How to Build an ATV Audio Tube / Stereo - Page 8 - Can-Am ATV Forum
post #71 of 121 Old 12-20-2011, 04:21 PM
canamxmr2011's Avatar
I thought I replied a while back sorry man.
You need 2 y cables and a set of RCA cables and if using a iPod then you need the cable that goes from headphone jack to RCA.
The y cables you need the ones with 2 female ends and one
Male end.
Plug the white RCA cable plug into one of the female ends of the y cable, plug the other side of that white RCA cable into one amp in the other tube. That y cable, plug into the other amp in the white spot. the white male plug from the headphone jack, plug it into the other female plug on the y cable. On the other y cable, do the same thing but with the red cables
The facts say alot, the ride says it ALL.
2011 Outlander 800r XMR
1993 KING QUAD
Competition Sports
Gorilla-Axle
///Airdam
STM
Looney Tuned
Rubberdown Customs
Dyno-Jet
Motosport Alloys
Highlifter
TEAM THRASH'N IT
"IN ROUTE TO SHABOOMS"
canamxmr2011 is offline
post #72 of 121 Old 12-20-2011, 06:57 PM
07reaper's Avatar
since this thread is bouncing back around now, i recently had an idea on something a little louder.. i have a ski boat and have these on the wake tower Bazooka MT6502BS BLACK 6-1/2" Marine Tubbies / Black MT-6502B,
wonder how they would hold up on the outty? local atv shop here sells these little amps ( not sure what brand, cant remember) but there "800" watts.. the razors running around here use them to push speakers such as these... anybody have any ideas on how to make this happen and keep everything semi water proof.. i know bazooka has a warranty that they offer on water damage..
ideas?
07reaper is offline
post #73 of 121 Old 01-08-2012, 05:52 PM
How did you wire the amp to a cig plug? I have a Kinter 500watt amp. Two wires coming off the amp. Red and Black. I think one is a remote? Please help. This is the only thing holding me up!
dux0606 is offline
post #74 of 121 Old 03-06-2012, 07:25 PM
Wyldlander's Avatar
I just finished mine( but it's together so i can't show you pictures of what i did).
So I will try and describe it to you as best as I can.
Looking at your amp, there should be on one side the controls and the AUX output ( RCA "white/Red") On the other side of the amp should be the "Posts" for the speakers and the Batteryconnection plug. For the battery plugs you should have 3 places where wires go. First the ground (-)should be Black wire, then there is a remote block, then a red(+). take a small piece of the red wire and loop it from the remote to the (+) Then red wire from the (+) on amp to the cig plug. It works, Mine was this way before i took it apart to lengthen it and i re-assembled it and it works great.
http://www.can-amforum.com/forums/at...-stereo-11.jpg
Test it before you put it all together, i tested mine in my truck, all i got to do is paint and seal it up. Use clear silicone caulk to seal between the elbows and the pipe instead of gluing the tube together if you don't plan on submerging the pipe. It will make it easier to take apart if you have to fix or replace something internally. You cn use small screws to help hold it all together but do not glue if you ever plan on taking it apart.
It is a Bitch to take apart without tearing up the elbows, that is if you intend to re-use the elbows.
2008 Outlander 650 max XT in Yellow,Full Ricochet skidplates, Amsteel synthetic line, 26 inch Maxxis Bighorn 2.0s, HMF Performance Utility pipe( in Yellow), HMF fuel controller, BRP rear box, Tigertail w/1.25 reciever, Gade footpegs, Kolpin/Moose overfenders, (1) gallon Rotopax fuel pack( just in case)
Cumberland ATV Riders
Southernoffroadriders
My Youtube channel can be found here:
http://youtu.be/0h8WlovZRA4
Wyldlander is offline
post #75 of 121 Old 04-11-2012, 09:44 AM
case
Originally Posted by Sooner View Post
Pictures 17-23
Where did you find the water proof case
dodgeman77 is offline
post #76 of 121 Old 04-11-2012, 09:51 AM
Im have an iphone and ipod nano where can i find an affordable but yet good waterproof case for my auiotube
post #77 of 121 Old 04-11-2012, 04:14 PM
Walmart in the boat section the have this waterproof bag thing that has a headphone hack inside and out so you can plug in your phone or whatever
1993 KING QUAD
Competition Sports
Gorilla-Axle
///Airdam
STM
Looney Tuned
Rubberdown Customs
Dyno-Jet
Motosport Alloys
Highlifter
TEAM THRASH'N IT
post #78 of 121 Old 04-15-2012, 08:12 PM
My question is what would i have to do if i wanted to put 4 speakers? Would i need 2 200 watt amps? What modifications would I have to make if I wanted to make it this way?
crustyspandex1994 is offline
post #79 of 121 Old 04-16-2012, 05:07 AM
you just need a 4 channel amp. and 2 6-inch pvc y's, or 2 elbows with 2 t's.
my 2 channel sounds great..bazooka makes a nice set of camo speakers..they sound great but cost alittle more..and they look great..
fredgal is offline
post #80 of 121 Old 04-19-2012, 12:29 PM
Look at my tubes.
1993 KING QUAD
Competition Sports
Gorilla-Axle
///Airdam
STM
Looney Tuned
Rubberdown Customs
Dyno-Jet
Motosport Alloys
Highlifter
TEAM THRASH'N IT
Hey guys I would like some Audio help! Donna Can-Am Outlander 13 03-24-2011 06:57 AM
audio system for autlander le bombardier Can-Am Outlander 1 02-15-2011 06:55 AM
say, if I record audio of my 800xt engine... Bounce19712 Can-Am Outlander 10 12-06-2010 09:05 PM
Need help with my audio system!! cannnedhamrider Can-Am / BRP 1 11-26-2010 01:42 AM
How to get your audio back on utube SIMO General Chit Chat 0 03-24-2010 03:13 AM
