fuel grade???
This is a discussion on fuel grade??? within the Dyno Reports | Tuning Center forums, part of the Can-Am Tech Area category; I run 91 octane in my 05 DS650. Is it safe to run 94 octane?...
Go Back   Can-Am ATV Forum > Can-Am Tech Area > Dyno Reports | Tuning Center
Old 01-29-2012, 05:36 PM
First Name: Love to live on the edge!
Member #20556
View pops29's Photo Gallery(0) Send a message via MSN to pops29
Question fuel grade???
Old 01-29-2012, 05:39 PM
WiNdGaDe800's Avatar
Why? The lower the octane the more power you have...
Do you have a reason to need high octane, such as high compression motor work?
Old 01-29-2012, 05:51 PM
Member #20556
I have some, and don't want it to go to waste. No motor work, YET... Planning on a BIG BORE kit.
Old 01-29-2012, 05:55 PM
I'd just mix it with lower octane gas to use it up then.
Old 02-02-2012, 08:06 PM
KWIK Racing Inc.'s Avatar
First Name: my 07 rene got stolen in june of 2010 and now i have a 2010 rene Xxc
Member #2600
View KWIK Racing Inc.'s Photo Gallery(18)
you only need octane if the engine requires it.
by that i mean this... as compression goes up in an engine, it reqiures higher octane feul so the motor does not deatanate or ping itself to death. Our motors are low enough compression that premium feul is a waste. will not give you any more power and has even shown on dyno results that it can hinder hp figures, if to high of a octane rating is used. (car related)
You don't get more or less power using regular over premium or visa versa.
if your compression is to high for regular, then you will ping and lose power, therefore wanting to use higher octane fuel to make the engine not ping and produce the power it can.
2010 RENE Xxc - FLEXX BARS - HEATED H/T - OURY GRIPS - ROXX 2'' ANTI-VIBE RISER - ATR STEER-STEM BUSHING -STEALTH SNORKELED - D2 GUARDS - QUADTECH SEAT COVER - HITCH - CUST. RACK - B/H 1.0 TIRES (CUSTOM SIPPED) - ATR FRAME SPINE - BC GRAPHICS - HYGEAR SUSPENSION KYB PRO SHOCKS - CRANK BUMPER - VIPER EL3000 WINCH - RICOCHET SKIDS - KWIK RACING SLEEVED AND REINFORCED STEERING STEM - BOPP A-ARM REAR SUPPORT BRACE - BOPP DUDDING FRONT END POWDER COATED AND SWAY BAR TABS WELDED ON - RED POWDER COATED & REINFORCED FRAME - ATR HD TIE RODS/ENDS - EHS AIR BOX LID - TWIN AIR c/w OUTERWEAR SOCK - 51mm TAPERED TROTTLE BODY - QUADWORX INTAKE - BOM SUPER MAGNUM CAMS - GO HARD / NPP TRUMOIL SLIP ON PIPE c/w OEM CERMAIC COATED HEADER AND O2 BUNGS WELDED IN - CVTECH PRIMARY AND STM ROLLER SECONDARY WITH 45 STR. HELIX/GOLD SPRING - Q-JECTION ECM - DYNOED/TUNED BY GET TORQED 70.39 RWHP 47.29 FT.LBS.TORQUE. TOP SPEED 88MPH OR 141 KM. REV LIMIT 8600 RPM/SHIFT OUT IS 8000 RPM. 5 DEGREE'S ADVANCE TIMING
Old 02-22-2012, 02:22 PM
Hammyabeer's Avatar
Member #21038
View Hammyabeer's Photo Gallery(0)
I've run alot of dyno tests with fuel and as stated above a higher octane fuel will decrease your hp.I tested 100 octane sunoco in my ninja and it lost 4hp to 89 octane.Without the compression your wasting your money.
Old 02-23-2012, 06:36 AM
choPppps's Avatar
Member #3820
View choPppps's Photo Gallery(0)
But, to answer your question, it won't hurt it unless you hear pinging (doubt it would knock as that is usually from a lower grade).
2010 800 Can-Am Max XT-P
HPG's up front
26" ITP Terracross
.. only faster, is fast enough!
The Following User Says Thank You to choPppps For This Useful Post:
Big Papa (02-23-2012)
Old 02-23-2012, 11:09 AM
uprightshark's Avatar
First Name: Paul
Member #19331
View uprightshark's Photo Gallery(0) Send a message via MSN to uprightshark
What about Ethenol? Right now it is hard to find a dealer selling regular gas without 10% E.
I remember the dealer warning me about Ethenol in my Outtie, so I have avoided it with supreme gas. Is this stupid?
Uprightshark
SHARK WARNING! Keep your wheels out of the water!
My Ride: White 2013 Commander Limited
BRP full skids, rock sliders, tanneau cover, Dalton Clutch kit and mirror.
Old 02-23-2012, 11:45 AM
Big Papa's Avatar
Member #15495
View Big Papa's Photo Gallery(0)
^^^^I wouldn't say stupid. There are lots of opinions on it as well as misinformation.
I've posted this before (and took crap for it) but I think the PHDs who did the study have an opinion that is worth more than what some dealer has to say. http://pods.dasnr.okstate.edu/docush...AE-1746pod.pdf
I am by no means a proponent of ethanol. I think it is a waste of corn and it drives food prices up, but I also don't like anecdotal evidence being passed off as fact.
2011 Renegade 500
2005 Honda 400EX
2004 Yamaha Grizzly 125
The Following 2 Users Say Thank You to Big Papa For This Useful Post:
DaveB (02-23-2012), uprightshark (02-23-2012)
Old 02-23-2012, 03:57 PM
RORER-714's Avatar
Member #4904
View RORER-714's Photo Gallery(10)
You can get 89 octane in the US without ethanol,but most places the premium/supreme has 10% ethanol as well as 89.
\'06 Outlander 800 Camo,2" Snorkeled,HMF,Crutchfield 1&2 Extreme's,28" 589's
\'07 Renegade 800,Snorkeled,27" Executioners
1000x commander fuel grade octane
2013 can am with high octane fuel
89 fuel in high compression atv
89 octane renegade 500
can am commander fuel octane
can am commander what octane fuel to use
can am fuel type
can am renegade 1000 gasoline octane
can+am atv
can+am commander
gas octane can am 800
renegade 1000 fuel octane
renegade 1000 gas grade?
renegade 800 fuel octane
what octane canam 650
Tent trailer up grade Dmwjr6 General Chit Chat 6 10-22-2011 09:28 PM
New Oil Grade PAOuty Can-Am / BRP 4 04-12-2010 04:50 PM
6th Grade Biology Class Malinda1 Humor 0 02-07-2007 09:04 AM
What type and grade of oil for you 800 Traxterman Can-Am / BRP 43 09-25-2006 08:16 AM
