Outlander 400 squeal/screech - Page 2 - Can-Am ATV Forum
This is a discussion on Outlander 400 squeal/screech within the Can-Am Outlander forums, part of the Can-Am ATV Discussion category; There called wear sleeves they make sure you make a good seal between input shafts of your rear and tranny , if your not leaking ...
Old 12-16-2016, 05:51 AM
zags's Avatar
Member #11016
View zags's Photo Gallery(0)
There called wear sleeves they make sure you make a good seal between input shafts of your rear and tranny , if your not leaking any grease you should be good
Sent from my SM-N910V using Tapatalk
2010 can-am outlander 650xt,Ricochet full skids,gh frame mod,stanley box (back),odgio(front),gps60csx,brass kahunas on the rear,king atv gauge pod
Old 01-11-2017, 10:43 AM
Member #69386
View knibbeje's Photo Gallery(0)
Wanted to circle back to share my experience. I did some more research and was a little worried about being able to press out and replace those u joints and get it back together. The u joint kit was like $25, on a tip from my brother I found the complete drive shaft with new u joints on each end was $40-$50 depending on who sold it. I got the $50 one only because it had faster shipping to my house. The item arrived and was built quite a bit better in terms of size of drive shaft steel compared to oem one. It has grease zerks, but while greasing one the threads came loose on the zerk. It was a 2 part zerk, the part that threaded into the u joint was good, but the 45 degree angle part also had threads and they were flimsy/light and shot. The ebay company was very good about sending me a replacement overnight fedex no charge!
I decided that now I know that those sleeves should have been on anyway it is worth going through the work of taking it all back out. I took it back out, added the wear sleeves, and then swapped the grease zerk from the replacement one to the first one so that was good. Added grease, put it back together.
Amazing the difference in driving as I have no lag, when you apply throttle instantly it goes. I guess the clutch was fine all along! The old u joints were completely shot. I'll keep up on greasing this one too.
I went to the parts store and got a new grease zerk (got a better one as it has a solid brass body so no place for threads to come loose anymore) So if anyone needs a replacement rear drive shaft, let me know! I can keep this around for the future but I hope to not have to replace this again!
Got to play/race a 2016 Outlander 1000R with my 2014 Outlander Max 1000 JRHAWK9 Can-Am Outlander 0 08-12-2016 09:15 AM
just got a 2008 Outlander LTD 800, hv Q's pls :) synergy58 Can-Am Outlander 9 07-09-2016 03:03 PM
2015 outlander 1000 or outlander l 570 le Mooser16 Can-am 2015 Models 3 04-27-2016 07:30 AM
My New To Me 2012 Outlander XT 1000 TNRon Can-Am Outlander 12 01-26-2016 11:41 AM
Getting a 2012 Outlander XT 1000,... Opinions :) TNRon Can-Am Outlander 8 01-18-2016 10:13 PM
