Quote: Originally Posted by
Nistagmo
One question guys.
I like the OEM rims but the center cap is so simple.
Would one of this fit?
If those are for the ITP SS series wheels then no...they are a larger diameter. I'm not sure if any of the ITP ones will fit,you'd have to look at how the stock ones are held in and then probably measure the diameter and call ITP and see if they have any that will work. I haven't seen any measurements listed on the net..only what ITP wheels they are for.
Edit....
Something to think about though is the design of the stock wheels doesn't require a cap per se because of the offset. Any raised cap would likely stick out past the edge of the wheel and 1) Get knocked off and 2) Probably not look so great..jmo.
