Melted seat and fix - Can-Am ATV Forum
 9Likes
post #1 of 36 Old 05-02-2019, 03:44 PM Thread Starter
BOSSTANK's Avatar
Melted seat and fix
I purchased my 2015 Cam-am Outlander XMR used with about 170hrs on it. Well the seat fit all funky looking, itís was melted thatís why. I ordered a new seat and put 3 strips of heat shielding on it and put heat shielding where it was melted on the other seat.
Melted seat fit
New and old seat underneath
New seat with extra heat shielding fit
2015 Can-am Outlander XMR 1000R
2015 Kawasaki Teryx4
2001 Honda Rancher ES
BOSSTANK is offline
post #2 of 36 Old 05-02-2019, 04:00 PM
looking good!
FWIW, I've read that the exhaust heat and seat damage isn't so much from a lack of shielding or proximity to other things, as it is a result of the OE tune from BRP being a bit on the lean side. Leaner exhaust=hotter exhaust. Most of the "fixes" I've read involved a tuner or reflash to richen the mixture up a little.
DaveB, styk and purelybarbed like this.
Upgrades:
WildBoar Radiator Relocate
D2 Fender Flares
OPT7 C1 Lightbars 14" and 22"
SYATV Snorkels
Previous bikes:
07 Brute 785
07 Renegade 800
BombardierBomb is offline
The Following User Says Thank You to BombardierBomb For This Useful Post:
styk (05-07-2019)
post #3 of 36 Old 05-02-2019, 05:07 PM
Dr_Z's Avatar
You need a tuner or reflash like stated. I had a melted side panel and a melted gas tank on my 2011. Don't let things get worse. I got lucky mine didn't burn up. Mine runs a lot cooler now.
purelybarbed likes this.
2011 Outty 800XXC
Dobeck AFR+, Hayden fan controller, QSC Rev-X primary/STM secondary, TORQ Locker
Powermadd hand guards, RotopaX 4 gallon, Symtec heated grips, Homemade UHMW skid
My YouTube page
(mostly unedited track rides)
Dr_Z is online now
post #4 of 36 Old 05-03-2019, 12:09 AM Thread Starter
BOSSTANK's Avatar
Originally Posted by BombardierBomb View Post
looking good!
Yeah the guy that had the atv before me was running an HMF Performance pipe with no tuner. What’s crazy is the dealer installed the pipe on a new showroom atv with no tuner. When I purchased it from him I switched to a HMF Titan QS pipe and installed the HMF optimizer.
I messed with the first 3 settings and forgot what it came preprogrammed with... according to the HMF web site this is what I should set it too right?
BOSSTANK is offline
post #5 of 36 Old 05-03-2019, 07:53 AM
Dr_Z's Avatar
That would be a good place to start.
2011 Outty 800XXC
My YouTube page
Dr_Z is online now
post #6 of 36 Old 05-03-2019, 08:25 AM
I have the same quad, and the same damage to my seat, and had to replace the battery tray. Been looking into buying a new seat, how much it run you and where did you buy it? Running PCV right now so far so good, batteru tray holding up, and the aircraft grade heat tape i added is still there.
Mario Warszawik is offline
post #7 of 36 Old 05-03-2019, 09:22 AM
DaveB's Avatar
Originally Posted by BOSSTANK View Post
looking good!
Yeah the guy that had the atv before me was running an HMF Performance pipe with no tuner. Whatís crazy is the dealer installed the pipe on a new showroom atv with no tuner. When I purchased it from him I switched to a HMF Titan QS pipe and installed the HMF optimizer.
I would add 3.5-4 to Green mode....Green/Blue set at 1 or 1.5
I would add 5-5.5 to Yellow mode....Yellow/Blue at 2.5-3
Definitely 0.0 added in the Red mode....Red/Blue therefore doesn't matter.
BombardierBomb likes this.
Pain or damage don't end the world. Or despair, or f*cking beatings. The world ends when you're dead. Until then, you got more punishment in store. Stand it like a man... and give some back.
2016 Renegade 1000 XMR: "Suck My Wake II"
QSC primary, STM secondary, Yoshimura,
BRP Rad relocate, Monster EFI reflash,
Cecco post brace, Rigid LED, skids, blue plasma rope.
2016 Outlander 570L DPS: "Tank"
BRP snorkel and rad relocate, 27" Outback XTs,
LED, blue plasma rope, Fox shocks, Alpine Flex plow.
Past machines:
2012 Renegade 1000 XXC
2008 Outlander 400 EFI
2007 Outlander 800 XT
Lots of older non-BRP junk
DaveB is offline
post #8 of 36 Old 05-03-2019, 03:55 PM
25TH INFANTRY's Avatar
all can am atvs need the exhaust headers wrapped with heat tape. i have documented mine wrapped and not wrapped and there is a difference of 300 degrees. i would also just bit the bullet and get your ecm flashed by monster.
2010 Renegade 800R XXC
2011 Outlander 800R XXC
25TH INFANTRY is offline
post #9 of 36 Old 05-04-2019, 03:23 PM
Originally Posted by 25TH INFANTRY View Post
All can am atvs need the exhaust headers wrapped with heat tape.
Is that enough to avoid melting, or do you also suggest using insulation tape on the parts listed above? Adding tape to the exhaust pipe seems the cheapest and easiest option, no? But my most important question is if the engine is safe with a slip-on (as claimed) and no ECU tuning. Thanks.
JC
elptxjc is offline
post #10 of 36 Old 05-04-2019, 07:43 PM
Dr_Z's Avatar
Your engine may survive, but you will probably continue to melt plastic if you don't cool it down somehow. Any pipe that is more free flowing than stock will lean it out more and add heat. If I disconnect the AFR+ and just use the temp gauge, I can see 20F-30F degrees hotter just with the stock pipe.
I gave up on the exhaust wrap after trying 2 different kinds and neither lasted. I actually had better luck with the Hayden fan controller than the wrap before I put the AFR+ on it.
Insulating tape is a good thing to do. I have it everywhere the exhaust is near plastic.
2011 Outty 800XXC
My YouTube page
Dr_Z is online now
