You'll have to loosen up the front differential and slide it foward. Then remove the bolt holding the U-joint to the thru shaft. Then slide the driveline apart and re-install the boot on the removed half. Then when you re-install the driveline you then install the other half of the boot on the part of the driveline that is on the differential. Then re-install the driveline and differential and go ride.
'08 Renegade 800, Full HMF, Mr.RPM cams, PC5-dual tune w/LM-2, 09 intake, EHS lid, full ricochet skids, Warn 2500xt, Symtec hand/thumb warmers, CVtech primary, STM secondary
'07 Outlander 500 XT, Richochet skids, Symtec hand/thumb warmers, Gorilla winch, CVTech modded secondary, 2000 miles
'10 800 Summit 154 Hillclimb-clutched/piped
'09 600 Etec Summit 146
'03 CRF 450
CVtech-Airdam dealer, Amsoil dealer
Klim/HMK dealer
WPS/Parts Unlimited dealer
Custom metal fab
