Back from Dynojet in Vegas
This is a discussion on Back from Dynojet in Vegas within the Dyno Reports | Tuning Center forums, part of the Can-Am Tech Area category; done...
Go Back   Can-Am ATV Forum > Can-Am Tech Area > Dyno Reports | Tuning Center
Old 04-02-2012, 10:32 PM
outty1000's Avatar
Member #17274
View outty1000's Photo Gallery(0)
Default Back from Dynojet in Vegas
done
2012 Outlander 1000R XT, Muzzy duals (black), PCV, auto tune on closed loop, QSC clutch, Elka stage 4's. 2010 Polaris 850XP LE, 2005 840 BF
The Following 3 Users Say Thank You to outty1000 For This Useful Post:
atvmodster (04-05-2012), hedge (04-03-2012), WiNdGaDe800 (04-03-2012)
Old 04-03-2012, 07:22 AM
hedge's Avatar
Member #7142
View hedge's Photo Gallery(0)
cool, I read on the other forum that they didn't let you watch. too bad, that'd be cool. When I was at Get-torqed they had a bike on the dyno, was pretty hard to keep the grin off my face. I was in a hurry or I would have hung around and watched for a bit.
Looks like you're making pretty good power and I like that flat graph, I am installing the same pipes on friday so I'm getting pumped now, hopefully that tune will be available soon.
Maybe I'll be a little closer with those renegades.
2012 Outlander 1K, 28" Zillas on 14" MSA Vice beadlock rims, Ricochet skids, Muzzy Dual Full system + PC5, Elka Stage 4 shocks
http://www.youtube.com/user/hedge8888
Old 04-03-2012, 05:47 PM
WiNdGaDe800's Avatar
Very Cool, it is good to see that they actually do this good of tuning for their "pre-set" maps on their site, very good to know!!!
Old 04-03-2012, 06:28 PM
I haven't used any maps from PowerCommander's site, but I may have to test a couple of them as I notice they are drastically different than the map I'm currently using.
Old 04-03-2012, 06:59 PM
Member #9933
View ubergod's Photo Gallery(0)
Did they do a dual tune?
'12 Outlander 1000XT
29.5x11 OL2's
Full Dual Muzzy
PCV w/Custom Tune
QSC Primary/STM Secondary
Custom Snorkels/Rad Kit
'10 Renegade XXC (Sold)
http://www.youtube.com/user/PunisherGod1?feature=mhee
Old 04-04-2012, 10:19 AM
fstang24's Avatar
Member #19585
View fstang24's Photo Gallery(0)
So stock baseline tune is 62hp correct? You got it up to 68hp with the muzzy and pc5. So did you gain 6hp over stock with just the muzzy or the muzzy and pc5 combined?
2012 Can Am Renegade 1000
MUZZY DUAL EXHAUST
POWER COMMANDER V
RICOCHET SKIDS
CAN-AM HANDGUARDS
14" STI HD3 WHEELS
28" OUTLAW 2'S
DALTON CLUTCH KIT
MR.GO FAST"
Old 04-04-2012, 06:34 PM
Member #9933
I would love to see what the map looks like..
29.5x11 OL2's
Full Dual Muzzy
PCV w/Custom Tune
Old 04-14-2012, 09:41 PM
KWIK Racing Inc.'s Avatar
First Name: my 07 rene got stolen in june of 2010 and now i have a 2010 rene Xxc
Member #2600
View KWIK Racing Inc.'s Photo Gallery(18)
how you should think of this is the pipe is making all that hp...but the bike has to be tuned to bring out the hp that the pipe can make
the pc5 is a tool to maximize the hp that each part is capable of doing. the pc5, really does'nt make hp, it tunes the motor to make it with whatever mods you have..
but in general, you see only about 2-4 rwhp more once tuned...
another thing you have to look at is every bike is different..same motor..but.. e.g is on the 800's they are seeing totally stock rwhp vary from 46 - 51.. yes that much of a difference.. same dyno.. same dyno tires, everything the same and stock bikes.. just one makes more than the other...
imo you are wasting your time with a generic map.. you mite think its good or ok.. but is it really? for YOUR machine.. that you don't know.. the map works only good for the bike it was written..
Looking at your sheet, your hp starts falling off to soon.. the flat line should continue till shift out.. they never played with your clutching, did they? getting that shift out a touch higher would of probably seen another horse or two.
2010 RENE Xxc - FLEXX BARS - HEATED H/T - OURY GRIPS - ROXX 2'' ANTI-VIBE RISER - ATR STEER-STEM BUSHING -STEALTH SNORKELED - D2 GUARDS - QUADTECH SEAT COVER - HITCH - CUST. RACK - B/H 1.0 TIRES (CUSTOM SIPPED) - ATR FRAME SPINE - BC GRAPHICS - HYGEAR SUSPENSION KYB PRO SHOCKS - CRANK BUMPER - VIPER EL3000 WINCH - RICOCHET SKIDS - KWIK RACING SLEEVED AND REINFORCED STEERING STEM - BOPP A-ARM REAR SUPPORT BRACE - BOPP DUDDING FRONT END POWDER COATED AND SWAY BAR TABS WELDED ON - RED POWDER COATED & REINFORCED FRAME - ATR HD TIE RODS/ENDS - EHS AIR BOX LID - TWIN AIR c/w OUTERWEAR SOCK - 51mm TAPERED TROTTLE BODY - QUADWORX INTAKE - BOM SUPER MAGNUM CAMS - GO HARD / NPP TRUMOIL SLIP ON PIPE c/w OEM CERMAIC COATED HEADER AND O2 BUNGS WELDED IN - CVTECH PRIMARY AND STM ROLLER SECONDARY WITH 45 STR. HELIX/GOLD SPRING - Q-JECTION ECM - DYNOED/TUNED BY GET TORQED 70.39 RWHP 47.29 FT.LBS.TORQUE. TOP SPEED 88MPH OR 141 KM. REV LIMIT 8600 RPM/SHIFT OUT IS 8000 RPM. 5 DEGREE'S ADVANCE TIMING
Old 04-14-2012, 10:11 PM
Member #2600
As for an example...
i just was up at torqed in edmonton a few weeks ago and we installed some new bom cams.... in my dyno chart the bottom run is the base run with the new cams. all other mods stayed the same....
i left last fall with a final rwhp of 65.36, i believe and from just swithing to these cams gave me just under 1/2 hp more...but look at the last line how all over the place it is...
then look after we tuned with my aftermarket ecu... gained close to 4 1/2 rwhp over the base run... and gained over 3 ft lbs of torque after tuning...
look at the green line, how quite smooth it is and even thou you lose hp as you go up in rpm, you want to minimize this as much as you can and try to keep to peak power all the way up in the mph scale.
Old 04-14-2012, 10:19 PM
outty1000's Avatar
Member #17274
They didn't touch the clutching.
2012 can am outlander 1000 muzzy review
can am bom cams
can am outlander 1000 dynojet
can am renegade 1000 dyno jet
dynojet can am 1000
quadtech renegade 800 seat
the bom super mag camshafts
Night Race outside of las vegas bflochp Rides and Events 1 06-26-2010 11:19 AM
Hello from Las Vegas bflochp Please Introduce Yourself 16 04-30-2010 08:54 AM
New Member from Las Vegas, NV no1huskerfan Please Introduce Yourself 9 04-13-2010 07:50 AM
wheelin' near Vegas ? Effer General Chit Chat 2 03-16-2007 07:24 AM
Catholics in Las Vegas .....a little trivia Malinda1 Humor 0 02-26-2006 10:40 PM
