Coolant bleed valve gasket - Can-Am ATV Forum
post #1 of 11 Old 10-01-2011, 09:49 PM Thread Starter
kmb760's Avatar
Just wondering if any one has a problem with the bleed valve screws not tighting down enough. I seem to have one that feels like it is stripped inside the plastic housing. I dont see coolant leaking but I also dont want any air bubbles to creat in the system.
Has any one found a solution to this kind of a problem, like is there different gakests then those green paper wax feeling ones or does any company make a aluminum housing to have a real bolt and cooper gasket?
Kevin
2009 Outlander 840, Dual Muzzy, Auto Tune, K&N Filter, CV-Tech Primary, STM Secondary......
RYR
kmb760 is offline
post #2 of 11 Old 10-01-2011, 09:51 PM
camlaw's Avatar
Kevin
i used a small o-ring,,
2010 can am 800 max xt-p,,26" mst's on black 212 rims
camlaw is offline
post #3 of 11 Old 10-01-2011, 10:05 PM
christisk's Avatar
I, for one, have not had that problem
christisk is offline
post #4 of 11 Old 10-02-2011, 11:09 AM Thread Starter
kmb760's Avatar
Kevin
like a small rubber O-ring?
RYR
kmb760 is offline
post #5 of 11 Old 11-06-2011, 12:36 AM Thread Starter
kmb760's Avatar
Now when I try to tighten the screw it just keeps spinning and after a ride I can see some moisture around the housing. Im really hoping the air isnt going into the system to keep get an air pocket at the water pump.
RYR
kmb760 is offline
post #6 of 11 Old 11-06-2011, 04:34 PM
HVACGUY's Avatar
I had this problem. I installed a small heli coil in the stripped out hole and then found some steel flat washers at Home Depot that had a rubber gasket molded on one side. A stainless steel bolt for the plug completed the assembly. End of problem forever.
Eric
2003 Bombardier Outlander 400
Viper Max 3000
ITP Terra Cross Tires
ITP Wheels
HVACGUY is offline
post #7 of 11 Old 11-06-2011, 08:31 PM Thread Starter
kmb760's Avatar
thats a great idea using the heli coil, thanks.
RYR
kmb760 is offline
post #8 of 11 Old 03-19-2012, 08:25 PM Thread Starter
kmb760's Avatar
Has any one else tried to solve this issue. Its seems like the plastic just crubles away when you try and tighten the screw down. I tried using a rubber gasket with no luck and im thinking of expirementing with a aluminum heli coil and one of the spare stripped housings.
RYR
kmb760 is offline
post #9 of 11 Old 03-20-2012, 12:11 PM
albertrock's Avatar
I am experiencing the same issue, so may i ask what this aluminum heli coil is and where can i purchase it?
albertrock is offline
post #10 of 11 Old 03-20-2012, 01:16 PM Thread Starter
kmb760's Avatar
Its threaded inside and out that way the helicoil stays in the plastic housing and then the new bolt screws inside the helicoil. This way the bolt threads into aluminum and not the plastic that just crumbles apart.
RYR
kmb760 is offline
ds650 oil bleed screw 00ds650 Can-Am DS 3 12-16-2011 01:13 AM
Tech Question - Too Much Oil Lead to Valve Cover Gasket Leak? gtj Can-Am / BRP 8 01-19-2011 07:36 PM
Need a gasket!!!! lapoolboy Can-Am Outlander 1 11-11-2010 04:58 AM
gasket kit canadian can am ATV Tech Tips 4 09-19-2010 03:00 PM
head gasket for 840 lunatic Can-Am / BRP 21 05-30-2009 12:54 AM
