Ignition switch replacement = Key reprogram? - Can-Am ATV Forum
post #1 of 5 Old 02-13-2013, 04:29 PM Thread Starter
AV8R's Avatar
My ignition switch is giving me issues and I'm considering changing it out. If I put in a new switch will I have to reprogram my keys? Will my key fit a new switch? It's a outlander 1000
Southern Mudd Junkies Racing
AV8R is offline
post #2 of 5 Old 02-13-2013, 04:46 PM
awful knawful's Avatar
I don't think you need to reprogram the key. Install new switch and should work. Switch is basically a slot, all keys will phisically fit.
1998 Honda 300
2005 Polaris 50
2012 Can Am 1000XT
ELKA Stage 4s, Moose Rear Bag, JUNK BRP Hand/Thumb Warmers, 26" Bearclaw HTRs, DP Brake Pads, 2" Rox Riser, LTR Billet Fuel Cap, Gates Kevlar Belt, Rox Hand Guard Mounts, Power Madd Hand Guards, Garage Products bushings, Click N Go 2 poly plow.
awful knawful is offline
post #3 of 5 Old 02-13-2013, 04:59 PM Thread Starter
AV8R's Avatar
Thanks. Got a reply from buddy who races for canam and knows everything about these bikes. "The keys aren't cut, they have a chip. The switch is generic. The chip in the key is matched to the ecm. Only new/replacement keys need to be programmed."
So there is some info for anyone else who wants to know.
AV8R is offline
post #4 of 5 Old 02-13-2013, 05:03 PM
RiverRat750's Avatar
Make sure your ignition relay switch in your fuse box is not going out.
I had the same issue on my 800R XMR. I changed out the ignition relay switch and solved my issue. Try swapping around the fan relay and the ignition relay just for a test and see if this fixes you issues. If it does then you know you have a bad relay switch. $15.00 for a new one.
Hope this helps.
2011 can-am 800R XMR...
2014 can-am Maverick Max 1000 XRS
HEALTECH SPEEDOHEALER
MONSTER PRODUCTS TIMING & FUEL CONTROLLER
RiverRat750 is offline
post #5 of 5 Old 02-13-2013, 05:07 PM Thread Starter
AV8R's Avatar
Thanks for the heads up, i'll look into that. I think it's the switch just because sometimes one key position won't start it but the other will... etc.
AV8R is offline
burnt out ignition switch? Renegade800rXxc Can-Am Renegade 0 09-04-2012 06:24 PM
Ignition switch plastic nut? westinbrad Can-Am Outlander 7 05-31-2012 04:19 PM
ignition switch burned ebm Can-Am / BRP 9 11-30-2011 09:48 PM
burned ignition switch H&k Can-Am / BRP 13 05-09-2009 12:57 PM
key/ ignition switch trouble! mrpringle Can-Am / BRP 7 12-07-2008 09:37 AM
