Mounting gas can on front rack - Can-Am ATV Forum
 1Likes
post #1 of 11 Old 05-09-2019, 07:14 AM Thread Starter
Hi I been looking around how to mount those flat gas cans. Like the koplin or rotopax? Do I gotta make custom mounts or does any of the ones the company makes work for outlander?
Sent from my iPhone using Tapatalk
Ashes is online now
post #2 of 11 Old 05-09-2019, 09:16 AM
Garage
I mounted two to of the one-gallon'ish tanks right on the front rack.
The mounts are simply connected to the front rack with a couple of U-Bolts.
Graham
RCAF Retired (1981-2002)
2019 Outlander Max 570 XT
galamb is offline
post #3 of 11 Old 05-09-2019, 09:46 AM
WIOutty's Avatar
I have the 1.75 gallon rotopax and I just ratchet strap it right down to my rack works perfectly
WIOutty is offline
The Following User Says Thank You to WIOutty For This Useful Post:
superxtruder (05-09-2019)
post #4 of 11 Old 05-09-2019, 10:09 AM
At least the XT-P doesn't have tubular metal racks. They're flattish plastic, so a U-Bolt wouldn't fit. It'd be nice to mount those RotoPax units with a LinQ type of clamp. Somebody needs to fab one .
elptxjc is offline
post #5 of 11 Old 05-09-2019, 11:34 AM Thread Starter
Yeah I don’t think the u bolts will work on my racks. I guess for now I will use ratchet straps
Ashes is online now
post #6 of 11 Old 05-09-2019, 11:53 AM
Jorge570's Avatar
They make many style mounts. Just google search rotopax mount etc.
2017 Can-Am Outlander 570DPS
2001 Ski Doo MXZ 700
Jorge570 is offline
post #7 of 11 Old 05-09-2019, 10:38 PM
Premium Member
GunnyE9's Avatar
I use Roto Paks & here is what I did on my 2014 Outlander MAX.
I took the Roto Pak Standard Mount, https://rotopax.com/pack-mount.html
... where the holes are in the for the "Body" of the mount, I drilled them clear thru for 5/16 in bolts and bought a couple of long bolts & a couple of nylon nuts.
Next, I take the base with the raised mounting holes up (like in the photo) & slide it under the center of the plastic rack under two of the quick link holes in the rack. I hold the mount in place with a nylon nut, put the base over the two factory quick link holes (at the aft end of the rack), & start one bolt, then I hold the other nylon nut under the rack & get the other bolt started. And then I tighten them down. Works pretty good & it's easy to remove when I need to.
GunnyE9
All Around Nice Guy .... "Work" is a Dirty Four Letter Word ...
My Video's - http://www.youtube.com/user/GunnyE9?feature=mhum
______________________________
2014 Metallic Outty 1000 MAX-XT with just a few mods ...
GunnyE9 is offline
post #8 of 11 Old 05-10-2019, 09:20 AM Thread Starter
Ok thanks I will try this and see how it goes
GunnyE9 likes this.
Ashes is online now
The Following User Says Thank You to Ashes For This Useful Post:
GunnyE9  (05-10-2019)
post #9 of 11 Old 05-13-2019, 03:10 PM
I have a Rotopax on the rear of mine, 2.5 gallons. There is a bracket that bolts to the rack, then a stud sticks up where the 'pax goes, then a T handle type thing that secures it. I didn't want it at first, but it doesn't get in the way so gonna leave it....
2018 Outlander XXC
27" Pitbull Growlers
HMF slip on
Bomb ECM/controller
Lots of lights
Bumblebeegade is offline
post #10 of 11 Old 05-17-2019, 01:20 PM
One question on those containers: Do they have a pressure relief valve? Or do you just fill them to the brim, to avoid sloshing, and creating pressure inside? Just curious, since just the sun hitting the container would cause expansion. Thx.
elptxjc is offline
Front Rack and Bumper Removal Tacoman Can-Am Outlander 11 05-04-2019 05:39 PM
Front Rack Jerry Can BranKon Can-Am Outlander 14 01-10-2019 09:15 AM
LinQ front rack on a 570? Zmaro Can-Am Outlander 1 10-25-2018 10:51 PM
Solutions to fill holes in front Rack Crazy Canuck Can-Am Outlander 12 06-29-2018 05:02 AM
Front rack storage bretterwin85 Can-Am Outlander 5 12-08-2015 11:52 AM
