Renegade & Outlander rear cv boot or cv joint replacment
This is a discussion on Renegade & Outlander rear cv boot or cv joint replacment within the Can-Am Renegade forums, part of the Can-Am ATV Discussion category; Hi there ! I had my cv boot torn a part two days ago,so i came here to see a solution of the problem. . ...
Old 11-19-2010, 12:37 AM
Member #12055
View astvadz71's Photo Gallery(0)
Default Renegade & Outlander rear cv boot or cv joint replacment
Hi there ! I had my cv boot torn a part two days ago,so i came here to see a solution of the problem. . Ok i have ordered the damn socket for the trail arm but 10 days waiting? nooooo way. So i got it out with no problem. I did pull aside the two shocks and the key move is to remove the secure bolts for differential,pull brake caliper aside . Wobble dif back and to the side and there u go axel is out . soory No picks but
Old 11-19-2010, 04:57 AM
View QUADAHOLIC's Photo Gallery(58)
Thanks for the "tip", there is always a way, when there is a will.
Old 11-19-2010, 06:57 AM
cam2010's Avatar
Member #7413
View cam2010's Photo Gallery(2)
You really don't have to touch the diff or brake caliper. Just lift the rear of the machine, undo both rear shocks at the bottom and swing the rear tires down until you can get the axles out of the diff. ( use a sledge and a strap to pop axles out at diff end) Then remove outer axle nut and pull out axles.
I bought the fancy torsion nut tool because my dealer told me I needed it to replace the boot. I tried to return it unused but they wouldn't take it back. They even argued that you did need it to change boots.
2012 commander 1000 XT
2010 canam outlander 800R XT
26" Zillas
Old 11-19-2010, 07:24 AM
gbroad23's Avatar
Member #4746
View gbroad23's Photo Gallery(0)
Whats that tool worth? I've read here somwhere of someone making one, Any pics of that self made tool? Good tips guys.
Old 11-19-2010, 11:36 AM
cam2010's Avatar
Member #7413
It was about 50 bucks canadian. You could make one if you have time and patience.
26" Zillas
Old 11-19-2010, 05:40 PM
I believe you do however, need to unbolt and slide the diff back, to change the rear u-joints out....right?
Old 11-20-2010, 07:40 AM
f419sr1's Avatar
Member #3045
View f419sr1's Photo Gallery(0) Send a message via AIM to f419sr1 Send a message via MSN to f419sr1
I found to pop the inner Shaft out of the rear I put a hose clamp on the case of the inner CV shaft and took a long bar so I could get a good hit on it with a hammer and it poped right out didnt even have to take the shock off. Loosen the outer hub bolt first.
06 outty 800 MRRPM 840 gen 2 cams 09 intake PC3 engine oil cooler fan over ride snorkled full skids Aluma Tech CV Guards ITP 212 26" terra cross Piaa HIDs secondary radiator digital engine temp heated hand and thumb BRP fender extensions Fasst Flexx 14deg bars Rox Anti Vibe Risers Cycra Hand Guards and bark busters Moto Comm Camera stage two Crutchfields front and rear
07 Renegade 800 Rox anti vibe risers Aluma Tech external oil filter and cooler
2006 can am outlander 650 rear inner cv joint
2008 can am outlander 650 xt inner rear cv boot
2009 can am outlander rear cv boot replacement
2010 canam outlander cv joint
can am commander 1000 cv change
canam cv boot torsion alex
canam renagade cv boot
how do remove rear axle from can am renagade
how do remove rear axle from can am renagade#gsc.tab
how to replace the rear cv boot pretector on a am renegade
outlander 800 rear inner cv boot issues
rear inner cv boot removal on a 2009 800 outlander
removing rear axle shaft from 2006 can am 800
replace cv boot
replacing cv boot on can am outlander 1000
Rear CV joint boot replacement walleyeguy Can-Am Service Bulletins /Recalls / How To 93 04-23-2013 08:47 PM
Rear inboard CV joint outty650 Can-Am Outlander 0 04-15-2010 07:34 PM
400 rear u joint pops Can-Am / BRP 3 03-21-2009 10:49 AM
06 650XT rear U-joint fireman7797 Can-Am / BRP 8 11-18-2008 05:02 PM
rear u joint poorfarmer Can-Am / BRP 3 12-17-2006 10:53 PM
