wheel bearing greaser tool and axle nut torque - Can-Am ATV Forum
 7Likes
post #1 of 66 Old 12-05-2018, 08:44 PM Thread Starter
Hello Everyone:
I need to purchase a wheel bearing greaser tool for my 2018 Can Am defender HD-10. Looking for the model that you can grease bearings without removing axles . What tool would be the best too get.
Also what is the torque on axle nuts.
Thank You kenner
kenner is offline
post #2 of 66 Old 12-06-2018, 10:12 AM
Chief...'s Avatar
Garage
Don't believe there is any tool to grease them without removing the axle (the only atv I have seen that can do that is the Polaris). On the Can Am's you have to remove the axle but you do not have to remove the bearing from the knuckle. https://www.ebay.com/itm/Can-Am-Comm...diHL:rk:1:pf:0 It's a must have tool if you do your own maintenance. My service manual says 151lbf*ft =/- 11 for my 6x6, don't know it that would apply to yours.
2015 Outlander 1000 6x6 XT
2012 Outlander 1000XT (Sold)
2004 Honda Rincon (Sold)
Chief... is offline
post #3 of 66 Old 12-06-2018, 05:13 PM
Born2atv's Avatar
There is a greaser tool for Can-Am. There is also a You-Tube videos out on how to use them. I seen the video and it was a Maverick front hub and they did not have to remove as much as on the ATVs. I would use Google to find out more on the Wheel Bearing Greaser tool.
Born2atv is offline
The Following User Says Thank You to Born2atv For This Useful Post:
Chief... (12-08-2018)
post #4 of 66 Old 12-06-2018, 09:06 PM
Chief...'s Avatar
Garage
I stand corrected, https://www.ebay.com/itm/39mm-Wheel-...db5o:rk:2:pf:0 it looks like the side-by-side have such tool.
Chief... is offline
post #5 of 66 Old 12-07-2018, 05:28 AM
Spawn's Avatar
Garage
Will this one fit my 2015 Outlander or is it just for the maverick?
2015 Outlander XMR 1000
BRP Extreme Bumper
BRP Trunk
BRP Passenger Seat
Ricochet Skids (Black Anodized)
Full Muzzy Dual Exhaust
Power Commander V
VForceJohn Tune
Race Driven Brake Pads
Fan Mod
Wetsounds 10" Stealth Sound Bar
MR RPM Valve Covers
Mud N Wheels Rear Drive Shaft
Spawn is offline
post #6 of 66 Old 12-07-2018, 05:44 AM
Garage
I just greased my bearings on my 18 outty max. You do have to remove the axle, lower ball joint, and lower shock support to make it easy to get the axle out but it is surprisingly easy and quick process. For the amount of grease that goes in there it is well worth it. Plus you can check your brakes while your there. My bearings took about 20 pumps of grease to fill.
jp413 is offline
post #7 of 66 Old 12-07-2018, 09:13 AM Thread Starter
I did purchase the greaser tool that chief found on ebay, will let you know how it works.
Any idea of axle nut torque??
kenner
kenner is offline
post #8 of 66 Old 12-07-2018, 12:37 PM
Chief...'s Avatar
Garage
I WISH, but alas, no I donít think so.
If you take a look at the difference between these 2 videos you can see that on the defender the axle has room between the shaft and the bearing so they can slide the tool into the bearing without removing the axle, but on the outlander there is little to no room between the shaft and the bearing and the axle has to be removed.
turbines1 likes this.
Chief... is offline
The Following User Says Thank You to Chief... For This Useful Post:
Spawn (12-07-2018)
post #9 of 66 Old 12-07-2018, 01:48 PM
Spawn's Avatar
Garage
Is it possible to remove the axle from just the wheel hub without removing it from the differentials?
BRP Extreme Bumper
BRP Trunk
BRP Passenger Seat
Power Commander V
VForceJohn Tune
Fan Mod
MR RPM Valve Covers
Spawn is offline
post #10 of 66 Old 12-07-2018, 02:02 PM
Born2atv's Avatar
When you all watch the videos, they also tell you there is a different size of tool. Can-Am has just two, one that fits the Outlanders and one for Side x Sides. I bought mine from Royal Distributing and a 1 1/6 ' socket. Polaris is the only other manufacture I've seen so far that also has this tool. Like I said, it is a lot easier to grease the Side x Sides.
Born2atv is offline
Spawn (12-07-2018)
Go Back   Can-Am ATV Forum > Can-Am ATV Discussion > Can-Am Defender
