Exhaust Wrap on Outlander 1000R - Can-Am ATV Forum
This is a discussion on Exhaust Wrap on Outlander 1000R within the Can-Am Outlander forums, part of the Can-Am ATV Discussion category; I might like to wrap both exhaust pipes on my Outlander 1000R in an effort to "pipe" the heat out the pipe instead of allowing ...
Old 01-10-2017, 06:25 PM
Member #72202
View dbj216's Photo Gallery(0)
I might like to wrap both exhaust pipes on my Outlander 1000R in an effort to "pipe" the heat out the pipe instead of allowing it to radiate in between the side shields and out on me.
Have you done this, and if so where there any ramifications? I assume if it is effective in heat reduction, Can Am would have done it long ago.
What could go wrong? Maybe too much heat in the exhaust side of the head and burn the valves or warp the head. Maybe the exhaust headers will turn red hot and fail from overheat. Maybe the muffler and spark arrester wouldn't like the heat. Maybe Can Am wanted the exhaust side of the engine in the "breeze" as the machine is being ridden forward.
Your advice and experiences welcome.
David
Old 01-10-2017, 06:40 PM
Dr_Z's Avatar
First Name: Winter tracks riding addict!
Member #29280
View Dr_Z's Photo Gallery(0)
I've wrapped my G1 800 twice. Once with the DEI wrap and spray, and once with the titanium dry wrap. I do not mud and both lasted less than 2 years. I have finally given up on wrap since the Hayden fan controller keeps the temps bearable.
If you submerge it, you must make sure the wrap is dry before you park it or the pipe will start to look like crap pretty soon.
2011 Outty 800XXC
QSC Rev-X primary/STM secondary
26x9 Kenda Bearclaw HTR
No Limit octane custom wheels
Symtec heated grips
Homemade UHMW skids
Tatou 4S tracks
SpeedoHealer
Klim winter gear
My YouTube page
(mostly unedited track rides)
Old 01-10-2017, 07:06 PM
Member #73562
View o3dave's Photo Gallery(0)
I did this on my last quad and would not ever do it again. Ceracote is the way to go and is not expensive. The wrap will hold moisture and shorten the life of the pipe.
Old 01-10-2017, 07:15 PM
skeeter69392's Avatar
First Name: love to ride
Member #31621
View skeeter69392's Photo Gallery(0)
mod
you can try this on your 1000, i have it on my 570 and i dont have any heat problems.
my foot and left leg used to get really hot...no more
its a piece of aluminum bent to a 90 bolted on to the existing heat shield holes.
there is approx. 1 inch bent under the stock heat shield which catches the air and forces it down the exhaust pipe instead of on you.
i am assuming your talking about the heat on your left side?
2016 outlander 570 viper red
ricochet skids
3000lb warn vantage winch
fox podium shocks
front LE bumper
gates non-carbon belt
uni air filter
1984-200x
1984-big red 200
1985-big red 250
1999 fourtrax 200
1999 beartracker 250
2000 bayou 220
2001 big bear 400
2001 rancher 350
2003 rancher350
2006 rancher 350
2007 rancher 400 auto
2007 big bear IRS 400
2007 king quad 450
2007 brute force 750
2012 king quad 500 power steering
2016 ca-am 570
Old 01-10-2017, 07:24 PM
Member #72202
Thanks for the informative posts. I did not know the downsides of wrapping in "fiberglass", but holding moisture is a problem. And there is lots of moisture under our ATVs as we ride through a creek along the trail.
Ceramic coatings make sense, but I may be too lazy to disassemble the entire exhaust system and send it off to an applicator.
The cerakote website does boast about slight increased horsepower due to the expanding and forcing exhaust gases out a bit faster.
I vote Can Am make a product improvement and ceramic coat their exhaust pipes from engine to muffler on all models 650 and bigger where heat is more of a problem.
I did notice significant sheet metal heat shielding around the exhaust pipe and muffler on my Can Am. I don't know if that is newer, or they have had that for some time.
David
Old 01-10-2017, 07:29 PM
Spawn's Avatar
Member #28128
View Spawn's Photo Gallery(0)
Here is what I did....did the fan mod where you add a on/ off switch to turn fan on whenever I want and I put D.E.I.'s Floor and Tunnell Shield II on on the entire inside on both the left and right sides of plastics as well as under the rear left fender....now I don't have any heat issues and I ride 5-10 mph on trails mostly....here are some pictures
2015 Outlander XMR 1000
BRP Extreme Bumper
BRP Trunk
BRP Passenger Seat
Ricochet Skids (Black Anodized)
Full Muzzy Dual Exhaust
Power Commander V
Race Driven Brake Pads
Fan Mod
Wetsounds 10" Stealth Sound Bar
Old 01-10-2017, 08:24 PM
Member #31621
can-am will never coat or wrap their exhaust pipes and neither will any other atv manufacturer because it is not good for the pipes.
ricochet skids
fox podium shocks
front LE bumper
uni air filter
1984-200x
1984-big red 200
1985-big red 250
1999 fourtrax 200
2000 bayou 220
2001 big bear 400
2001 rancher 350
2003 rancher350
2006 rancher 350
2007 king quad 450
2016 ca-am 570
Old 01-11-2017, 03:51 AM
Member #64953
View jwfirebird's Photo Gallery(0)
the wrap isnt good for the pipes only if you mud, but the coat should be fine. the just dont want to spend any more than they have to to get the bike out the door
16 570 outty max mudlight xtr
06 660 rhino mega meyhem
some previous;
08 raptor 700r se
03 650 prairie
06 360 prairie
The Following User Says Thank You to jwfirebird For This Useful Post:
o3dave (01-11-2017)
Old 01-11-2017, 07:34 AM
Member #21278
View Deadman's Photo Gallery(0)
The first issue is they run so lean the pipes are stupid hot.
Get a tuner so it runs right first and that will cool the pipes down a lot.
Renegade 1000 X XC, Full Muzzys Exhaust, Flexx Bars, Ricochet A arm skids Hayden Fan Mod!
Old 01-11-2017, 01:31 PM
Member #72202
Spawn: Thanks for your post. I think your approach is pretty good for heat mitigation and increased rider comfort (me!) I was just thinking if I could slow the heat down a bit at the exhaust pipes themselves it would help. I read several Can Am owners have used this DEI material to reflect heat back at the engine.
I also think I will have a manual override on the radiator fan to help blow out heat from between the plastic sides. That certainly makes sense. I don't want to run the engine too cold however. 200F coolant temp sounds about right to me. But the exhaust pipes out of the engine could be 800F or higher.
David
NEW 2016 Can Am Outlander MAX 1000R Limited outlanderltd Can-Am Outlander 24 01-16-2017 06:03 AM
G2 Outlander exhaust cross fitment Grey Can-Am Outlander 3 09-11-2016 11:49 PM
Heat wrap the entire exhaust? kittrell87 Can-Am Outlander 24 08-21-2016 07:12 PM
Got to play/race a 2016 Outlander 1000R with my 2014 Outlander Max 1000 JRHAWK9 Can-Am Outlander 0 08-12-2016 09:15 AM
16 outlander 1000xmr add two brothers exhaust anything else needed? Minime0616 Can-Am XMR 1 07-13-2016 10:53 AM
