03-28-2007, 05:13 PM
Member #306
I just tuned my suspension with the one inch spacer life under the springds on my MAx 800.
And it sure as heck did'nt cost me 695 bucks for a pair.
03-29-2007, 06:54 AM
I know several of you guys already have the stabilizer. Are they fairly easy to install?
03-31-2007, 08:55 PM
Member #839
Yeah, it's fairly easy. :tg: It took me about 1 hour to install it, but now that I know the ins and outs, it would only take about half an hour once I had my machine elevated.
A couple of suggestions:
1. Hoist the front of the ATV up and remove the front tires.
2. Pry the plastic clamp up that holds theradiator hose (left side of machine) and tie it out of the way.
3. Install the 4 mounting bolts into the stabilizer, but do not tighten fully. Instead, snug them enough that the stabilizer doesn't move easily and check to make sure that you can get a wrench or socket onto each of the 4 bolts. I used a rubber mallet to center the stabilizer and checked that I could put the wrench on each bolt. Then I tightened them all.
4. I centered the handlebars and then centered the linkage before tightening the clamp on the steering shaft.
5. I also noticed that when I reinstalled the radiator hose, it was very close to rubbing on the newly installed stabilizer, so I tie wrapped the hose up and away from the linkage.
Hope this helps everyone. I haven't had a chance to ride my machine since installing the stabilizer, but have plans to ride in a couple of weeks. :ban:
03-31-2007, 11:16 PM
Member #324
Crutchfield Performance
Just supported one or our Sponsor's
Ordered the Stabilizer. Ed sounds like a real good guy.
Randall
2006 BRP 800 MAX "Yellow"
Built 11/05 Bought 1/06
BRP Mudguards, Radiator Protector, F/R Bumpers
Ricochet Skids & A-arms, Jet-Hot coated exhaust
Leed Eng. 2" reciever
Team Outty Member #78
04-01-2007, 05:49 PM
Member #2163
So what is the stabelizer worth.
Black c-series 7 rims-winter
4x26x10x12 act tires-winter
2-AD Bovin tracks with custom fenders-winter
Custom painted stock rims-summer
27x9x12 and 27x12x12 Dirt Tamers on factory rims
1"and 1.5" highlifter spacers-summer
hand-thumb-foot warmers-winter
Moose fender flairs BRP wind shield
04-01-2007, 05:58 PM
LIMO-MAN wrote:
they will cost you around 495 delievered. BUT IMO they are worth their weight in gold out on the trail
OMFGGG NO WAY
04-04-2007, 11:35 PM
Member #708
Something else to put on my list of 'needed' items!:dan:
BigDozer66
'06 Outlander 800HO, Warn 3.0xt, Ricochet Full Skids, Alumatech CV Guards, BigDozer66 Custom Battery Protector, Twin Air, 27" Outlaw MST's on Motosport Climax wheels
Team Outty Member # 142
'05 King Quad, Warn 2.5ci, Amsteel Blue, 26" MST's, ITP C Series Type 6
http://community.webshots.com/user/bigdozer66
04-13-2007, 05:49 PM
For those of you with the KewlTek split brake kit, you can mount the stabilizer with a little effort and some time. I had to do some rerouting of the brake hoses and had to grind a little off the stabilizer mounting plate but it does work.
08-26-2007, 10:14 PM
Member #1388
I'm no mechanic and installed mine the night before last by following the directions that came with it. Everything that Crykid said is dead on and I did the exact same thing (or at least figured out the hard way...) tie wrapping the radiator hose and all. Eventhough it wasn't rubbing...it seemed too closed to leave be.
I am taking my Renegade to WV in early Sept. I'll post back my thoughts on this stabilizer. I've only ridden the Renegade once for a few hours before without the stabilizer. Since I use my hands for work...I figured this thing was like a small insurance policy. I've caught trees before and small stumps in the underbrush and almost broke my thumb and wrist.
