P0705 Transmission range sensor circuit malfunction (PRNHL). - Can-Am ATV Forum
post #1 of 15 Old 11-10-2012, 09:20 AM Thread Starter
TheBlizzard's Avatar
Getting this code when under a heavy load going over 55mph. I took the three gearbox sensors out and cleaned them and put them back in and there was no change. When it throws the check engine light there is no change in how it runs, nor do I get the "E" in the position box on the dash like some say that they get.
Just wondering where I should go from here? Is there some connections I should take apart and clean? Battery may be getting weak or something?
Bike in question is an 08 800 Rene
Thanks in advance guys.
TheBlizzard is offline
post #2 of 15 Old 11-10-2012, 09:35 AM
gbroad23's Avatar
I would assume you took the wires off the sensors as well and cleaned thos connections? Just making sure cause you wernt overly clear on that. There is also a 4th wire about 3-4 inches towards the front with the same style sensor for the 4x4 indicator light. It wouldnt hurt to clean and dielectric grease that one aswell. I will see if the manual has anything on testing them.
07 outty 800 max xt, XMR stealth snorkels, Fox evolution shocks, CV tech primary by Airdam, 650 helix, Y/B Dalton secondary spring, Odyssey pc680 battery, 5000 pound viper max winch, 28 " Swamp Fox with off set rims, Full Ricochet skids, Moose Grip/Thumb and seat warmers, steel frame mod, Wild bore rad relocate, Allballs Tie rod ends, ATR heavy duty tie rods, All balls ball joints and wheel bearings, XMR dash pod, extended vent lines, updated cvt back plate, custom built steering stem (2" longer than stock), MRRPM 840 bbk, stage 1 drop in cams, Throttle wedge mod, PC5, FMF slip on, O2 bungs welded for dual tune.
gbroad23 is offline
post #3 of 15 Old 11-11-2012, 11:04 AM Thread Starter
Yeah sorry I wasn't clear, but I did clean all of them, and I also cleaned and used dialectic grease on the connections.
I will do the 4x4 indicator sensor as well just to be sure, I didn't know about that one.
It just doesn't make sense that it only does it under a heavy load going above 50mph or so. I could drive it for 5 hours straight and never see it happen unless I get going that fast.
And again, it does not throw the indicator "E" error like some say happens under that condition.
So I am kind of at a loss. It doesn't affect how it runs at all but I just like my stuff to be running 100% to avoid issues when I am on long rides.
post #4 of 15 Old 11-11-2012, 01:42 PM
had the same thing as you, after cleaning all 4 wires - I kept getting the code.
What solved it was cleaning the speed sensor from the metal filings it collects.
its located at the same area - have a go at it and let us know
good luck
2007 650 Outty Max
Mods: 1" wheel spacers, Hayden 3647 (disabled), VBX bearings, Fan Led switch, HMF Performance Slip-on & QC, Dalton DBO650 & Tan Spring, FlexxBars 15 Quad High, Odi Rogue grips, Cycra handguars, ELKA 1+R, DEI Titanium exhaust wrap
michalip is offline
post #5 of 15 Old 11-12-2012, 04:31 AM Thread Starter
Awesome, I'll do that in the next few days here and post my findings. I think my neighbors are going to get sick of me riding the roads going 60mph though here pretty quick so hopefully I can get it fixed. Ha ha.
post #6 of 15 Old 01-21-2013, 08:51 AM
Flyboy538's Avatar
good luck
Good info man i have gotten the same code but when i cycle the key off and back on again it clears it. I will give those conncections a cleaning i read that in the service manual just couldn't believe that was going to get rid of that code.
Flyboy538 is offline
post #7 of 15 Old 01-22-2013, 01:24 AM
good luck
Same thing was happening to me - just cycle it once at the beginning of the trip and never get it again. Well that was getting a bit frustrating so I started digging . It was the VSS all along, but it didnt hurt cleaning all the other sensors located in the same area as I wrote above.
2007 650 Outty Max
michalip is offline
post #8 of 15 Old 01-22-2013, 06:50 AM
Flyboy538's Avatar
good luck
Oh really?? Whats the VSS?
post #9 of 15 Old 01-22-2013, 08:03 AM
gbroad23's Avatar
Vehicle Speed Sensor.
gbroad23 is offline
post #10 of 15 Old 01-22-2013, 08:37 AM
Flyboy538's Avatar
That's the 4th wire to the right of the 3 in the gearbox right? Did you have to replace it or just clean it??
P0705 Fix DohCanadian Can-Am Outlander 5 05-06-2012 06:35 PM
P0705 - 2011 Outlander 400 - Please advise TanGo_8 Can-Am Outlander 9 09-23-2011 11:46 PM
p0705 code mikezx7 Can-Am Outlander 3 09-09-2010 09:22 AM
trans range sensor 666666 Can-Am Renegade 1 07-21-2010 04:56 AM
transmission sensor switch gmailey Can-Am Outlander 0 04-10-2010 12:05 AM
