Is loctite required - Can-Am ATV Forum
 3Likes
  • 1 Post By Dr_Z
  • 1 Post By 25TH INFANTRY
  • 1 Post By elptxjc
post #1 of 10 Old 05-09-2019, 03:09 PM Thread Starter
Danieldp13's Avatar
Is loctite required
I am changing my primary spring tomorrow night. Is loctite required on the primary clutch bolt? If so is it ok to ride my machine about 12 hours after re torquing the bolt with loctite?
I see it sets in 10 minutes and fully cures in 24 hours.
Danieldp13 is offline
post #2 of 10 Old 05-09-2019, 03:15 PM
25TH INFANTRY's Avatar
no loctite on primary but i know some people use it on the secondary but it don't call for it. loctite takes a lot longer to set if its cold out, fyi. i use loctite on every bolt i remove except the fender bolts and clutch bolts. I've had shock bolts and a-arm bolts come loose before.
2010 Renegade 800R XXC
2011 Outlander 800R XXC
25TH INFANTRY is offline
post #3 of 10 Old 05-09-2019, 03:22 PM Thread Starter
Danieldp13's Avatar
Haha I have a little ocd and don’t want that bolt to ever come loose or have to worry about it.
So I will be ok changing the spring out and re torquing to 74 ft lbs.
Sounds way better to use loctite we ride pretty aggressive so It is possible to see bolts coming loose.
post #4 of 10 Old 05-09-2019, 04:58 PM
Dr_Z's Avatar
I never use thread locker on the primary clutch bolt but I do use a torque wrench to set it. Never had any loosening issue here.
25TH INFANTRY likes this.
2011 Outty 800XXC
Dobeck AFR+, Hayden fan controller, QSC Rev-X primary/STM secondary, TORQ Locker
Powermadd hand guards, RotopaX 4 gallon, Symtec heated grips, Homemade UHMW skid
My YouTube page
(mostly unedited track rides)
Dr_Z is offline
post #5 of 10 Old 05-09-2019, 05:58 PM Thread Starter
Danieldp13's Avatar
Ok thanks!
post #6 of 10 Old 05-09-2019, 08:37 PM
sounds good until that bolt gets stuck on there and it happens a lot, hence the reason i don't loctite it. I'm a torque wrench guy as well and those are the only bolts i check and re-torque after every ride.
Chief... likes this.
post #7 of 10 Old 05-09-2019, 08:56 PM Thread Starter
Danieldp13's Avatar
Sounds good I will just re torque and make sure to check it every once in a while
post #8 of 10 Old 05-13-2019, 12:35 PM
Just a word of caution. Or two, really. Ha ha. First, there're DIFFERENT kinds of thread lockers, or loctite, but mainly RED and BLUE, so always specify which one when discussing it. They're VERY different . The blue is the mild version, while the red is called permanent, because you'd probably strip the head or break the bolt while attempting to remove it. And even with tons of heat, it takes a hefty head/bolt to remove without damage, but many times, you just can't apply it where the bolt is, due to neighboring plastic, sensors, etc. The second caution is to NOT use loctite if not called for; it's not needed, as mentioned above. But if you insist, at least use the blue one. Hope this helps.
elptxjc is offline
post #9 of 10 Old 05-13-2019, 02:56 PM Thread Starter
Danieldp13's Avatar
Thanks for your advise. I do know the difference between red and blue loctite haha. But I didn’t end up using any like I was told not to! I went for a long ride on Saturday so next week I will just open the clutch cover and re torque it
post #10 of 10 Old 05-14-2019, 10:29 AM
Matts175's Avatar
I'm paranoid, so I used a dab of blue.
2017 Can Am Outlander 450
Outty 1000 Max Springs/Shocks, GSE Performance Trail Tamer Exhaust, Dobeck EJK Tuner, 22" LED Light Bar, Heat Demon Grips/Thumb/Butt Warmer, Trail Tech Temp Gauge, Airbox Lid #248 O-ring Mod, Synthetic Winch Rope, 54" Alpine Plow
Matts175 is offline
Maintenance Required Reset kobuk Can-Am Outlander 2 02-01-2019 02:46 PM
Red loctite on secondary bolt Xmrwarpig Clutching 6 01-08-2019 05:46 AM
Maintenance Required Message Mahtee Can-Am Outlander 4 07-05-2016 06:59 PM
Question Yellow Loctite and Torquing hdoilcan ATV Tech Tips 5 04-10-2016 08:46 PM
No maintenance required message even well past 10hr? dandiele Can-Am Outlander 10 01-07-2016 10:14 PM
