800 Max Loss of Power issues - Can-Am ATV Forum
This is a discussion on 800 Max Loss of Power issues within the Can-Am Outlander forums, part of the Can-Am ATV Discussion category; I noticed a loss of power at the top end. I installed a new belt 100 miles ago. Confirmed the air filter was clean, even ...
Old 11-28-2012, 06:36 PM
1981packers's Avatar
Member #22805
View 1981packers's Photo Gallery(0)
I noticed a loss of power at the top end. I installed a new belt 100 miles ago. Confirmed the air filter was clean, even ran it without out on one run. I installed a tee with a plug to test fuel press. I jacked up the rear and throttled all the way up, seemed to hit the rev limit @ 78 mph. The fuel press went to 51 then 41 then to 51. Looked in the fuel tank, somewhat clean. I tested on the jack with low fuel. I filled and ran it with a full tank on the trails. I hit 48 mph and the tach was 5500. i could barely hit 55mph I am pretty sure its fuel loss but not totally sure I'm afraid to take it in to the dealer having a snorkel installed, cause Outanders suck in water stock.
2012 Can Am Outlander 800Max
Rotopax,American Truckbox, Ricochet skid plates, Snorkel, Vampire 28's
Old 11-28-2012, 07:07 PM
bullet30's Avatar
Member #23645
View bullet30's Photo Gallery(0)
As far as water I took my belt case off and cleaned the face and gasket real good then greased the gasket upon reinstallation haven't had a prob since. As far as the snorkel your changing the amt of air the engine pulls in which I would suggest a programmer for fuel. The top end should be significantly higher. Chk and see if mud has accumulated on the primary clutch
2015 xds turbo
reflash 16psi
mrrpm intake
larger injectors
couple of cams
pcv
my cat delete
slip ons
custom bov
rage 3p
2014 Maverick XXC
Qsc raptor (gen2)
Stm secondary (gen1) straight 40 helix
Sport low
M2 exhaust
Traded
2012 outlander 1000xt
Dual full system muzzys
TUNE MONSTER w/ all available expansions & wideband O2 sensors
Uni filter or Stock
26" weak sidewall zillas
MRRPM 51mm throttle body bore
MRRPM gen1 drop in cams
Qsc primary (Billet inner sheave)
STM secondary
Some other goods
CA4L!
Traded
2011 Polaris sportsman 550 LE EPS
Stock
Old 11-28-2012, 08:22 PM
Member #22805
That answer had nothing to do with my question...loss of power. not leaks for water.
Old 11-28-2012, 09:39 PM
I'm thinking fuel pump if pressure is dropping to 41.
Old 11-29-2012, 03:55 AM
brutewing's Avatar
Member #8867
View brutewing's Photo Gallery(3) Send a message via ICQ to brutewing
Check the springs in your clutches may need a good cleaning
2012 800 MAX straightline performance intake, straightline pipe, straightline air box mod, straightline power commander tune, QSC CLUTCH and YELLOW BECAUSE IT IS FASTER, 2" rox riser, 26" bighorns on 14" climax motosport rims, BRP storage box ,,right and left mirrors
2006 18 foot mr pike lund my baby
1985 350X TRIKE
1997 Honda valkyrie
PAST QUADS
2005 750 BRUTE FORCE
2005 650 HONDA RINCON
2005 KFX 700
1993 220 KAWASAKI
1985 90cc kawasaki dirt bike
Old 11-29-2012, 05:28 AM
bullet30's Avatar
Member #23645
it most certainly did. If the clutch is caked with mud it won't close very far decreasing your top end and loss of POWER! As for the programmer comment u said u were afraid to take it to a dealer cause it was snorkeld, I suggested adding a programmer cause once again u r changing the air flow through the engine and adding more air to fuel changes everything so that was friendly beneficial knowledge! As for the belt case comment it seemed u like to ride in mud and water sooooo if the clutch was full of mud that was another tech tip I learned.
2015 xds turbo
reflash 16psi
mrrpm intake
larger injectors
couple of cams
pcv
my cat delete
slip ons
custom bov
rage 3p
2014 Maverick XXC
Qsc raptor (gen2)
Sport low
M2 exhaust
Traded
Uni filter or Stock
STM secondary
Some other goods
CA4L!
Traded
Stock
Old 11-29-2012, 05:55 AM
Member #22805
Thanks bullet.
Old 12-06-2012, 09:08 PM
Member #22805
It was the fuel pump. Found after trial and error. Used a fuel pump from Autozone like someone had mentioned on a sticky. Thank you! Running like a dream now.
Old 12-06-2012, 10:32 PM
Fuel pressure drops below 50, it's fuel pump.
Old 12-07-2012, 06:00 AM
bullet30's Avatar
Member #23645
Glad to hear you got it fixed!!
2015 xds turbo
reflash 16psi
mrrpm intake
larger injectors
couple of cams
pcv
my cat delete
slip ons
custom bov
rage 3p
2014 Maverick XXC
Qsc raptor (gen2)
Sport low
M2 exhaust
Traded
Uni filter or Stock
STM secondary
Some other goods
CA4L!
Traded
Stock
2008 can am renegade 800 low on power
2015 outlander 1000 power loss with snorkel
800 outlander problem starting and power loss
can am 2012 800r loss of power
can am 800 los of power
can am 800 outlander looses power
can am outlander display not working and loss of power
can am outlander looses all power
can am renegade 800 power loss
canam outlander 800 lossing power under full throttle
outlander 800 loss of power
outlander max low power
possible causes of loss of top end on 800 can am
problems with can am 800 max
what to do with power loss on can outlander after snorkel kit installed
15-20% power loss LBCMAN Can-Am Outlander 19 03-14-2012 07:25 PM
loss of power dc0273 Can-Am Outlander 3 08-03-2010 02:54 AM
Power loss at WOT SierraRenegade Can-Am / BRP 4 05-08-2008 04:56 PM
Loss of Power webrebel Can-Am / BRP 26 08-10-2007 03:15 PM
power loss cmepoo Can-Am / BRP 26 10-07-2006 10:44 PM
