grease? - Page 2 - Can-Am ATV Forum
post #11 of 17 Old 04-20-2013, 12:11 AM
Miniflexalex's Avatar
grease?
Gen2 has 16 zerks.
6 on the rear
8 on the front
2 on the u-joints
2013 MAX 1000 XT-P
QSC/STM clutch, MrRPM cam's, MrRPM 51mm throttle body, Tune Monster with all extensions, Muzzy slip on, Ricochet skids....and still the OEM tires
Miniflexalex is offline
The Following User Says Thank You to Miniflexalex For This Useful Post:
dnystrom (04-20-2013)
post #12 of 17 Old 04-20-2013, 09:31 AM
1882's Avatar
I can't seem to find the last two on my g2 s rear, I have found two sway bar and two others I'm not sure what they're called but they're in plain sight. Where are the last two? Thanks!
2012 Outlander 1000XT with Elkas
2009 850XP with Elkas, Ron Wood ehxaust, PCV and QSC clutch
1882 is offline
post #13 of 17 Old 04-20-2013, 12:59 PM
HumpinJack's Avatar
There is 6 on the sway bar link; one on each joint and one more on each side where the sway bar connects to the frame. There is 2 more on the U joint in the drive shaft.
I use Amsoil synthetic Marine grease and I grease it after I wash it. Since I wash it after every ride I grease it after every ride to keep the squeaks down. Now I gotta find a way into that steering stem on the G2.
2012 Outlander 1000 - 27" Outlaws1, QSC Raptor / STM roller, HMF, UNI, 2” DIY Snorks, RDC Relocate, Ricochet Full Skids, BRP Extreme Front Bumper, BRP Mud flares, BRP Heated Grips, Rhino Axles, American Star tie rods, 2013 XTP Gauges, 2" ROX bar Risers, and a Cam Lock pipe lift (best mod ever).
HumpinJack is offline
post #14 of 17 Old 04-20-2013, 08:02 PM
MUDDINMIKE's Avatar
Steering stem.........That noisy bitch........ I'm all ears H J...
2014 Outty 800 XTP
27"Bearclaw HTR's, Meloche fan controller,
Ricochet skids,Uni filter, Race-driven brakes,
G/P bushings all around....
SOLD,2012 Outty 800 XT Black on Black,
Ride hard not stupid, get out of stupids way!
MUDDINMIKE is offline
post #15 of 17 Old 04-20-2013, 09:05 PM
I use plain old farm and fleet marine wheel bearing grease, good enough for marine/wet use, good enough for me. I think the key is not in the grease but that you do it often or at least 2-3 times per year or more depending on where you ride.
Does 16 zerks on a 2008 cam am outlander MAX XT 500 seem right or are there less or more? Just bought it today and want to go thru it with a fine toothed comb - thanks!
That just seems crazy high amount as compared to my older ATV's having like 4-5 or so total, but I may be missing some on those ATV's as well I guess, not sure?
cookiedough is offline
post #16 of 17 Old 04-21-2013, 04:11 AM
Angore's Avatar
Originally Posted by MUDDINMIKE View Post
I'm all ears H J...
Looks like they're still trying to see if it'll work on the G-2 but here's an idea : http://www.can-amtalk.com/forums/top...-stem-bushing/
Angore is offline
post #17 of 17 Old 04-22-2013, 01:32 PM Thread Starter
I found all the zerks that mentioned but why is there nothing on the lower trailing arm, by the plastic g2 cap that covers the tube from side to side. ?
chop is offline
Where to Grease Smitty800 Can-Am 2012 Models 1 12-11-2012 08:31 AM
In need of a new grease gun Coonhound693 Can-Am Outlander 6 12-03-2012 09:52 PM
Grease Fitting for U-Joint grease nipple Sergio Can-Am Outlander 15 02-25-2011 05:09 PM
How often to grease? Mike's CanAm Can-Am / BRP 10 11-26-2010 06:16 PM
Grease jeffoutty800 Can-Am / BRP 18 03-23-2008 11:21 PM
