View Poll Results: Throttle Wedge Questions.
Removed my wedge and love it!
6 |
9.84% |
Removed my wedge and put it back in.
2 |
3.28% |
Haven't removed my wedge but am interested in this.
53 |
86.89% |
04-07-2012, 08:42 PM
Yes, In 5 hours I've gotten 3 pop's out the exhaust after letting off from 10-15% throttle. So it's definitely effecting things, that's why I want Renelander to do this so I can see his before and after map so I can adjust mine somewhat close.
So if you want to be the guinea pig...
04-07-2012, 11:56 PM
Member #1859
Id like to hear from more 1000 owners that do it first before i rip it all apart. It feels nice to have it all back together...
2012 Camo commander 1000xt
Visco loc QE, Sport roof, Rear wind screen, Half windsheild, Spring spacers, K and T black box, Airdam CV-tech primary and machined secondary
2012 outlander 1000xt
Fan override switch, 1'' spring spacers, Snorkaled, Airdam cvtech primary with machined secondary, Rad relocate, Twin Air filter, Dual Muzzy exhaust, PCV w/autotune and 28" Mega mayhems coming soon!
Previous atv's
09 Rzr 800, 10' Can-am renegade 800xxc, 08 Thundercat 1000, 06 can-am outty 800xt, 05 grizz 660, 02 kawi 650, 00 Sportsman 500
05-07-2012, 01:04 PM
Member #8068
If i remove wedge on a stock outty xxc will i need a tune
2011 outlander xxc
Engine ice, 25" bighorns, dalton clutch kit...more to come.
2 factory built ds 450s
5 ny state pro extreme dirt track championships, 4 national extreme dirt track championships
05-07-2012, 04:01 PM
Not with a stock exhaust I wouldn't think. Are you 100% stock?
You could try and mod it like I did if your worried about anything.
If your stock I would go with adjusting your clutch before I messed with this mod. I would suggest upgrading your Primary Spring to a Tan spring from Dalton, or if you like high engagement go with green/yellow. Then come back and ask.
05-07-2012, 04:25 PM
Member #8068
Ok thanks.
2011 outlander xxc
05-27-2012, 08:10 AM
Did you fall down Powerstroke Cowboy ?
06-04-2012, 07:27 AM
Member #8068
i removed the wedge...do i leave the two holes empty where the screws went in?
2011 outlander xxc
06-04-2012, 09:15 AM
First Name: I'm VFORCEJOHN
Member #18764
If you want it to idle at 4000 rpm leave the holes open.
I did this to my 1000, I saw about 1-1.4 rwhp gain in the lower speeds. you DO have to add a ton of fuel to the front cylinder. which this seems to affect most.
just in the 5-25% throttle range I saw the most drastic changes.
John
06-04-2012, 11:46 AM
Member #8068
so with this mod i need a fuel controller? this might be why it wont stay running.
2011 outlander xxc
06-04-2012, 05:11 PM
John
You did "MY (and Renelander's)" mod or you removed it completely?
You will need to add fuel somehow, yes, and this is a NEED situation, not a "want" situation, but you NEED to get your holes soldered shut aswell, or do like MY mod and mill the wedge.
800r throttle wedge modification, 800r throttle wedge modification?, can am commander removing wedge, can am outlander 800 mods, can am throttle body wedge mod, can am throttle box, can am throttle screw, can am throttle wedge, can am wedge, can am wedge mod, can-am wedge removal, outlander 800 needs more throttle response, outlander wedge mod, renegade intake wedge, where is the throttle adjustment screw on a can am outlander 800
