dyno trip plans
This is a discussion on dyno trip plans within the Dyno Reports | Tuning Center forums, part of the Can-Am Tech Area category; I have a 1000xt with a swamp xl and a syatv kit. What do I need to insure my bike is running correctly? Want to ...
Go Back   Can-Am ATV Forum > Can-Am Tech Area > Dyno Reports | Tuning Center
Old 03-21-2012, 05:07 PM
Member #15934
View GOFORIT's Photo Gallery(0)
I have a 1000xt with a swamp xl and a syatv kit. What do I need to insure my bike is running correctly? Want to make sure the A/F is correct or close. Will a PCV do the trick? Do you have to have a dyno with a PCV? Just want to make sure my bike is running correctly or close.
2012 1000XT, Ricochet skids, Pitbull Growler 8 ply radial tires, ITP 212 14" black wheels, BRP fox shocks/springs, SYATV snorkel just in case,HMF Swamp XL exhaust and a Wally mirror, Dalton clutch kit here but not installed, extreme bumper here not installed.(SOLD)
2010 650XT, SYATV snorkels, HMF utility muffler 27" Interco Reptiles, ITP 108 black 14" wheels (SOLD)
2011 Honda Rancher ES, 27" Interco Swamplite tires, 14" ITP 108 wheels(SOLD)
Old 03-21-2012, 05:28 PM
WiNdGaDe800's Avatar
I'd go with the PCV with Auto-Tune. The Auto-Tune will cost as much as a dyno tune but with auto-tune you can tune all day everyday, add a mod... tune it again.. all free after the initial purchase. A dyno is only one time..
Once you get it, just run your bike at each throttle position until the rpm's stop climbing, then stop and go to the next throttle position until the rpms stop climbing, and repeat.
  #13
Old 03-23-2012, 07:39 AM
Member #15934
Is the PCV waterproof or can it be waterproofed easily?
  #14
Old 03-23-2012, 08:06 AM
Pelican works great, I did notice though that it gets hot inside that little box, but could be where I have it mounted too I suppose.
  #15
Old 03-24-2012, 10:50 PM
outty1000's Avatar
Member #17274
View outty1000's Photo Gallery(0)
Well I'm pumped for my dyno tune trip. Got my scorcher tires mounted on stock wheels the pro mod wheels don't clear the brake caliper. Added a little weight to the clutches for the lower elevation, current shiftout is 7,000 rpm's @4,300' so the elevation drop to 1,300' should dial it right in. Will be leaving at 3am Monday morning and arrive around 8 am. Hope its all worth it in the end, it will be a long day with the turn around so I can get back to work Tuesday. Tried to schedule for Saturday but they don't dyno tune on weekends.
2012 Outlander 1000R XT, Muzzy duals (black), PCV, auto tune on closed loop, QSC clutch, Elka stage 4's. 2010 Polaris 850XP LE, 2005 840 BF
  #16
Old 03-25-2012, 08:11 PM
atvmodster's Avatar
Member #1859
View atvmodster's Photo Gallery(0)
keep us posted man
2012 Camo commander 1000xt
Visco loc QE, Sport roof, Rear wind screen, Half windsheild, Spring spacers, K and T black box, Airdam CV-tech primary and machined secondary
2012 outlander 1000xt
Fan override switch, 1'' spring spacers, Snorkaled, Airdam cvtech primary with machined secondary, Rad relocate, Twin Air filter, Dual Muzzy exhaust, PCV w/autotune and 28" Mega mayhems coming soon!
Previous atv's
09 Rzr 800, 10' Can-am renegade 800xxc, 08 Thundercat 1000, 06 can-am outty 800xt, 05 grizz 660, 02 kawi 650, 00 Sportsman 500
  #17
Old 03-26-2012, 07:39 PM
Member #13972
View Superbri's Photo Gallery(0)
All dynos are different, even the same make there are diffences and too many variables unless they are put on the same dyno with the same tires.
The Following User Says Thank You to Superbri For This Useful Post:
outty1000 (03-27-2012)
  #18
Old 03-26-2012, 07:44 PM
Member #9933
View ubergod's Photo Gallery(0)
Your clutches could use some tuning man..
You have almost 500 rpm of over rev for one thing.
I bet theres some more power in a proper clutch tune
'12 Outlander 1000XT
29.5x11 OL2's
Full Dual Muzzy
PCV w/Custom Tune
QSC Primary/STM Secondary
Custom Snorkels/Rad Kit
'10 Renegade XXC (Sold)
http://www.youtube.com/user/PunisherGod1?feature=mhee
The Following User Says Thank You to ubergod For This Useful Post:
  #19
Old 03-27-2012, 12:20 AM
outty1000's Avatar
Member #17274
I sent the maps to Adam and he said that 300-400 over rev is all by design as long as it's not hitting the rev limiter that's where the QSC shines and gets the big hole shot. Look where the peak hp comes right after the over rev at 30 mph. You feel it riding too, it's like being slung out of a sling shot those first 30' or so. He said clutch looked real good.
  #20
Old 03-27-2012, 11:36 AM
VFORCEJOHN's Avatar
First Name: I'm VFORCEJOHN
Member #18764
View VFORCEJOHN's Photo Gallery(0)
Overrev on bottom end is TOO LITTLE BASE WEIGHT. That's exactly what you have here. this is causing a forward push loss and may feel good, but time it and you'll see it sounds like you are going faster but you aren't.
try adding about 2-3 grams of base weight to the area closest to the pin. big motors like lots of base weight especially of the clutch weight is highly curved (like an EPI kawy weight or polaris weight)
instead of overrevving, you'll get the PUSH forward. and it should also boost power. 840cc can am's with STM clutching I can gain 3-5 rwhp by removing the overrev and having it overrev about 100-200 rpm. power is flat and linear and it takes off like a rocket.
Think of running a spring like a HPD plain in a stock Brute. it feels like it gained 10 rwhp. but it's actually slower than the stock spring
I can't believe they didn't dial in your top end. that's where all the power lies. I'll do 100 runs if that's what it tales messing with -1 to +1 all over the top end.
look at that a/f chart. that's not that great of a tune. if my line isn't ruler straight it isn't tuned.
that a/f varies from 13.2 to 13.7 up and down. and this is at WOT under the load of the roller
that line should be 12.6-12.8 where I find the max power on my dyno.
How about front vs rear cylinder a/f readings. it takes me 3-4 HOURS to fully map out a dual cylinder tune and I know exactly what I'm doing.
sounds to me like he got you on and off the rollers as quiclky as possible and didn't dwelve into the fine tuning aspect of what the dyno is really for.
Sell that autotune, get yourself an LM-2 and datalog everything real world and make your adjustments from there. I dyno first, then I ride and datalog and adjust from there if needed
John
www.vforcejohn.com Pipes, FI tuners, Clutching, Custom Dyno tuning for all setups. email vforcejohn@yahoo.com
atv dyno tune cost
New Year Plans PHILLIP66 General Chit Chat 8 12-19-2011 02:18 PM
my plans, need your opinions! millerdui Can-Am Outlander 10 08-18-2009 06:11 PM
ATV Trailer Plans Offcamber ATV Tires and Wheels 10 09-13-2006 07:17 PM
Change of plans... Swamp Rat 74 Can-Am / BRP 3 05-23-2006 05:38 AM
