Coolant Bleeder Screw
This is a discussion on Coolant Bleeder Screw within the Can-Am Outlander forums, part of the Can-Am ATV Discussion category; Was burping and bleeding my rad after a rad relocate and the washer on the bleeder screw cracked. Can I just replace them with a ...
Old 02-22-2012, 05:19 AM
KJM11's Avatar
Member #14737
View KJM11's Photo Gallery(0)
Default Coolant Bleeder Screw
Can I just replace them with a rubber gasket washer or will there be too much heat that will cause it to wear prematurely?
Started looking for the part # and thought this might be a better solution.
Side note, the relocate was very easy with the BRP kit and love the look...can't wait to actually ride it.
Appreciated.
'08, 500 Outty Max XT, 27" Zillas on SS212's, Dalton Clutch Kit, Snorkeled, BRP Rad Relocate, Ricochet Skids, Frame Mod, Twin Air filter, Relocated Battery, Rear Fender Guards, Over Fenders, Bronco Touring Box
Old 02-22-2012, 07:24 AM
camlaw's Avatar
Member #2621
View camlaw's Photo Gallery(0)
i used a small rubber o-ring,,,worked fine..
2010 can am 800 max xt-p,,26" mst's on black 212 rims
The Following User Says Thank You to camlaw For This Useful Post:
KJM11 (02-22-2012)
Old 02-22-2012, 11:08 AM
Member #11178
View buddyp's Photo Gallery(0)
what place did you get your relocate kit from?
Old 02-22-2012, 12:09 PM
KJM11's Avatar
Member #14737
I ordered it from a local dealer. Your better off getting it from a dealer in the US.
I paid more for it locally even though the kit shipped from BRP in Montreal, Quebec.
Old 02-22-2012, 03:49 PM
r2swift's Avatar
Member #20610
View r2swift's Photo Gallery(0)
you can use rubber o ring and all is good. I'm a firm believer in the burp first, before anything it truly solves alot of the BRP overheat issues.
Yellow 06 Outty 650 HO, UNI air Filter,HMF Penland Pro muffler,Dobeck Fuel Control, Polished race radiator, Dolton clutch kit, Moose pro Belt,Gorilla rad relocate, digital temp gauge, Rox Risers,Pro taper Evo bars,Yellow High lifter Hd Spings,Mud industries snorkels kit, Hayden Fan Controler,Denso Iridium plugs, Can am Hand gaurds, Venom 3000lbs winch, Rubber down 2" lift F/R, 12" ITP Aluminum rims,27"x9" 589 Front, 27"x12" 589 Rear,Custom LED Tail light,New fuel pump, Billet fuel cap, billet shift knob,Billit brake cap, Kolpin Over under fender extenders, Aftermarket Bumpers F/R. Big bore kit soon. And the owner of ABS bailbonds Titusville Fl 321 593-0051 if you need us.
The Following User Says Thank You to r2swift For This Useful Post:
KJM11 (02-22-2012)
Old 02-22-2012, 05:50 PM
KJM11's Avatar
Member #14737
Agreed, I burped the lines and kept topping up the rad. I was just being over cautious.
02 coolant bleeder valve parts
02 ds 650 how to bleed the oil
bleeder screws can am outlander
bleeder screws can am outlander#gsc.tab
bleeding radiator after relocation canam
can am 800 coolant bleed screws
can am bleed coolant
can am coolant bleeding
can am outlander bleeder screw gasket
can am outlander burping radiator
can am renegade coolant bleader
coolent bleed screw location outlatander 800
ds 650 oil bleed screw
ds650 bleeding screw
how to bleed a can am radiator
location of can am 800 coolant bleed screws
pic of can am bleeders on hrad
renegade 800 coolant bleeding
renegade cooling system bleeder screw gasket
Linq Adapters, set screw necessary? hedge Can-Am / BRP 6 01-29-2012 05:06 PM
ds650 oil bleed screw 00ds650 Can-Am DS 3 12-16-2011 01:13 AM
Throttle stop screw Xmachine Can-Am / BRP 29 11-11-2011 07:41 AM
plug wires... screw on ends? Bubba n TX Can-Am Outlander 8 05-31-2010 06:24 PM
400 idle screw outlanderrider Can-Am / BRP 2 06-10-2007 08:23 AM
Copyright ©2000 - 2012, vBulletin Solutions, Inc.
