Rear prop shaft U-joint won't come off - Can-Am ATV Forum
post #1 of 7 Old 04-15-2019, 07:56 PM Thread Starter
I wanted to remove my U-joints to replace them but they won't come off. I pushed with sockets like shown on some videos but it's as if the space between the yokes and the shaft isn't wide enough. I tried with channel locks to grab the end cap but I was only able to remove 2 out of the 8 caps even though the caps come out a max of 1/8 of an inch.
It won't move !
I've tried both u-joints, going right or left and nothing I'm at limit, cant't go further !!
HELP !!!!!!
Luc
Montreal, Canada
2016 Outlander 850 Max XT
2" lift removed after axle popping out
Much smoother ridding
Led bar cool !
Vwluca is offline
post #2 of 7 Old 04-16-2019, 02:17 AM
Chief...'s Avatar
Garage
Push the cap out as far as you can and get a vice grip and as tight as you can get it put it on the 1/4" of that cap that is pushed out and work it slowly back and forth while pulling it out. It's a PITA but it can be done.
2015 Outlander 1000 6x6 XT
2012 Outlander 1000XT (Sold)
2004 Honda Rincon (Sold)
Chief... is offline
post #3 of 7 Old 04-16-2019, 02:01 PM Thread Starter
Thanks again buddy !
Different subject !!!!
Can I use blue loctite on the bolts that hold the yokes to the diff and transmission ?
Will work this out tonight
Luc
Vwluca is offline
post #4 of 7 Old 04-16-2019, 02:26 PM
25TH INFANTRY's Avatar
Some U-joints love fight ya! i have had good luck with putting the cap in a vise and turning it. its a lot easier that way.
2010 Renegade 800R XXC
2011 Outlander 800R XXC
25TH INFANTRY is offline
post #5 of 7 Old 04-16-2019, 04:00 PM
Luc
Short answer is yes .
I use blue Loctite because I feel the yellow stuff is overkill .
Just be sure the threads ( male & female ) are free of oil before replacing the bolt .
Bonzo is offline
post #6 of 7 Old 04-16-2019, 06:41 PM
Chief...'s Avatar
Garage
Luc
My service manual calls for Loctite 648 which is High Strength, Rapid Cure, there are probably quit a few equivalences available.
Chief... is offline
post #7 of 7 Old 04-16-2019, 09:30 PM Thread Starter
Even with the caps sticking out almost 1/4 of an inch, they didn't move at all. Not even with vise grips, vise nor humongous channel locks. I even bent the handle on my vise !!!!!!
I ended taking 3/4" emery paper on a roll that I have. And on the cap, opposite of the one sticking out, the one that was inside the au joint, I wrapped an eight inch lenght of paper and did an up/down movement around the cap as to "sand" it and "reduce" it"s diameter. I then pushed it on the other side to make it stick out and now I was able to wiggle the cap off. Had to do this on all 8 corners !!!!
I ordered 2 original U joints but although they were in a BPR sealed bag with numbers, they were different. I guess that BPR CHANGED supplier !!!
I even had to grind a little bit one lip on one corner because the crosses wouldn't slide in between the holes. They looked like the ones from a Youtube video from ELEMENTAL ATV. I took his tip for the grinding. Thank God .
Now all done and will be putting my ride back on it's wheels .
Thanks to all for all the great help, videos and advise.
Luc
Montreal
Montreal, Canada
Led bar cool !
Vwluca is offline
Tips for rear prop shaft removal Vwluca Can-Am Outlander 11 04-12-2019 07:19 PM
wheel bearing greaser tool and axle nut torque kenner Can-Am Defender 61 12-26-2018 05:20 PM
Rear prop shaft removal Loxboy1 Can-Am Outlander 3 03-02-2017 10:41 PM
How to choose the suitable CV axle for your ATV or UTV on the market Baizhongmin ATV Product Reviews 0 05-03-2016 01:55 AM
rear prop shaft phased? Folgers Can-Am Renegade 6 03-20-2016 07:46 PM
