Which tuning tools to purchase.
This is a discussion on Which tuning tools to purchase. within the Dyno Reports | Tuning Center forums, part of the Can-Am Tech Area category; I getting ready to purchase everything so I can tune mine and my buddy's 2011 Outlander X MR. This is what I plan on buying. ...
Go Back   Can-Am ATV Forum > Can-Am Tech Area > Dyno Reports | Tuning Center
Old 12-29-2010, 09:38 AM
Member #13503
View OuttyXMR's Photo Gallery(0)
Default Which tuning tools to purchase.
1. Power Commander V
2. Autotune AT-100 (for dual cylinder tunes at the same time)
3. Wideband Commander / Wideband Commander 2 / LM2 (to fine tune 100%, idle, and 2% any suggestion which one to get and why.)
I will be helping a few friends with their tunes so I have to learn this if there is anything else I will need please advice all you tuner guys. I am determined to learn how to tune. I have read so many threads it is all starting to make since. I still don't know which one of item 3 to get please advice.
Old 12-29-2010, 10:20 AM
Member #13503
Does the WB2 also do autotune with the PCV and does it have data logging capabilities (like the orginal WB) if I buy the LCD-200. This may be a better choice for myself the only down fall is for the dual cylinder tune I will have to tune each cylinder seperatly. Does that sound correct.
Old 12-29-2010, 10:27 AM
Member #13503
Does the WB work as an autotune also with the PCV?
Old 12-29-2010, 10:38 AM
VtecGSR95's Avatar
Member #4306
View VtecGSR95's Photo Gallery(0)
I had the PCV, WB2 and LCD. They work fine, but you do have to tune the cylinders individually. The WB2 IS an autotune with an extra port and the LCD will record datalogs with an SD card. The WB2 can be used on any bike with the extra wires on it.....whereas the autotune can ONLY be used in conjunction with a power commander.
I havent used the LM2 setup.....but I would think any wideband should work for monitoring A/F and then use the power commander to adjust.
The Following User Says Thank You to VtecGSR95 For This Useful Post:
OuttyXMR (12-30-2010)
Old 12-30-2010, 03:23 AM
Member #13503
After further reading about the PCV, LCD-200, and the autotune, I am under the impression that the LCD-200 w/SD Card can be used for data logging the AFR. Is this correct.
Old 12-31-2010, 02:39 AM
Member #13503
Well DJ got back with me and the PCV, Autotune AT-300, and LCD-200 w/SD Card will allow you to log data. So I will be able to perform a dual cylinder tune and then go back and fine tune the lower TPs. So that is the setup I have decided to go with can't wait to get started.
Old 01-03-2011, 06:48 PM
norsepeak's Avatar
Member #858
View norsepeak's Photo Gallery(0)
I went with the PC5 and LM-2 for the data loggin ability and tuning. I got a great deal on the LM-2, and I figure I can use it on my sleds and pick-up truck too....cause I can't leave things stock...
'08 Renegade 800, Full HMF, Mr.RPM cams, PC5-dual tune w/LM-2, 09 intake, EHS lid, full ricochet skids, Warn 2500xt, Symtec hand/thumb warmers, CVtech primary, STM secondary
'07 Outlander 500 XT, Richochet skids, Symtec hand/thumb warmers, Gorilla winch, CVTech modded secondary, 2000 miles
'10 800 Summit 154 Hillclimb-clutched/piped
'09 600 Etec Summit 146
'03 CRF 450
CVtech-Airdam dealer, Amsoil dealer
Klim/HMK dealer
WPS/Parts Unlimited dealer
Custom metal fab
Old 05-19-2011, 03:32 AM
Member #15571
View 2011XMRBrad's Photo Gallery(0)
What do I really need to do after I install a snorkleyouratv kit and a slip on hmf swamp xl pipe? I don't plan on doing any more mods. Atleast none to affect my fuel/air ratio.
Old 05-19-2011, 04:23 AM
PHILLIP66's Avatar
Member #11824
View PHILLIP66's Photo Gallery(0)
I just put the pc5 on mine when I went with the swamp series XL.My dealer programmed it for me.I'm happy with it.
2011 OUTLANDER 800r Xmr
HMF SWAMP SERIES XL/PC5
CVTECH CLUTCH
WHOOLIE SHOP WET TUNES/FREESTYLE AUDIO
OUTLAWS 2's
Old 05-24-2011, 05:15 AM
Mr Xmr's Avatar
Member #16402
View Mr Xmr's Photo Gallery(0)
How much does PC5 and exhaust system from your dealer? Are you running with the original air filter?
atv 800 twin tune tps
atv exhaust tune advice
atv tuning tool
autotune at-300 install pcv
camam 800r tuning
can am 800 lm2 wiring
data logging using pcv
dual tuning outlander auto tune at-100
how to tune a atv
lcd-200 to work with pcv
lm2 tuning -linndrum
outlander 2 tuning photo
pc-v autotune or wideband 2
pcv autotune logging
pcv lcd-200 data logging
pcv tuning for 07 can am 800
power commander autotune wiring
power commander lcd-200 can am
power commander wb2
setup lm-2 atv
New purchase yukonsly ATV Tires and Wheels 2 05-07-2010 01:57 PM
Need advice on ATV Purchase! chappy07renegade800 Can-Am / BRP 6 04-06-2010 08:46 AM
Purchase of Outlander 800 max..what yr? conflag Can-Am Outlander 15 07-23-2009 03:23 PM
S x S purchase Russell RUVs / UTVs / SxS 12 05-04-2009 07:52 AM
Pre purchase questions rlcowder Can-Am / BRP 16 09-21-2006 02:47 PM
