mid range loss... i think
This is a discussion on mid range loss... i think within the Can-Am Renegade forums, part of the Can-Am ATV Discussion category; me(renny) and my bud(has a renny x) were riding a few days ago for an hour or two and the motors were pretty hot and ...
Old 07-02-2009, 02:50 PM
mat's Avatar
mat mat is offline
First Name: 30, but ill never act it!!!
Member #6901
View mat's Photo Gallery(0)
Default mid range loss... i think
me(renny) and my bud(has a renny x) were riding a few days ago for an hour or two and the motors were pretty hot and it seemed his had more mid than mine when we would pin the throttle. i got a g/y spring dalton kit and his is stock, both have stock tires and i just cant figure it out. im running steel weights and i dont think i did anything wrong, could my belt be getting too hot and slipping more, what gives, with that kit shouldnt i be pulling harder than stock from bottom to mid or is it basicelly like a stall converter on a car...... i do miss the days of just having to deal with a sprocket on my ole banshee, it was alot less complex than clutching a cvt!
Old 07-02-2009, 04:08 PM
Voodoo's Avatar
Member #2820
View Voodoo's Photo Gallery(8)
From what I understand, the Dalton basically just stalls the engagment and affects shift out....With you having stock tires, it may be hurting rather than helping...
Voodoo
Old 07-02-2009, 05:16 PM
the dalton kit is much better when you run bigger tires on the renegade. for stock tires, BRP did a dang good job with the clutching.
Old 07-05-2009, 04:24 PM
Member #1104
View brpbear's Photo Gallery(0)
I can agree with you as long as your at sea level where a clutch kit helps is over 3000ft. I have owned three outty's and know a Renegade and have had to work with the clutch on all of them but most of my ridding is above 7000ft and I also have used over sized tires.
Old 07-05-2009, 09:28 PM
good point. i keep forgetting not everyone rides at zero elevation like i do
Old 07-05-2009, 10:01 PM
Voodoo's Avatar
Member #2820
Agreed Wake....the only elevation I have is after a 12 pack....lol
We are at 85 feet here as an official sea elevation...
Voodoo
Old 07-06-2009, 03:57 PM
800VTwin's Avatar
Member #4130
View 800VTwin's Photo Gallery(0)
Are your rpm's the same at shiftout? if yes- its not the clutch
Any pipes or programmers? Stale gas? Tire pressure same? Body weight difference? Throttle stop screw? Air filters same and clean?
Dalton kit works great with stock tires.
08 gade 800
-800vtwin.com ECM
-Koso Display
-LTE Dual Exhaust (ceramic), modded QC's
-50mm tb
-09 tb boot, airfilter, cams
-Race Intake
-Modified Airbox
-Dalton Clutch Components
Old 07-06-2009, 06:06 PM
b800's Avatar
Member #2254
View b800's Photo Gallery(0)
On my and Outlander and my Renegade, I was clearly faster with my stock spring than the G/Y spring. With stock tires.
But they feel faster with the G/Y spring, because the motor was not loader enough. The spring doesn't affect a lot the shift out on this Vtiwn (+/-100 to 200RPM)
Keep your dalton centrifugal level and test with the stock spring.
Check also the suggestions of 800VTwin.
Renegade 800R 2009 (3000miles)
MXZ 500SS 2009
Tundra 2002
Past ATV
Outlander XT 800 2006 (14900km)
King Quad 700 2005
Grizzly 660 2002
Xplorer 400 2001
DS650 2000
Blaster 1998
LT230 1993
Old 07-07-2009, 06:34 PM
mat's Avatar
mat mat is offline
Member #6901
ok guy, finally got into the clutch today, went back to stock arms and the g/y spring, it seemed to help but not sure without racing. im going to try b800s suggestion and run dalton arms with steel weights and the stock spring. all thin terminology about shift out and stuff is confusing the crap outta me. i'll be glad when i understand how all this cvt stuff works!!!!!!!
Old 07-07-2009, 06:47 PM
mat's Avatar
mat mat is offline
Member #6901
k, went back to the completely stock set up, definately doesnt wheelie as good, im beginning to feel like i waisted my money on the dalton though cause i didnt gain mid range and lost 2 mph on top with the steel weights. either im getting used to the power i got or i aint doin something right, i dont know. it just definately feels like somethings missin somewhere. even with the reccomended setup i can barely get the front up on asphalt at 20mph! oh and i forgot to mention i am at 0 elevation too... gonna try b800s suggestion tomorrow, right now im kinda pissed and got one heck of a headache!
Power loss at WOT on 800 xt suprjet Can-Am / BRP 19 11-21-2008 09:54 PM
Power loss at WOT SierraRenegade Can-Am / BRP 4 05-08-2008 05:26 PM
Loss of Power webrebel Can-Am / BRP 26 08-10-2007 03:45 PM
loss in horsepower sharib Can-Am / BRP 0 03-11-2007 09:03 PM
power loss cmepoo Can-Am / BRP 26 10-07-2006 11:14 PM
