM
Missouri Mud Runs Seat Deep Rides and Events 8 05-14-2009 10:57 PM
Who runs 10w-40 racer742 Can-Am / BRP 20 10-31-2008 02:04 AM
Jeep Runs Over Va. Man While He's in Bed outlandish Weird, Bizzare or Just Plain Stupid 2 03-22-2007 08:55 PM
Boy, 11, OK After Truck Runs Over His Head killswitch_1 Weird, Bizzare or Just Plain Stupid 1 01-12-2006 02:18 PM
