*Outlander 800 (Engine light flashing along with Limp home mode) - Can-Am ATV Forum
This is a discussion on *Outlander 800 (Engine light flashing along with Limp home mode) within the Can-Am Outlander forums, part of the Can-Am ATV Discussion category; I have an issue with my Outlander 800, my dealer doesn't seem to know whats going on with it? Its gotten worse since the weather ...
Old 05-30-2012, 12:57 PM
Member #23090
View Sweet83's Photo Gallery(0)
I have an issue with my Outlander 800, my dealer doesn't seem to know whats going on with it? Its gotten worse since the weather has warmed up. The engine light likes to come on it seems just shortly (around a second) before my cooling fan kicks in and flashes. Also the screen says its in "Limp home mode" but its not actually because it still drives normally. Once I turn the machine off and start back up the engine light is gone along with the message? Any Ideas what this could be? They said they could find anything and replaced my dirty air filter and said try that.... Anyway needless to say, it did nothing!
Any insight here would be appreciated.
Thanks,
Jared
Old 05-30-2012, 03:11 PM
If the light comes on does it throw a code the dealer can read?
Old 05-30-2012, 05:19 PM
TacticalWarfare's Avatar
First Name: Scott
Member #22565
View TacticalWarfare's Photo Gallery(0)
Might be an overheating issue. Check your radiator as it may be plugged with mud, grab a flashlight and shine it through from all angles. If the rad looks clean, my next guess would be that your thermostat is stuck closed?
2007 Outlander 650XT
- 27" BEARCLAW's
- ITP SS108's
- XMR Snorks
- HMF Performance Exhaust
- Aftermarket Clutches
Old 05-30-2012, 07:34 PM
WiNdGaDe800's Avatar
Could be Cooling fan current inrush (although not likely) Is your battery good with good/tight connections, if they are loose then a sudden current draw could fault the ECM, I have a capacitor JUST for this situation and it has worked wonders.
As insurance I would unplug as many plugs as you can find and make sure they arn't corroded or pins bent/pushed in, I've found some pins pushed in on my bike when I went through and DI-Electric greased them all.
Also when your engine is good and hot crack your bleeder valves on each head to make sure you don't have any coolant bubbles, once you do that and they are both closed go ahead and vigerously squeeze your radiator hoses (careful hot) to knock any bubbles off the coolant hose walls and to work any other bubbles into the radiator, when the engine cools take the rad cap off to let the bubbles out and top off the coolant before you put the rad cap back on.
2012 can am outlander check engine light limp mode
2012 can am outlander max 800 what is a home limp mode
2012 outlander 800 check engine light flashing
2014 can am outlander check codes
can am commander limp mode with engine light lite
can am limp home mode
can am outlander 800 limp home mode
can am outlander limp home mode reset
can-am 800 outlander engine light
canam outlander 800 diagnose check engine light
check engine light on 2008 canam outlander800cc
limp home mode can am outlander 800
limp mode on a 800 can am outlander
outlander 800 blinking.engine.light
quad can am 650 heck engine limp home mode
Limp home mode?? Trapper Luke Can-Am Commander 33 11-24-2012 10:20 PM
Snow Ride - Engine Light Flashing - Limp Home gtj Can-Am Outlander 16 05-03-2012 09:43 PM
Limp Home Mode - Check Engine 20Outty09 Can-Am Outlander 2 05-31-2011 02:06 PM
limp home mode sledneck_4 Can-Am / BRP 5 07-24-2010 12:31 AM
HELP !! Check Engine/Limp Home Mode martinause Can-Am / BRP 14 06-27-2008 04:54 PM
