Coolant leak - Can-Am ATV Forum
post #1 of 6 Old 10-27-2010, 02:43 PM Thread Starter
Coolant leak
Allright I got a coolant leak now on my outty I've checked he coolant lines and nothing seems to be wrong, but there was coolant all over the snow and some on the engine. where do you think the problem could be? Would it be a big fix if it was the radiator? This happened about a week ago and I've been too scared to run it since.
riderforlyfe is offline
post #2 of 6 Old 10-27-2010, 03:09 PM
RORER-714's Avatar
let it sit in one spot running and see where it drops from and follow that back.
\'06 Outlander 800 Camo,2" Snorkeled,HMF,Crutchfield 1&2 Extreme's,28" 589's
\'07 Renegade 800,Snorkeled,27" Executioners
RORER-714 is offline
post #3 of 6 Old 10-27-2010, 03:34 PM
gbroad23's Avatar
What kinda outy do you have? I would assume weeping hole on back of water pump. It's warranty if you still have it. I read somewhere that if it is to small to find a guy put a small piece of cotton over his weeping hole to find out that thats where it was coming from.
gbroad23 is offline
post #4 of 6 Old 10-30-2010, 06:43 PM
check
the weephole if it's pre-08'. Its at the water pump. Had the weephole upgrade?
'07 Outlander 650, Snorkle Your ATV, 26" ITP Rims and Mud Lites, HMF Swamp Series
knukey is offline
post #5 of 6 Old 10-31-2010, 05:45 AM
It helps to know what year the quad is,..does it have the new reservoir tank/cap. Does it leak standing still or just when running. Happened just once? Could be many different points of leakage, bleeder screw, hose clamp, weap hole, rad cap, simply got hot and "burped" a little coolant.........and then the worse case scenario......crack in block/case.
QUADAHOLIC is offline
post #6 of 6 Old 10-31-2010, 06:17 AM
Camcrazy's Avatar
I haven't heard about the new reservoir tank/cap? Does this affect the 07 Outlander Max 800? And did someone ask if it was pre-08 year and if so was there a recall?
07 Outlander 800 Max Red
27" Bighorns
2" Lift kit
Garmin 76GS
3000lb. Gorilla Winch
UNI Air Filter
Camcrazy is offline
coolant leak daveyboy241 Can-Am Renegade 7 01-04-2011 02:06 PM
coolant leak blevinsbulldog Can-Am / BRP 17 02-08-2009 11:06 AM
COOLANT LEAK renegade 1382 Can-Am / BRP 10 02-06-2009 04:29 PM
coolant leak renegade 1382 Can-Am / BRP 5 01-03-2009 07:51 AM
brp 800 coolant leak sunrise Can-Am / BRP 5 03-15-2006 04:27 PM
