Battery problems on 2012 1000 - Can-Am ATV Forum
post #1 of 9 Old 12-15-2012, 05:13 PM Thread Starter
Brianm900's Avatar
I was just wondering if anyone else is having problems. In July I had to get jumped when out on a trail ride. On Monday I went on ride turned it off went to start & wouldn't crank. Last nite I took it to dealer, today they said battery is fine. It's because the EFI takes more power then what the charging system puts out. If that is true, you would think they would make the charging system put out more.
Brianm900 is offline
post #2 of 9 Old 12-15-2012, 05:17 PM
Hardcore Member
Renelander's Avatar
You have a case of a crappy dealership. Lol
Did you check your battery connections?
2012 Renegade X XC 1000
TUNE MONSTER with both expansions and Wideband O2 sensors, ///AIRDAM CVtech primary, STM Secondary, Dominator Dual Exhaust, MrRPM 51mm TB and Drop-in Cams
CA4L!
CLICK HERE FOR YOUTUBE VIDEOS: RenelanderTV
Renelander is offline
post #3 of 9 Old 12-15-2012, 05:41 PM
gbroad23's Avatar
X2, Thats a good one Renelander. "A case of crappy dealership" bbbwwwwaaahhhhhhhaaahhahhahahaha
07 outty 800 max xt, XMR stealth snorkels, Fox evolution shocks, CV tech primary by Airdam, 650 helix, Y/B Dalton secondary spring, Odyssey pc680 battery, 5000 pound viper max winch, 28 " Swamp Fox with off set rims, Full Ricochet skids, Moose Grip/Thumb and seat warmers, steel frame mod, Wild bore rad relocate, Allballs Tie rod ends, ATR heavy duty tie rods, All balls ball joints and wheel bearings, XMR dash pod, extended vent lines, updated cvt back plate, custom built steering stem (2" longer than stock), MRRPM 840 bbk, stage 1 drop in cams, Throttle wedge mod, PC5, FMF slip on, O2 bungs welded for dual tune.
gbroad23 is offline
post #4 of 9 Old 12-15-2012, 06:45 PM Thread Starter
Brianm900's Avatar
Yes I did
post #5 of 9 Old 12-15-2012, 07:23 PM
slayer1962's Avatar
Charging
That sounds rediculous. They increased the charging system recently should be better than ever.
slayer1962 is offline
post #6 of 9 Old 12-16-2012, 12:09 PM
VFORCEJOHN's Avatar
check the ground wire going to the rear cylinder head. I've seen some of these loose. this will cause poor charging.
these 1000's have the most powerful charging system. 400 and 650 watt stators. they double and triple what most other atv's output.
the reason for these having such strong charging systems is POWER STEERING!!! that's why pwoer steering models have the upgraded 650 watt stator instead of the 400 watt standard stator.
Bad battery OR loose connections. Unless the atv isn't charging??
John
www.vforcejohn.com (570)-773-1240 Slipon and Full system Pipes, FI tuners, Clutching, Custom Dynojet Dyno tuning for all setups. email vforcejohn@yahoo.com
VFORCEJOHN is offline
post #7 of 9 Old 12-16-2012, 01:11 PM
Grounds on a 1k, pic courtesy of Slyder.
rkc05 is offline
post #8 of 9 Old 12-16-2012, 02:08 PM
Check all connections and use a battery tender all the time.
adrumm5378 is offline
post #9 of 9 Old 11-09-2013, 08:17 AM
Myler709x's Avatar
I keep getting limp mode and P code 0262 which is cylinder #1 injector shorted to battery. Iv only been getting this since I did my snorkels and had to remove that metal plate that all those wires are connected to and just ground them to the frame. Could my problem have something to do with these grounds?
2015 Renegade xxc 1000
QSC/STM
HMF Performance duels with vector tips
Power commander
Gorilla axle rad relocate
PPSM snorkels
2" Highlifter signature lift
3/4 PPSM spring spacer lift
PPSM Knuckle shifter
1" wheel spacers
30" Silverbacks
Rhino axles
XMR Rear diff
Check us out for lots of videos and giveaways!
www.facebook.com/myler709x
www.youtube.com/myler709x
Myler709x is offline
air filter problems 2012 outy 1000 Jaxamilliom Can-Am Outlander 20 05-10-2012 06:09 PM
problems with new 2012 renegade 1000 hobo Can-Am 2012 Models 3 02-06-2012 08:29 PM
2012 Renegade 1000 xxc Problems Gade1000 Can-Am 2012 Models 17 11-01-2011 09:37 PM
Battery problems on 09 650 09 650 xt Can-Am Outlander 4 05-15-2010 10:15 PM
battery problems renegade 1382 Can-Am / BRP 10 01-15-2009 03:55 PM
