Photos of replacing Front CV boot - Can-Am ATV Forum
This is a discussion on Photos of replacing Front CV boot within the Can-Am Service Bulletins /Recalls / How To forums, part of the Can-Am Tech Area category; Today I picked up a replacement CV boot It was not a factory BRP bootit wasuniversal type. For$ 17. And after looking at the factory ...
Old 03-08-2007, 10:59 PM
Member #1314
View motelcambodia's Photo Gallery(0) Send a message via Yahoo to motelcambodia
Today I picked up a replacement CV boot It was not a factory BRP bootit wasuniversal type. For$ 17. And after looking at the factory bootit is not a rubber the front ones look to be some type of hard plastic .Thats why it cracked .
I started with removing the front hub. I found 1 1/16" socket fits the big nut. Its on tight I used my 3/4" air gun to get it off.
I then pulled off the spindle undoing the 3 bolts on the bottom and the one nut on the upper ball joint.
The Following 2 Users Say Thank You to motelcambodia For This Useful Post:
BRPFan (07-27-2009), volksman (12-15-2009)
Old 03-08-2007, 11:04 PM
Member #1314
TO get the shaft off the CV joint I used a rubber hammer and just hit it and it come out. It had a spring type ring on the end of the shaft that it will unsnap relasing the shaft from the CV Joint. The photo shows the whole shaft off the bike but im sure it would been easer to do this on the bike. You should also look the see if it has 2 small angled parts on the spring clip you can spread open and slide it off easy hidden in the grease I did not find on mine so atap with a hammer took it off . The rear has one that you spread to remove off the axle.
The Following 3 Users Say Thank You to motelcambodia For This Useful Post:
BRPFan (07-27-2009), randyv (06-05-2010), volksman (12-15-2009)
Old 03-08-2007, 11:09 PM
Member #1314
This boot replacement come with the new clamps and the little tool to get them tight.
To put the CV back on the shaft I just made sure the spring ring was in the grouve in the shaft and just tapped it back togther with the rubber hammer.
Old 03-08-2007, 11:13 PM
Member #1314
This is what I did when reassembling was to hold the upper ball joint so the locking nut would not spin the ball joint. I clamped it up tight in the hole .
Old 03-08-2007, 11:20 PM
Member #1314
The front CV boot are some type of plastic , the rears look to be rubber.
The fronts feel hard and brittle . I'm thinking this will has to be replaced on all 4 soon.
E bay has replacements and my local dealer had a aftermarket one in stock for only $17.00
This can be done in about 45 min. . It only took me 10 min to reassemble it all back on the bike.
I did not have any shop manual so there may be a easer way to do this.Or a correct way .Butthis worked for me.
Have fun.
Old 03-09-2007, 10:49 AM
Member #1314
kraked wrote:
u would think they would warranty that. By looking at the pic it's pretty obvious it is a failure not a puncture. Did u try ?
NO. For $17.00 for a aftermarket boot that was in stock and a wait time of 1 week for them to order a stock boot. I did not even try. The stock boots look like they are junk hard plastic. I will see how this boot does compared to the other side. My bike is only5 1/2months old ,1100 miles 85 hours. It was much easer for me to just do it my self. I may bring them the old boot so they can make a record of it so if others have the same problem they can do a recall HA ha ha. And the dealer I would trust to do it is 1 hour past this one I just got the part from.
Old 03-10-2007, 09:19 AM
Member #888
View wildbill's Photo Gallery(0)
Good post I just had to replace the rear axle on my Yamaha Grizzly as it was bent beyond belief. I also was dissatisified with the hard plastic boots on the front of my 06 Bomb and though about ordering replacement rubber boots. I found a great place to get boots, clamps and axles if anyone needs them. thecvman.com has a great selection of cv parts very reasonably priced and lots of info on doing the job yourself. Thanks for the pics with inyour post.
WB
2006 Outy 800 EFI HO Green,
2003 Yamaha Grizzly 25" Maxxis Bighorns,
1982 Honda ATC 110 & 185S
Old 05-28-2007, 08:53 PM
Kraker's Avatar
Member #240
View Kraker's Photo Gallery(0)
me too under warranty but it was a freak occurance i think.Both rear sidessmall clamps spun on the axle shaft and one ripped. Looking back the only reason i can come up with is that after playing icebreaker for a while(in about 1"-2" of ice in puddles)then stopping for a bit & going again, some ice chunks must have gathered in the factoryplastic rear boot protectors and froze there:shrug:
Old 11-10-2007, 12:00 AM
Member #1314
Revolution wrote:
i cant seem to get the outer cv off of the shaft?
Look for a 2 small round size of a paper clip wire on the spring clip sticking up near the splines and the CV holding it to the axle. Spread them and it should slide off.
You may need to clean off all the grease.
For boots look for FAST BOOT. $17 to $20 and most ATV dealers it includes a small tool and new bands to hold it on.
Old 11-10-2007, 08:41 AM
Member #185
View Revolution's Photo Gallery(0)
i ended up taking the hole axle into the dealer and they got a tool from brp that is for poping them off, very simple tool to make,
07 Can am Outlander 800XT
Dalton clutch kit
Ricochet skids
Power Commander
HMF Penland
04 Can am Outlander 400XT
EPI Clutch kit
26" Mudzillas
2000 bombardier traxter 500 axle nut size
2001 can am traxter 500 how to remove cv shaft
2004 bombardier outlander max boots
2005 bombardier traxter xl front right axle
2006 bombardier outlander 400 front inner cv boot change
2007 can am 800 ho efi outlander cv boot problems
canam outlanderr front cv boot replacement
cv joint for 2005 bombardier traxter xl
front cv boot replacement for bombardier quad
how to remove front axle on a 2005 bombardier taxter xl
how to take front axle off a can am outlander max 2004
mtmrmrcmc. mn xt.com..com cv
replaceing cv boot on can am traxter
replacing front axle can am outlander
replacing front axles on a 2000 can am 4x4 500cc traxter
