01-21-2012, 07:44 AM
Here's Johnny!
Member #3196
Been running dual PC545's for 3 years…no problems.
01-21-2012, 08:21 AM
Member #19504
A snatch block reallly reduces stress on the winch motor, thus needing less power to pull. You should also do small pulls at a time, letting the battery recover and the winch motor cool. There is also a discussion on here about using a trickle charger or battery maintaner when your not riding. Just a thougt, its always nice knowing that you left for your ride with a fully charged battery to start with. I just bought a Warn recovery kit like the one inthe BRP catalogue. it has a snatch block, shackles and some traps, nice kit and small enough to have on board.
2012 Max XT with XMR snorkle kit.
Ricochet Skids, Pitbull Growlers, STI HD2SE Wheels.
2012 DS 250 for my son
01-21-2012, 08:23 AM
This is the voltage gauge I use. It works very well in a Renegade due to it swiveling, not sure on the Outlander, their are other style's of them that may work better aswell.
01-21-2012, 08:26 AM
First Name: Gerry
Member #11457
most of the specs of the winches I have seen (2500-3000 cap) have a current draw between 100 and 150 amps with a 2/3 load. The battery on your atv is not going to take it for long. Use a pulley, rev the engine up around 3500-4000 rpms, winch in short bursts.
Add an additional battery. Keep it plugged into a battery tender so it is ALWAYS fully charged when you go out on a ride. I plowed for over an hour the other night - 9degrees by following the advice above. No limp home at all. I have only had the limp home 2x in 4 years (OEM original battery) once when I ran the winch for a long time at idle and one time plowing with the headlights on.
Cold is murder on the battery also, but not much you can do about it.
08 Renegade 800
Viper 3k Winch
Tusk 60" Plow
D2 Overfenders
Rene1 Performance Mud Flaps
PRM ATV Rear Rack
ITP SS212's
26" BigHorn 2.0's
Can Am Skids
Delorme PN-30 GPS/SPOT Emergency Locator
Stealth Snorkels
Hayden Fan Controller
From the hills of SW VA....
01-22-2012, 11:31 AM
Member #11010
Man, I must have been flat lucky because I've been plowing/winching with my headlights on, auxilory lights AND hand warmers... What I'm reading makes sense, I'll kill the cool looking extra lights, maybe the regular lights, but have to keep those hand warmers going!!!
2010 650 XT Max
03-03-2012, 12:24 PM
Member #9419
Quote: Originally Posted by eagle jeeper
Thanks Wow 6000 rpms. That just seems wrong but if it works i ll try anything right now. I think i m going to look into the Odyssey battery. I have been doing some searching and there is the possibility of dual batteries but there seems to be some debate about how to properly set it up.
Hi..in the end what solution u did ? thx (I have a 2009 max out 800r xt with the same problem ) thx
03-03-2012, 12:56 PM
Member #18570
^^ Just another reason I'm making a dual battery setup. Drives me nuts I can't start the bike if the battery goes for sh!t!
Odyssey's are good batteries man, buy one and enjoy!
2012 OUTLANDER 1000 XT - XMR COLORS- APACHE TRACKS/GORILLA AXLES X4/AMERICAN STAR TIE RODS (CUSTOM MADE)/AIRDAM (CVTECH) PRIMARY & STM 45 GOLD SPRING SECONDARY/HMF SLIP ON/DEX FARING/2UP SEAT-MOOSE BOX/KIMPEX PEG BARS/BRP METAL PEGS/RICOCHET SKID PLATES/2" GT PIPE LIFT/CAN AM HEATED GRIPS/30" OUTLAW RADIALS ON MSR DIESEL WHEELS/WARN RECEIVER CLEVIS/ROYAL PURPLE & LUCAS OILS (CUSTOM SNORKLE/KOV RAD RELOCATE BUILT TOGETHER)
NEXT UP -- JL AUDIO SYSTEM//TWIN BATTERY & BUILT IN SOLAR CHARGER (HAVE PARTS NEED TIME!)//GET TORQED CAM REPLACEMENT
2010 POLARIS 550 XP EPS -- MID RISE SMOKE WINDSHIELD/2UP SEAT--MOOSE BOX//RT30 WINCH & REMOTE--OTHERWISE STOCK FOR THE TIME BEING
03-03-2012, 01:25 PM
Member #9419
thx
vs
the price is 31$ difference worth Odyssey PC680-P the difference ?
03-03-2012, 05:12 PM
Member #9419
i just test my battery so:
no engine start : 12.50
engine start 13.20 + headlight , warmers ON - 12.50 - 13.20 up and down
3500 - 5000 rpm - 14.52 + headlight , warmers ON 3500 -5000 rpm - 14.20
what do u thing ? is k ?
I have a YTX20L-BS BATTERY ON
I will like to buy the Odyssey PC680-P Battery and use the stock YTX20L-BS like a dual battery and I bought
it will do the job to keep both battery charged ???
THX
03-07-2012, 03:03 PM
Member #21294
Solution?
I had my first experience from ATV with my new Outlander 400 T3 from last summer, and from the very beginning the battery could not cope with even light winching. And the winter made it even worse, I could not plow snow a long while until it stopped due to dead battery. This could not supply power to both plow lift and cooling fan.
We had a couple of days here in this part of Sweden with temperatures from -5 C to -10 C. As soon as it fell below -5 C it was impossible to start the engine, unless you warmed the battery up.
But soon it cooled down and it came to stop by plowing snow.
First thing I thought of was to install dual batteries as some of you guys have done, but then I found a simpler solution:
I exchanged the OE YTX20L-BS for a Shorai LFX27L3-BS12 and got appr. 50% more capacity. If you can afford it, you can even buy the LFX36L3-BS12 and get corresponding the double battery capacity, within the limits set by the dimensions of the OE battery.
So far it is working really GREAT! Engine started by 2nd attempt by -12 C, lowest so far after the exchange.
The motorbikes people are looking for the LiFePO4 batteries for weight reduction and lowering the centre of gravity, not necessary in most of the ATV:s I think. Anyhow you get a weight reduction by 2/3. It is not only a matter of getting more capacity, the Shorai can take higher charging Amps, it is important to take care of the charging systems capacity, and store the energy as much and as fast as possible, I think.
Isn´t it worth a try?
2007 can am outlander 800 separate battery for winching, atv winch draining battery, battery dying using winch, battery for only atv winch, can am commander battery charging system, can am commander dead battery, can am outlander larger battery, can am quad charging battery, canam commander battery dead, dead atv battery, low voltage on 2008 can am outlander when using the winch, quad gets dead battery when you use lights or wench, using winch kill battery outlander, what deca battery fits a can-am outlander, will can am run on dead battery
