Tryin to pull the headlight bulbs out!
This is a discussion on Tryin to pull the headlight bulbs out! within the Can-Am Outlander forums, part of the Can-Am ATV Discussion category; Got some aftermarket bulbs for the wheeler, but havin trouble takin the stock bulb out. Dont wanna break nothin. How do they come out?...
Old 04-17-2011, 04:28 PM
First Name: Fun and fun
Member #14777
View Cananimal10's Photo Gallery(0)
Default Tryin to pull the headlight bulbs out!
Old 04-17-2011, 04:55 PM
First Name: Loves mud
Member #13765
View Sasq40's Photo Gallery(0)
On mine there was a little tap on the inside of the light you had to press inward then down and it released the bulb. O and the get to the bulb there was just 3 screws
Sent from my iPhone using Tapatalk
Old 04-17-2011, 04:59 PM
kleinbus's Avatar
Member #8848
View kleinbus's Photo Gallery(0)
1) Unscrew the plastic rim on outside that holds the rubber boot sealeing the bulb opening.
2) Move rubber boot back
3) Remove the harness socket from bulb
4) Release the spring clip securing the bulb ( I use longnose pliers to move the tip of locking tab towards the bulb body )
5) Remove the bulb
6) Assembly in reverse order
fear is temporary, regret is forever
Old 04-17-2011, 05:08 PM
SEXYREX's Avatar
Member #5051
View SEXYREX's Photo Gallery(0)
Unscrew the three small screws at the back of the light to remove the cover. Pull off the rubber seal, push the retaining clips in at the bulb connector and pull the wire connector off the bulb. There is a wire clip holding the bulb in. Hold the end of the wire with the curl on it and push inwards then unhook it from the housing. Easy, really, put some light on it so you can see what to do.
2010 OUTLANDER 800R MAX LIMITED EDITION
Old 04-17-2011, 05:26 PM
Canuck75's Avatar
Member #6500
View Canuck75's Photo Gallery(0)
do the right side first and you will see how the clip holds the light in
Mine: 2007 Can-am Outlander 800
28" Zilla's on SS212's / Dalton DBO 800 kit / BRP HD springs / BRP Fender Flares / BRP Full Skid Plates / BRP Stealth Snorkels / Front and Rear XT Bumpers / 3000lb Warn Winch / PowerMadd hand guards / Uni filter / Moose Grip and Thumbwarmers / Gade Footpegs / Quadrax Cargo Trunk
Hers: 2007 Can-am Outlander 650XT
27" Zilla's / BRP Steath Snorkels / Uni Filter / Quadrax Cargo Trunk
Old 04-17-2011, 05:32 PM
Member #14777
Thanks for the help guys!
Old 04-18-2011, 09:54 AM
Member #15311
View 2011Blue's Photo Gallery(0)
What kind of bulbs are you putting in?
Old 04-18-2011, 02:03 PM
SEXYREX's Avatar
Member #5051
The stock bulbs are 35 watt. There is a selection of H4 car bulbs which are 65 watt and give off much more light.
Old 04-18-2011, 05:51 PM
res2cue's Avatar
Premium Member
Member #15621
View res2cue's Photo Gallery(8)
OK they might be brighter but how much heat do they throw? if putting in the bigger bulbs!
2005 Bombardier Outlander 400 H.O. XT
Old 04-18-2011, 06:32 PM
Member #14777
They are called Xentec h4 bulbs. They are an automotive type bulb. I have them installed but i had to do a lil of my own engineering to make it work. I hope no water gets to the bulbs! I put a bunch of silicone on the rubber covers. They wont get to hot because of the ballast that come with the kit. Ill try them out tonight
Tags
bulbs, trouble
06 bombardier outlander headlight
07 can-am outlander 800 headlight bulb
2005 can am outlander 400 headlight bulb
2005 can-am outlander 400 light bulbs
2006 can am outlander 400 tail light bulb
2008 can am outlander 400 headlight
2009 can am outlander 800 light bulb
2011 can am outlander 800 headlight bulb number
bombardier atv headlight bulbs
bombardier atv light bulb
can am outlander 400 headlight bulb swap
how to get a headlight bulb out of a atv
lights bulb for bombardier 2005
replace headlight on atv bombardier
types of headlights for outlander
LED headlight light bulbs Lunytech Can-Am Outlander 4 01-13-2012 02:46 AM
ds 450x headlight bulbs tunman450x Can-Am DS 0 10-07-2010 07:06 PM
Results: 35W Headlight Bulbs Upgrade to 55W on 800 Half Stuck Can-Am / BRP 45 07-23-2009 06:12 PM
taillight bulbs going bad? ytsouttymax Can-Am / BRP 18 05-12-2008 07:41 PM
new bulbs push4racing Can-Am / BRP 9 08-15-2006 06:00 PM
