Outlander 850 - hmf qs and hmf fuel programmer - Can-Am ATV Forum
post #1 of 6 Old 04-19-2019, 07:34 PM Thread Starter
Bought them together and installed them tonight. Site I bought them from said the progrAmmer will be plug and play without the need to make adjustments as it will come programmed for my bike.
Installed them both tonight, and it's not running well. Gassing it hard it gets around 45mph and dies for a sec and picks up and then dies again.
At low rpm it runs better but barely spin the tires on Full throttle which isnt like what the stock exhaust would do.
steelejones1 is offline
post #2 of 6 Old 04-19-2019, 09:33 PM
Dr_Z's Avatar
Does it run better with the programmer disconnected? If so, you found your problem. Either the unit is faulty or you have a bad connection, bad ground or wrong program in it.
2011 Outty 800XXC
Dobeck AFR+, Hayden fan controller, QSC Rev-X primary/STM secondary, TORQ Locker
Powermadd hand guards, RotopaX 4 gallon, Symtec heated grips, Homemade UHMW skid
My YouTube page
(mostly unedited track rides)
Dr_Z is offline
post #3 of 6 Old 04-20-2019, 05:01 AM
iam_canadian22's Avatar
Double check all connections. Could be faulty unit as well, its happened. Also the whole plug and play without touching is nonesense. Every bike is different and will require slightly different fueling.
Sent from my SM-G960W using Tapatalk
16 maverick xmr: sport low bypass, amsteel blue synthetic rope,
to come: ALOT
'15 xmr 800: 29.5" s/w OG oulaws, Sirius led light bar, can am/yoshimura slip on, dobeck gen4 afr+, QSC primary SOLD
iam_canadian22 is offline
post #4 of 6 Old 04-20-2019, 06:27 AM Thread Starter
I did notice before putting plastics all back on. That when rvving the motor lights 2345 would go red. Is that normal?
post #5 of 6 Old 04-20-2019, 03:32 PM
25TH INFANTRY's Avatar
when you disconnect it you just need to remove the ground and it will go back to the stock fueling. i would double check what its set at and go from there. just check the instructions on how to do it its pretty easy and try the recommended settings. the settings can be close but if your at elevation that can change things and you may need less.
2010 Renegade 800R XXC
2011 Outlander 800R XXC
25TH INFANTRY is offline
post #6 of 6 Old 04-21-2019, 06:41 PM Thread Starter
That worked I must had a lose connection. U snapped all 4 and resnapped them. Unplugged the ground off battery. Plugged all back in and reconnected ground and it straightened up.
