QSC REV X Primary Clutch - Impressions? - Can-Am ATV Forum
post #1 of 11 Unread 04-07-2019, 03:47 PM Thread Starter
So I have a 2014 Outlander XMR 1000.
Just installed a QSC Rev X Primary Clutch with stock secondary, and I wasn't overly blown away by the difference. Maybe it was all the snow and wet conditions on the ground... I did find myself with minimal traction.
Has anyone felt the same? I always see on the forum, people saying it is a night and day difference.
weezy is offline
post #2 of 11 Unread 04-07-2019, 05:02 PM
Spawn's Avatar
Garage
Interested to read comments...Iím like you, I thought that a new primary would make a ďnight and day difference ď???...and the front end would stand up with a blip of the throttle???.....maybe yours isnít set up correctly with the proper weights???
2015 Outlander XMR 1000
BRP Extreme Bumper
BRP Trunk
BRP Passenger Seat
Ricochet Skids (Black Anodized)
Full Muzzy Dual Exhaust
Power Commander V
VForceJohn Tune
Race Driven Brake Pads
Fan Mod
Wetsounds 10" Stealth Sound Bar
MR RPM Valve Covers
Mud N Wheels Rear Drive Shaft
Spawn is online now
post #3 of 11 Unread 04-07-2019, 05:17 PM Thread Starter
The shop I bought it from asked me what size wheels and tires I had so they could set it up, and they are reputable so I assume it is. Next time I am out I will give QSC a call with my RPM/Speed info and see what they say.
weezy is offline
post #4 of 11 Unread 04-07-2019, 06:40 PM
Spawn's Avatar
Garage
Looking forward to hear the outcome bc Iím interested in getting a qsc primary as well but I donít want to if there isnít that big of a difference that others talk about..
BRP Extreme Bumper
BRP Trunk
BRP Passenger Seat
Power Commander V
VForceJohn Tune
Fan Mod
MR RPM Valve Covers
Spawn is online now
post #5 of 11 Unread 04-07-2019, 07:03 PM
iam_canadian22's Avatar
The minimal traction will make it seem not impressive as you'll just spin alot more. Also keep in mind the preset setups are just average and often require fine tuning as every bike is different. Next ive tested twice, qsc raptor on my 15 xmr 800 and rev x on my mav xmr and both had much better gain when paired with a stiffer secondary spring.
Sent from my SM-G960W using Tapatalk
16 maverick xmr: sport low bypass, amsteel blue synthetic rope,
to come: ALOT
'15 xmr 800: 29.5" s/w OG oulaws, Sirius led light bar, can am/yoshimura slip on, dobeck gen4 afr+, QSC primary SOLD
iam_canadian22 is offline
post #6 of 11 Unread 04-07-2019, 10:21 PM
Dr_Z's Avatar
We tuned my Rev-X and had the weights way different than recommended. I had some creep at idle after I put in a new Mav belt this winter and set the weights back to the recommended. I lost a lot of top end power up at 6500 feet on tracks. My RPM would go up and then drop back down under load. I took some of the tip weight out and will need to test it, but it will be on tires as the tracks came off last weekend.
Point being, my experience on my 800 is that the weights were way off.
2011 Outty 800XXC
Dobeck AFR+, Hayden fan controller, QSC Rev-X primary/STM secondary, TORQ Locker
Powermadd hand guards, RotopaX 4 gallon, Symtec heated grips, Homemade UHMW skid
My YouTube page
(mostly unedited track rides)
Dr_Z is online now
post #7 of 11 Unread 04-08-2019, 08:40 PM
I just put a qsc on my 1000. Hell of a difference over stock. Although my stock primary had a pretty decent grove in it. I can spin my tires in the thickest peanut butter with no belt slip
Sent from my iPhone using Tapatalk
deanofay is offline
post #8 of 11 Unread 04-09-2019, 12:52 PM
25TH INFANTRY's Avatar
if its not set up properly with the correct shift out you could have lost performance. there are good shops out there that do a real good job most of the time but people do make mistakes and in the clutching game that is easy to do. first thing you need to know is what your shift out is. shift out is when you nail the throttle from a dead stop what does your RPM go to, this needs to be done on a hard surface like dry dirt or pavement in high gear? some of the bikes have a different shift out preference based on mods ect. my 2010 800 xxc with my mods is a 7500 rpm shift out, i think the 1000 like a little higher at 7800, i could be off on that and I'm not sure on the xmrs. if you have a low shift out your not in your power band and your leaving power on the shelf and if its to high of an RPM, again you'll be out of your power band. My rex x made one hell of a difference as well did my other bike with a cvtech.
2010 Renegade 800R XXC
2011 Outlander 800R XXC
25TH INFANTRY is offline
post #9 of 11 Unread 04-09-2019, 01:07 PM
altitude also plays a roll in clutching. I'm pretty close to sea level where i live at 500 feet but i usually ride in WV at 1500 to 2500 ft. i have my clutched for WV. so if your traveling to higher elevation to ride your RPM could be lower, every 1000 feet of elevation takes away 50 to 100 RPMs. Just something more to make this clutching game more confusing but once you get the hang of it you can make changes to the primary pretty easy. More arm weight brings down RPMs, less weight to the arm raises RPM.
post #10 of 11 Unread Yesterday, 04:42 PM
Spawn's Avatar
Garage
Did you get it straightened out Weezy?
BRP Extreme Bumper
BRP Trunk
BRP Passenger Seat
Power Commander V
VForceJohn Tune
Fan Mod
MR RPM Valve Covers
Spawn is online now
Holding crank on stator side Primary clutch removal? Limited Clutching 3 11-23-2018 04:16 AM
Primary & Secondary Clutch Change Up2NoGood Can-Am Outlander 17 06-13-2018 03:13 PM
2013 can am mav 1000r primary clutch Scottymaverick Can-Am Maverick 3 11-14-2017 10:37 AM
Help Needed - Primary Clutch Spring & Bearings outlanderLrider Can-Am Outlander 1 11-21-2015 11:07 AM
